HyperSET Voltage swing
Founder of XSA-Labs
Joined 2012
The HyperSET should have the same output capability as a BTSB panel mount as they use the same output driver OPA1637 and same +/-15v DCDC. I tested the BTSB in balanced mode and was able to drive 52Vpp. That should be more than enough to drive an F4. Only 40Vpp is needed to get 25w out of 8ohms.
https://www.diyaudio.com/community/threads/btsb-panel-mount-buffer.379030/post-7277059
Demonstrated 40Vpp:
1677031199226-jpeg.1145607
