Fixed gain field recorder?
TNT
Joined 2003
Here is a field recording in a sunken down square in central Stockholm. Concrete as far as the eyes can reach :)
Solo trumpet, mics 4 meter away low - I didn't rig the stand as this was made in a whim. I asked or permission to record. The man playing also held a speech / prayer - the level is adjusted as the trumpet was much stronger than the voice. Amazing what energy a single trumpet really has... I reflected while recording that the trumpet sounded quite small and thin.... he also gathered a lot of saliva which he had to pour out once in a while (hence some gargling/crackle.-.) - I edited these intermissions out ;)
  • TMs.zip
Reactions: 1 user
TNT
Joined 2003
No change. But as I was thinking about the answer and became a bit unsure it dawned on me that I need to develop a version handling and file naming system to keep track which conversion process version a certain "release" was made form. I'm quite sure I'm not at the final variant so it will be needed.
TNT
Joined 2003
Yet and excerpt from the latest organ recording session (No.9). It is the same HW as the last one. Mic positions quite radically changed. Mostly interested to hear a judgement about stage / height for this one but all impressions are valuable thanks!
  • AF9x.zip
TNT
Joined 2003
A short snippet of "jass-jam"... no processing other than gain by bit-shift and down-sampling by CDSP (Nyquist true).
Minimum sample value -0.6410 -0.8256
Maximum sample value 0.7237 0.8390
Peak amplitude -2.8 dB -1.5 dB
DC offset -0.0000 -0.0000
Minimum RMS power -78.5 dB -78.5 dB
Average RMS power -19.9 dB -19.3 dB
Maximum RMS power -9.1 dB -7.4 dB
Clipped samples 0 0
  • UPT1_jam.flac.zip
