Is the input (transformer, rectifier, cap) connected to ground somewhere?
It seems that the regulator works OK, but you can verify the voltages at pin 2 and pin 3, they both should be at 2.5V.
Do you have a LED in series with the output? What is the voltage at pin 6?
I am also intrigued how you can measure the 218mV so accurately with a scope?
Jan
Jan
- The diyAudio Store
- super regulator build - victory or defeat
