Hi im getting 38v on the ground on this amp any idea what could cause that
A Aqeeb127 Member Joined 2018 2019-03-03 1:54 pm #1 2019-03-03 1:54 pm #1 Hi im getting 38v on the ground on this amp any idea what could cause that ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-03 2:04 pm #2 2019-03-03 2:04 pm #2 Saw this also Attachments DSC_0660-1600x1203.JPG 482.5 KB · Views: 118 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-03 2:38 pm #3 2019-03-03 2:38 pm #3 It sounds like there's a short to one of the speaker outputs (assuming that the amp has about 76v of rail). ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-03 4:40 pm #4 2019-03-03 4:40 pm #4 Sorry its -38 on the ground of the rcas ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-03 5:01 pm #5 2019-03-03 5:01 pm #5 Negative 38v? Does this amp have positive AND negative supply rails? Where was the black meter probe when you measured -38v? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-04 7:15 am #6 2019-03-04 7:15 am #6 Yes it has - 38v the bleck probe is on ground ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-04 9:04 am #7 2019-03-04 9:04 am #7 Does this amp have positive AND negative supply rails? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-04 4:12 pm #8 2019-03-04 4:12 pm #8 Yes id has +38v 0v -38v ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-04 5:09 pm #9 2019-03-04 5:09 pm #9 That's unusual for a 4080 based amp. What's the resistance between the RCA shield and the negative rail? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-06 11:11 am #10 2019-03-06 11:11 am #10 Sorry i took the board out removed the outputs and its giving one voltage now ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-06 6:33 pm #11 2019-03-06 6:33 pm #11 Are you sure that you didn't have the black meter probe on a speaker terminal? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-07 8:43 pm #12 2019-03-07 8:43 pm #12 Yes i took the board out and probing on the negatibe side of the capacitor ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-07 8:44 pm #13 2019-03-07 8:44 pm #13 Yes i took the board out and probing on the negative side of the capacitor as it only have a positive rail ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-07 8:45 pm #14 2019-03-07 8:45 pm #14 I will send pics of the bottom of the board ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-08 2:57 pm #15 2019-03-08 2:57 pm #15 Thats the bottom of the board Attachments DSC_0642-1600x1203.JPG 436.4 KB · Views: 41 ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-08 2:58 pm #16 2019-03-08 2:58 pm #16 ... Attachments DSC_0640-1600x1203.JPG 386.3 KB · Views: 43 ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-08 6:53 pm #17 2019-03-08 6:53 pm #17 With the black probe on the main ground terminal, what's the DC voltage on the RCA shields? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-08 9:52 pm #18 2019-03-08 9:52 pm #18 Its zero now since i took the outputs out ••• More options Share P Perry Babin Member Joined 2003 bcae1.com 2019-03-08 10:30 pm #19 2019-03-08 10:30 pm #19 Was that the only problem with this amp? ••• More options Share A Aqeeb127 Member Joined 2018 2019-03-09 10:59 am #20 2019-03-09 10:59 am #20 It didnt give sound also ••• More options Share 1 2 Next 1 of 2 Go to page Go Next Last Show hidden low quality content Status This old topic is closed. If you want to reopen this topic, contact a moderator using the "Report Post" button. Share: Facebook Twitter Reddit Pinterest Tumblr WhatsApp Email Share Link Home General Interest Car Audio Ice power ps 5000 38 volts on rca ground Top Bottom
