Kit SSHV for Phono and Tube Pre (Simplistic Mosfet HV Shunt )
Simplistic Mosfet HV Shunt (SSHV for Phono and Tube Pre)
Design by Salas, Make PCb and kit by quanghao
Hi all!
SSHV shunt regulator is a great hight voltage Shunt supply for Tube Pre amlifiler and phono.
So many people have no free time, like me make this kit, so I try to complete it for you!
How interested would you sign up, I will try the first 10, and will offer a fair price for a kit
All information you can see this link:
http://www.diyaudio.com/forums/power-supplies/134801-simplistic-mosfet-hv-shunt-regs.html
And:
http://www.diyaudio.com/forums/powe...stic-mosfet-hv-shunt-regs-97.html#post2084348
I use SSHV for Phono ASH ( Phono D3a design by Andrea):
http://www.diyaudio.com/forums/quan...i-end-phono-preamplifier-andrea-ciuffoli.html
And Group by:
http://www.diyaudio.com/forums/quan...hv-shunt-simpler-simplistic-design-salas.html
Here is the measure SSHV
Hi Quang Hao,
I received my Kit the other day, would like to Say Thank-you, the quality is outstanding, I have one question so far the Caps C6 and C18, I noticed that they are not used on your board are they needed or is there some special circumstance where they are required, I do have them in my parts so can use them if they will improve circuit.
Regards Jezza
Hi Quang Hao,
Regards Jezza
Hi! it is good!
it no need! you do not worry about it! If you still need it, i can sen it to you!
you test it??
