FS: Clone Note LDR Attenuator
I built this with the following parts;
Elma 1 Pole, 24 Position switch, to replace the notchy original item.
Neutrik, NYS367, RCA jacks.
Beckman Instruments, Precision, 10-turn, 5K ohm helipot, which allows balance control.
Sorbothane feet.
Audioquest AQ Silver Solder.
The box is obviously an old tin, cigar box from @ 1925. I used a Sola, external LPS which I plugged into the vintage connectors on the left rear corner of the box. I'll include a pair of the corresponding plugs so that you can connect to your own power supply.
It comes with 15 extra LDRs, just in case.
It works perfectly. I'll accept returns within a week if you aren't happy.
$200 shipped CONUS via Paypal and Friends & Family.
Please ask any questions.
Thank you Jean Paul.
I am a sucker for old cigar boxes. I've housed a number of projects in them over the years.
I had a friend years ago who smoked a lot of cigars. In my motorcycle shop, all of the spare hardware and small parts were stored in dozens of neatly stacked and labeled La flor de Cano boxes.
