Paradise Builders
Joined 2005
DESPITE Simon1972 and others attempting to help you have NOT posted the pictures they need
to help you overcome the problem.
I know that Simon1972 has built and or repaired a very great number of these Paradise head-amps.
To call it "the worst project ever" is - in my opinion - totally unfair to the designer and to all of those who have tried to help you.
I suggest that you post pictures (Possible????) and see if there is - to those who know these things - an obvious answer.
Joined 2004
This is a great project.
My experience. I ran into difficulty building the power supply. An esteemed member offered and fixed it for free. Then I could not get my two preamp boards to bias properly. I put the project aside for a few weeks to get some rest. Upon returning to it I inspected my work carefully and found one solder bridge on each board. After reflowing and cleaning the joints, the boards settled and performed as they should. The good folks in this thread have been helpful all along. It was a long journey but well worth it - for the sound and finding kindness in others.
Several years later I am still enjoying Paradise :) .
Reactions: 1 users
Joined 2005
I‘m done with this project - at least for the moment.
From my personal perspective this is the worst project ever - and the only electronics project I was unable to finish.
some takeaways for my personal list
  • never buy unfinished projects that have been lying around for a decade or more
  • don’t mess with beta versions
Hi Stephan, you have pm
Reactions: 1 user
Joined 2008
Thank you all for your kind words.
Until I started this project, I wouldn't have considered myself a beginner. I have been building my own turntables and tonearms for a long time and have successfully developed, built and adapted various iterations of closed loop controllers for DC motors.
I have also successfully built a bunch of kits like this so far.
The boards look messy as I had to change a lot due to various reasons.
I‘m in contact with hesener so let’s see.
Joined 2005
If Hesener can't fix it, no one can.
I am sure you both Simon and as_audio can, certainly I am not the only one. But let's see if I actually can do it :D the proof is in the pudding!
I am suspecting the boards are a little older, and so the metal surfaces (even though gold) are a little oxidized. And, the lead-free solder available nowadays isnt helping, either.
wish me luck!
Reactions: 1 user
Joined 2004
I tried lead free solder for one project, it was awful, had to liquid flux every joint to get a good meniscus, just awful to use.
I've stocked on leaded.
Reactions: 2 users
Joined 2004
Honestly I've worked on some right ones, mix n match 25 and 40 graded transistors, input stages stuffed with 350 - 450hfe parts, input stages using parts from different brands, shunt regs oscillating worse than politicians, invisible solder bridges under the skt caps, and even one with a psu rail cap put in backwards ( from someone who should know much better, lol)
It's all fixable.
diyAudio Chief Moderator
Joined 2002
When trouble occurs its not in the the shunt voltage area but in the gyrator series area that feeds it. I replaced the gyrator with a simple Dmos CCS and all instability was gone.
It took some inventiveness to do that on the standard board though. Jumper wires, copper lane cuts, few new parts etc.
A straightforward drastic measure against an insisting oscillation would be skip the power section, remove the rails jumpers, power the audio section from an external stable low noise PSU.
Joined 2002
*Even a typical two channels bench PSU is good enough for skipping the onboard one and testing the situation. Preferably not SMPS type. Goal is the wall of noise seen when scoping the plus & minus rails pads to be largely gone.
Joined 2002
Mine did not have LM317 elements. It was this one. I replaced the circuitry between JP4 and the +/-18.2V points.
  • Paradise R3 schematic regulator annotated.pdf
Joined 2008
I think this is intended as cascoded current sources here, but nobody knows why
they choose a npn structure for the positive and a pnp for the negative rail.
The impedance of the sources is however impaired by the parallel elements R 101,
101b, C100, LED 1001, 102 (looking at one rail only).
Why should it be seen as gyrators, is this discussed somewhere ?
Joined 2002
If memory serves me right they were discussed as gyrators but maybe I remember wrong. In any case in there were the instabilities.
Top
