Salas DCG3 preamp (line & headphone)
diyAudio Chief Moderator
Joined 2002
Practically of course it can be used. No technical incompatibility. Why not try it since you will have it.
But how you will like the Khozmo 10k log + DCG3 combination is for you to judge. Squarewave rise time will be faster and bandwidth will be wider than with a 20-25k log for sure. That can be subjectively interpreted as clean but also as lean if an audio system as a whole lacks warmth. Including your room acoustics.
Reactions: 1 user
Joined 2002
These are the dimensions:
Dissipation is 10.2W at 150mA +/-17V for two channels. No worse than 1C/W (K/W) sink for 10C rise above ambient should be used. That's in free air and optimally oriented. Expect higher rise when boxed. Ventilation holes should be in vicinity. For mechanical stability & heat transfer the sink should be bolted in touch with the chassis. Apply thermal paste between their meeting metal surfaces. An adequate example sink type:
Fischer SK 85/100/SA
Joined 2002
Yes of course. About 470Ω RyJ & RxJ should take it there. Better put female socket pins in their places so you can try values because there are tolerances from build to build and from section to section. Or replace them with 1kΩ trimmers configured as rheostats if you can bodge them in there.
Reactions: 1 user
Joined 2002
Various supply designs can be combined and tested with the DCG3. The spec is that DCG3 can use between +/-15V and +/-17.5V rails consuming about 10W total DC power for single ended stereo (two channels 150mA output stage bias). Or about 20W DC for true balanced XLR stereo (four channels configured as two phases L two phases R).
