PCB Fabrication Service
PCB fabrication is also part of our services. Actually Siliconray's business was started from PCB.
We have a wide range of service line for PCB fabrication:
By layer: 1 to 40
By material: FR-4, Teflon, Aluminum, Rogers
Color options: green, red, blue, black, yellow
copper thickness: 1 to 10oz
board thickness: 0.5 to 2.5mm
min trace/clearence: 2.5mil
min hole: 0.1mm/4mil
finish: HASL, gold plated, Tin plated, Siliver plated, OSP
minium order quantity: >=1pc
Feature service: Ez-Proto
Once we had a advertise on audioxpress and voice coil magazines (expired now). We also had ad on Elektor, Circuitcellar, Nuts @ Volts magazines now. A lot of our customers order PCB for audio applications, the feedbacks are very positive. We suggest gold plated finish for audio applications. 2oz copper is preferred for audio amplifiers.
Please visit EzPCB - Professional PCB Supplier for further information. Any questions please don't hesitate to say.
