Hi,Hi Tim
the way we have designed it..no but we will need to test
I just stumbled on to this thread while searching for a way to add a display screen (a simple 2 line text display would do) to the GPIO bus of the USBridge Signature.
I bought a pair of USBridge Signatures from the Indian distributor (Fab to Lab) and have twice written to Allo for help but got no response.
Would you be able to tell if there is an option to run a display off the GPIO of the USBridge Signature?
My goal is to split the GPIO via a splitter, run a display of one end and connect the other end to a Pi2AES board (so I can get I2S via HDMI output for my DAC).
Thanks.
USbridge connector has exact same functions as RPIHi,
Thanks.
@cdsgames, Any thoughts on adding CamillaDSP to the new USbridge? It should run well on an RPi4 compute module and would if well implemented would add greatly to functionality.
see.....https://www.audiosciencereview.com/forum/index.php?threads/rpi4-camilladsp-tutorial.29656/
for one DIYer's experience
The USBridge is a computer, you choose what software to install after you buy it. An RPi doesn't come with CamillaDSP installed, that is what there are the instructions in the thread you linked to.
Moode audio comes with Camilla DSP. Check out https://www.moodeaudio.org/
Yes, I found that thanks. The only question I have is the hardware (Pi compute module and supporting hardware) up to the task.Moode audio comes with Camilla DSP. Check out https://www.moodeaudio.org/
Thanks. I am unable to get any display with the USBridge but the same display works with the RPi4. That's why I asked.USbridge connector has exact same functions as RPI
What are your estimated ship dates? I am seeing anything from 3 months to early 2023 from many online suppliers. Any prospect of getting a prototype out to ASR for testing?Hi , sorry for the delay , we are just waiting for parts (tpa3255 fopr example..)
Also interested in this, partiqularly given the semi conductor shortage.What are your estimated ship dates? I am seeing anything from 3 months to early 2023 from many online suppliers. Any prospect of getting a prototype out to ASR for testing?
Any photos of the prototype TPA3255 chassis and dimentions? A fully integrated version would also be killer...
Any experience, anyone ?I'm already using the Katana DAC THD+N board, with the Shanti. Will the Boss2 + Shanti sound better ?
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
