Phoenix Gold Titanium 1200.1
Joined 2012
I was playing audio with 12” subwoofer, I replaced the gain pot (50k), it was bad, it ranged from 0.5 up to 3 vdc, sounded like my sub woofer coil was scratching. I think there maybe an intermittent race or solder joint issue. I reached out to onemoreamp for schematic
Joined 2012
With no load and scope on the output. Bottom seems to clip. If I set the phase from 0 to 180 the waveform clips on both top and bottom
Joined 2012
Hey Perry I can find anything on this chip. Do you have any thoughts?
Also this amp consists of:
5 x lm833
5 x lm837
1 x lm339
2 x Q 208. 110s
Joined 2012
Perry I found clipped waveforms on both outputs of the lm833 on u5. Right above it found a burnt 10 ohm resister reading 288.
Top
