My Balanced Line Receiver
"Now, some people may prefer the (slightly) distorted sound". This is along the lines of what I'm getting at. There is no one THD figure. Real distortion profiles are a 3D graph of level, frequency, and spectrum. The graph shape varies with the distortion mechanism. The rate of distortion change is highly variable from a very gradual slope to a flat brick wall. There's just no way to discuss THD audibility simply.
However, when low enough, and in the presence of other audio signals that are 50+ dB higher in level, audibility literally becomes a function of masking.
Let me conduct a little experiment. Let's say we have an amplifier that adds 0.01% of the 2nd harmonic (H2) and 0.001% of the 3rd (H3):
The distortion is not particularly high and is all low order, harmonious and benign, perhaps even euphonic.
Now let me play a simple chord, A-C#-E:
Oops. In addition to H2 and H3, our benign test amplifier sputters a bunch of intermodulation products, musically unrelated to the chord, with levels comparable or in some cases above those of H2 and H3. These are not euphonic and would not be masked by music. Such an amplifier might be ok for simple music such as a solo vocal, but would get confused with anything moderately complex, and would mush a full orchestra.
So, while various components of the audio chain undoubtedly distort, 0.01% THD does not give your amplifier transparency, and you do get audible benefits from making one of them more linear.
Interesting exercise, but you are aware that many popular tweeters have H2 of only -30 dB H2, perhaps even as "bad" as -25 dB H2, at the low end of their passband?
Joined 2009
The part list a.k.a. BOM for one balanced line receiver board (see post #6 for the schematic and board outline):
QtyValueDevicePackageNamesExample P/N
2LM4562Dual opampDIP8U1, U2LM4562NA/NOPB
12M2Metal film resistorAxial 0204R1MFR-12FTF52-2M2
247kMetal film resistorAxial 0204R2, R3MFR-12FTF52-47k
212kMetal film resistorAxial 0204R4, R5MFR-12FTF52-12k
41kPrecision metal film resistorAxial 0204R6, R7, R14, R15/R16MFR-12FTF52-1k (1%) or
CMF501K0000BEEB (0.1%)
410kMetal film resistorAxial 0204R8, R9, R12, R13MFR-12FTF52-10k
2220kMetal film resistorAxial 0204R10, R11MFR-12FTF52-220k
222RMetal film resistorAxial 0204R17, R18MFR-12FTF52-22R
2100RMetal film resistorAxial 0204R19, R20MFR-12FTF52-100R
447uElectrolytic capacitorRadial D=5mmC1, C2, C3, C4EEU-FC1C470B
2470pNP0/C0G ceramic capacitorRadial LS=5mmC5, C6FG28C0G1H471JNT06
410uNon-polar electrolytic capacitorRadial LS=5mmC7, C8, C9, C10ECE-A1VN100U
With the part numbers shown in the right column and today's prices on Mouser.com, the total cost of this BOM with 1% 1kOhm resistors is just shy of $11.
Just a reminder: the GB for these boards is closing tomorrow.
Hi Alex,
I'm enclosing measurement results obtained with your PCB in two configurations: 2xLM4562 and OPA1656/OPA2156.
The measurement setup consisted of the Victor's oscillator with a 1656 parallel buffer, Hall topology notch filter (Groner PCB), Groner's 60dB LNA (0.39nV/rtHz) and a Cosmos ADC. The PSU was Jan Diddens's SilentSwitcher, itself supplied by a Power Bank.
The filter represents a load of about 1.8k, so at an output voltage of 2Vrms my measurement results should be comparable to yours at the first page of this thread.
The first measurement, made with 2xLM4562 on the PCB, produced the 2nd at -135dBc (-85.5 - 50 for the filter attenuation), which is the same as you obtained. The 3rd is at -158 in my case, some 18dB lower than your result.
The combination of OPA1656 at the input and OPA2156 as the diff. stage resulted in excellent figures for the 2nd and 3rd harmonics: -156 and -162dBc, respectively. Since the harmonics were just visible with the arithmetic averaging in REW, I had to resort to the coherent averaging (s. the 2nd att).
Now I'm fully aware of the fact that at these distortion levels I must take the results obtained with a grain of salt, but since TI measured the 2nd and 3rd harmonics of less than -160dBc at Vout of 3Vrms (s. Fig. 12 in the OPA1656 DS), the figures I obtained are at least not impossible.
It's a nice PCB you designed, Alex!
Reactions: 2 users
Here is the full schematic:
I guess I'm a bit late to this particular party, but just wanted to mention that you can use a T-type topology for input capacitors much like with resistors R1-3 (you could even put them directly in parallel). Doing so with values of e.g. 47p/470p/470p would have pushed high-frequency CMRR degradation substantially further out while making capacitor matching a lot less critical for CMRR performance up there.
Joined 2009
Except that caps arranged as a T wouldn't protect the input opamps from RF ingress, which is why the caps are there in the first place. (Instead, each of the two input opamos would see an identical RF input, and that's would not help their linearity.)
A better idea would be to bootstrap the middle point of both resistors and capacitors, as proposed by Bill Whitlock of Jensen Transformers - see the attached patent.
  • US5568561.pdf
Joined 2009
THAT1200 is (unfortunately) a not-so-linear implementation of the above patent, referred to as InGenius in the datasheet. If you don't have linearity to begin with, the input LPF probably doesn't matter as much.
Look at the patent instead, specifically at the "preferred embodiment" in Fig. 12 and its description, particularly page/column 10, lines 30-45. You can choose a larger midpoint-to-ground capacitor (the patient mentions 470pF) to provide better RF immunity and then bootstrap it to keep the CMRR high at low frequencies.
