PCM63P-J vs PCM63P and turning PMD100 to NOS
Hi all,
Does anyone knows what is the difference between PCM63P-J and PCM63P?
I have a Rotel rcd-971 with PCM63P dac chip and a Parasound D/AC1000 with PCM63P-J and I would like to know if one has better specs than the other (couldn't find in the spec sheet) or maybe they are both exactly the same.
I also read that the PMD100 attenuate non HDCD cds, is it true?
Some HDCD recordings have a peak extension which basically is a 6dB compression of top 9dB at recording phase. At playback gain of 6dB should be applied to such recordings. PMD100 can apply this digitally or it can be done in analog stages based on signal from PMD100. In the former case PMD100 attenuates normal CDs or HDCDs without peak extension by 6dB. In the latter case PMD100 does not attenuate anything. How Rotel RCD971 handles peak extension is not known to me.
