OLD THREAD Simplistic Mosfet HV Shunt (The Simpler Simplistic Design by Salas)
Dear Salas
Dear friends!
After Salas shunt regulator for use with my system Pre818, phono D3A by Andrea, I saw the The Simpler Simplistic Design by Salas great, I enjoyed with the advantages:
**The Simpler Simplistic : Cheap, easy to do, the sound is great! **
I decided to make a group buy to reduce costs and share the circuit layout. I will send for people with layout suggestions, when It is ok I will start making PCB.
Thank Salas very much.
This is my pre and The Simpler Simplistic
Oh man, this is what I'm looking for. I've built Salas simplistic HV shunt regulator for my tube preamp with very good result and it replaced my tube regulator but my build is point to point on veroboard only because I could not make a decent PCB.
So two PCB for me please.
