Realistic APM 200 meter
Joined 2010
Hmm... I hate to be obvious, but there is a sensitivity switch on the front panel. It offers a low range and a high range.
Do the LEDs come on?
I've noticed that the LEDs are a lot more sensitive, specially in the low range, than the meters themselves.
I'm including a copy of the owner/user's manual, which includes the schematics.
  • hfe_realistic_apm-200_en.pdf
Thank you for that manual tonyEE. I have the 2w switched on and the 8 ohm selection on the back. Well, your right about the LEDs being more sensitive. I was wondering if I could increase the sensitivity of the meters with the adjustable pots inside the unit. Or would I just screw up the meter accuracy.
Cheers, Doug
Joined 2010
The unit might need calibration or just a rebuild.
I got two of them and bought them rebuilt... driving a 16 watt amp into 90 db/w, 6 ohm speakers, on the 2W setting, I can see the meters and the LEDs work. When I drive a pair of Maggies with a 200 watt amp, I can get those meters to play and play and play...
Have you tried different speakers? Something with low sensitivity?
Is the problem on both sides, or just one side?
A 50W, 8ohm, power resistor
I couldn't find a service manual for it. There's a guy on eBay that rebuilds them, that's as far as I can help.
