Hi, do anyone have any experience or knowledge of this output transformers from DIY HiFi Supply?
http://www.diyhifisupply.com/node/324
Have they been supplied with any of the kits? Are there better options with both 3k and 5k or 3.5k and 5k primary windings? They will be used in a Tubelab Simple SE, at least as a start.
Any input is most welcome!
I used them (in fact, had them designed) for my WE 91 Amp copy. They have been supplied with some of the SE Kits. I based my specifications mostly on the Tango XE20S with some small changes.
Primary inductance is somewhat limited, so while you can run a 10Y with this Transformer set at 8K, but I would suggest that such an amplifier may be a little challenged in the ultimate lows. It works very well at 5k with a 45 for example.
Ciao T
Ciao T
Hi Thorsten,
Thank you for your valuable input. I am planning to use the OPTs in a Tubelab Simple SE with EL34's. Do they have any tap for UL mode operation?
Future usage of the OPTs will probably be in a Tubelab SE with 300B (or maybe 45). Any thoughts on how they will perform in this application and how they would compare to more expensive transformers (e.g. Tango XE20S and various Silk OPTs) based on the experience with your WE 91 amp copy?
Thanks again!
Thanks again!
The transformers perform well with 300B, 2A3 and 45. Sound quality is good. Paying more for Tango or Silk mostly gets a little more detail. You need to go for permalloy core transformers to get a real step up.
Ciao T
Ciao T
Thorsten, your input is most appreciated!
From what I have learned from the tube forum and Tubelab forum, James JS-6123HS seems like a contender (at least in the looks department) in the same price range:
http://www.tubeaudiokits.com/PARTS/JS-6123HS.pdf
Do anyone have any thoughts or experience with both the James and the SE Universal OPT from DIY HiFi Supply? I find it rather difficult to decide on the OPT's, so all input is most welcome!
