peranders said:You are right. This doesn't work. I can only change the default value at the first page. I can't change anything in the USER CP.
Changing my User CP is fine and I can change from 30 to 20 posts per page but my problem is that I can't use the option on the URL line as to display larger pages for searching for keywords.
This has indeed been covered before. You can change the value thru your user cp to one of the predefined values. However, you cannot change the value in the url to get the same effect. This was done by the company that writes the bulletin board software to avoid having excessively server intensive scripts when the number of posts on the page is too high.
