The rail voltage is "+118.9/-118.9". I have a distorted signal on (pin#12) counting from right. The ic's id# is buffed out. I don't know the pin layout for the driver board?? I enclosed the signal in, driver board signal (pin#12) etc.. thanks..
See attached.
The driver ICs are IR21844S/IRS21844S.
This is my first Sundown.. Thanks Perry..
I checked the two IRS21844s chips using the resistance guide.
U1>> 6/5=24.65k 6/7=24.65k 7/5=5.4
12/13=.383m 12/11=24.6k 13/11=1.1m
With pin#7 lifted
trace: 7/5=9.2 leg: 7/5=348.3k leg: 6/7=.379m
U2>> 6/5=24.55k 6/7=24.55k 7/5=5.5
12/13=.373m 12/11=24.5k 13/11=1.28m
With pin#7 lifted
trace: 7/5=9.2 leg: 7/5=.949m leg: 6/7=.964m
What is a possible alternate to check? Thanks
With pin#7 lifted
With pin#7 lifted
Yes.
The l7812 were measured with -lead on rca shield.
When measuring the voltage on the L7xxx type regulators, place the black probe on the ground terminal of the regulator (different terminals, for L78xx and L79xx types) and the red on the other two terminals.
The ones you posted the voltage for need to be removed and checked (to see if they're shorted) out of the circuit.
L7812 & L7812a were shorted.
With regulators removed.
L7812 pin#2 to 1=open
pin#2 to 3=49.6ohm
L7812a pin#2 to 1=123ohm
pin#2 to 3=11.2ohm
pin#1 input=18.8v
pin#3 output=.8v
U1 7/5 was 9.2 Now 6.53k
U2 7/5 was 9.2 Now 6.64k
Will just the regulators need replacement?
pin#2 to 3=49.6ohm
pin#2 to 3=11.2ohm
pin#1 input=18.8v
pin#3 output=.8v
- General Interest
- Car Audio
- Sundown SCV-4000D. No output from audio driver board
