DIY Video Projector Part II
autocad
Guy,
If you are game can you drop me a line.
I can give you the exact details of the project...as well as forward you a layout drawing to clear up what I really need to do.
After a few days of rethink I have a few options that may seem feasible...but the lense portion of this project is not my strong point.
Jason
LCD source light I WORKS!!!!
For all that are interested in building a cheap and small projector, I've finished the trial en error stage of my 2.5" LCD with an array of 48 super bright white LEDs as light source.
here's the list:
50 super bright leds 80,000 cmd, from besthongkong on eBay $ 13.90 deleivered
30 resistors from radio shack $ 9.00
2-Action TFT 2.5" color service monitor, eBay $ 160.00( I still have one if someone is interested)
1- predrilled pc board from RadioShack $6.00
1- Rear TV projection Lens 4 1/8 diameter, free( I found 1 broken tv on the street and pulled out the lenses, lucky me!)
and the rest is pieces of wood and screws from Home depot $ 25.00
photos coming soon!
write me if you want
irwing69@comcast.net:D
I made a neat little projector using a 4" b&w toshiba TFT which has a resolution of 35k. Instead of a crt lens I used a f1.2 super 8mm lens. For light I used a 35w 3000lm HID lamps with ballast that I had laying around, along with a reflector from a 1m candlepower spotlight. I used white posterboard for the screen. The results were not bad. Contrast was good. It was pixelated but that made it interesting and unique.
It was fun but now I've bought an Infocus projector. If anyone's interested you can buy my 4" LCD from me which has both wired or adapter for power, video in, audio in, brightness and color. for $20.
Re: LCD source light I WORKS!!!!
Cool, I'd be interested to know what sort of brightness you get from it, I suspect you have to be in quite a dark room or seriously restrict the screen size (probably not a bad thing with an lcd that small). Also what sort of heat do they give off with your configuration once enclosed in a box? How does the colour temperature compare to MH, etc.?
I've never doubted LEDs as a light source but the cost has always been a bit too much, seems like you've made something you're happy with for next to nothing which is always good!
I can't find a power supply for my nView Z350 anywhere, so No I'm using an ATX power supply which run the Panel just fine, except it heats up after about ten minutes and then the video gets distorted.
The model number for the original power supply is BPA-353-N, and has the following voltages:
Volt / Amp
+5.9 3
+12 1.55
-12 0.27
The one I'm using has the same voltages but quit a bit more amps than that, and I'm not sure if that's what causes it to heat up.
Has anyone been able to successfully run an ATX power supply on this panel or does anyone know what the issue is?
Wondering
I hope I'm posting this correcting and not hijacking a thread. If so please let me know and I'll not make the same mistake again.
But hopefully someone could answer a question for me.
I'm in the process of collecting parts to build a projector based on a 15" LCD.
I happened to be doing some Christmas shopping at a local electronics store and couldnt resist picking up this lens for $20.00 and am curious whether it could be incorperated in my project.
Its a Sharp AN-LV40EZ, I just checked the web and its listed on B&H photo for $2500.00, which of course doesnt mean it will work but if it doesnt I'm only out $20.00 :)
The specs I've found out so far are
* Type
* Wide-angle zoom lens Zoom, Wide angle
* Lens aperture
* F/1.7-2.1
* Focal Length
* 74 mm 97 mm
* Optical zoom
* 1.3 x
* Zoom adjustment
* Motorized drive
* Throw Ratio
* 1.9-2.5:1
* Projection Distance for a 100" Screen
* 13.8 ft - 18 ft
This thing is a monster at 11.25" long. Rear lens Diam of 3.5"
Front lens diam of 4"
Any thoughts would be appreciated
might work with a PSone LCD
With that short a focal length, the LCD will have to be very close to the back of the lens. So the LCD could not be much larger than the lens diameter. Perhaps the FOV will be wide enough for a PSone 5" diagonal LCD. Try some experiments with printed transparency film, the lens, and a spotlight to see how large an area you can project over the real throw distance you want to use.
For a 15" LCD projector, you need a lens with a much longer focal length, just so you can put it far enough from the LCD so that the FOV covers the entire LCD.
Standard lens & matching fresnel sets:
300 mm fl overhead projector triplet with 220 and 330 mm fl fresnels
450 mm fl opaque projector triplet with 220 and 550 mm fl fresnels
Future build
Thanks for the reply Guy. Looking at the machine it was used in I was afraid of that.
To make something like this work I would either have to modify the lens or create a way narrow the focus point of the lcd screen or as you say use a smaller screen which would lose resolution. Both mods are outside my skill level right now, back to using the triplet after Christmas :)
Hi everybody!
I'm thinking about building an independent projector based on iPod Nano (3g). It has small (2") screen with relatively high resolution (320x240) and it is very bright with standard backlight (someone built projector without ingerention to ipod: http://www.engadget.com/2008/03/03/diy-ipod-video-projector-boosts-utility/ ).
Did anybody try to adapt Nano's lcd to use it in normal projector? How about results? I don't want to destroy display if it is bad for projector.
320 by 240 is relatively high for a tiny LCD screen, but it wouldn't be very nice for the larger image want from projection. Regular NTSC TV is more like 560 by 488, for the luminance. When you try to make a standard definition TV projector with a large image you see those big pixels in the image. The 320 by 240 image will be much worse.
But it would be very nice to have a higher resolution 2" to 4" LCD: Then you could use CRT-projector lenses that are plentiful and go for around $10 on ebay. Or even $0 for three if you can find an old junked CRT projector sitting on the curb on garbage collection day!
** UDIY PROJECTOR ** BY oliver
Projet ( UDIY ) BRASIL
- Ecran toshiba 10.5"
- Kit HQI 150W 5.200 k
- Fresnels F1 220 mm
- Fresnels F2 320 mm
- 2 ventiladores 12 v
- Triplet de 320 mm
- Matériaux principal de la Box MDF
- Connectique de la Box : AV VGA TV
- Distance de projection 2,70 m
- Taille de projection : 1,30 x 1,180 m
http://projetordiy.com.br/forum/viewtopic.php?f=3&t=2651&p=26553#p26553
HELP NEEDED FOR BULB
Hi All
I am unable to get MH with Ballast at my place, the dealer has offered few alternatives.
1. Philips Aluline Pro 37/56 mm
Product Description
• Low-voltage halogen burner in a lightweight, high-gloss anodised aluminium reflector giving a white halogen light
Product Feature
• Integrated protective front glass
• Choice of clear or frosted glass
• High-intensity beam with an extremely clearly defined beam shape (clear glass versions only)
• Excellent color rendering
Product Benefit
• Excellent accent lighting effects due to reduced spill light (clear
versions only) Application
• Excellent light source for accent and general lighting in shops,
home, restaurants, galleries, exhibitions and museums
Rated Lamp Wattage: 35W
Beam Angle : 6D
Lumens Intensity: 18000
Rated Voltage : 6V
Another Choice
Philips MASTERColour CDM-R 35W/942 E27 PAR20L 10D
Watt : 39W
Voltage : 85
Color Tempeature : 4200
Chromaticity Coordinated : x - 371, y - 366
Luminous Intensity : 21500
Beam Angle - 7.5D, Spot
Option3
Philips MASTERColour CDM-R 70W/942 E27 PAR20L 30D
Watt : 73W
Voltage : 88
Luminous Intensity : 13000
Beam Angle - 26D, Narrow Flood
Please help me in taking a decision
Naidu
