in fact there is one finger already Missing.
Hi
I have two MS1401A drivers and they have an unleven Z response : the fisrt has a high Q response at about 400 Hz 60 ohms and the second has a very low Q reponse : only 20 ohms at 600 Hz.
I have have genuine JA6681B drivers and their responses are about 60ohm@400Hz
Do you have any idea what could be causing this? I tested the sound response of the TH4001 horn: the bad one seems to be less good.
Attached photos of diaphragms and Z response with DATS.
Pascal
All of these brands make beryllium drivers, so they know how to design and build with that material.
Maybe they or someone they know are willing help perfect our cloned diaphragm and do small runs of them.
https://sbacoustics.com/?post_type=product&s=beryllium
https://www.eighteensound.it/en/products/hf-driver/1-5/8/ND4015BE
https://www.masterdynamic.com/blogs/know-your-sound-tool/know-your-sound-tool-beryllium-drivers
https://www.focal.com/technologies/the-beryllium-tweeter
https://www.materion.com/en/product...ryllium-products/truextent-acoustic-beryllium
https://vue-audiotechnik.com/beryllium/the-use-of-beryllium-in-transducers/
https://www.paradigm.com/en/passive/persona-b
https://www.revelspeakers.com/info/series-performabe.html
I guess that the black stuff seems to be epoxy coating used by MeyerSound to hardned the Yamaha diaphragm.In fact there is one finger already Missing.
on
you wrote
"Meyer was using the original diaphragms but they limited the excursion by
applying epoxy or the likes to the surround fingers. This had a bit of a negative effect on the sound.
Look at the pic:"
Hi,Align the voice coil by loosing the screws and adjusting the position of the VC while playing a lowish tone from a tone generator jntil you get a clean sound.
One of them could be blown and have a deformed VC. If so, try to replace.
I already tried to remove and replace, even to change the driver but always the same Z response.
I will try the hear and measure a tone when loosing/screwing the dia.
What Meyer Sound did was an even distribution on the fingers with an opague (slightly pinkish) Epoxy. Look at the linked Pics again.
I know it is hard to swallow, but these are poorly "repaired" Diaphragms. Repaired is not even the right word, covered up damage describes it better.
If you still can, get your Money Back.
Angry to read that Radian,
I think my seller will not want to reimburse me, because he already said that the drivers had been checked by a specialist in Belgium and he paid him €175 for that. Today I tried to realign the VC by checking the impedance curve: it's much better, the curve is clearer but the peak value is only 34Ohm instead of 60 and the Fs is 530Hz instead of 400. The other is still OK. I have to set up a listening set (bass, filter, etc.) to really check their sound compared to the originals.
Check your messagesOltos
Did you finaly find a partner who will be ok to rebuilt them?
The price would be anaysed in a second time.
So sorry for you.
It happened to me too with one of my 6681b
Check your messages. Will also add this one to the list, though they may not have the engineering staff to do any prototyping. https://www.simplyspeakers.com/Oltos
- Info on the Yamaha JA-6681 compression driver
