minimum voltage across an electrolytic capacitor
Assuming the bias is the correct polarity, consider that zero-volt bias is not different from the component shelf life. The feedback decoupling cap in typical amps is a common failure, but they are often under-voltage, ie 6.3V or 10V when potentially exposed to maybe 50V from the output. Clamping diodes can provide protection. Latch-up can occur when a high DC output voltage reached the amp input. Bias servos may or may not solve such problems.
Reactions: 1 user
