Hi all, I will be partnering up with bk856er to set up a system at BAF 2019, consisting of his AMB γ3 DAC/pre driving my β24 power amp. He will also bring his Seas DIY speakers, Oppo BDP-95 unversal player as source, and other items. I will also bring other pieces to show. He is working on his own β24, so this will be a good opportunity for him to see mine up close for reference.
As bk856er mentioned in another thread, he is having serious health issues and has my total respect for doing all this in spite of the challenges. Kudos and let's all send positive energy his way!
I'm coming to Burning amp and bringing some stuff...
I brought a system last year, and this is an iteration on that. Last year it was a pair of active bookshelf speakers and a sub. I was set up in the Pass room last year, and didn't have to share space with many of you... my amplification didn't survive the trip though, and I ended up borrowing amplification from a gentleman set up nearby, thanks to him!
This year I've changed some drivers and made a new box. This is an active 3 way. The drivers are:
- Dayton Audio TD20F-4 - 3/4" soft dome tweeter
- Peerless / Tymphany TC9FD18-08 - 3.5" fullrange in mid duty
- Peerless / Tymphany SDS-160F25PR01-08 - 6.5" woofer
I think they're in like 10 or 11 liters. Small sealed box, inexpensive drivers, they don't go real deep but they're made to go with a sub.
I did upgrade the sub as well, but the new one is too big to bring. So the old one will come along, it's a OSB sealed box based on one of the 10" surplus NHT drivers (Foster) that were available a while back.
The whole thing is controlled by a computer running MAX / MSP with an application that I made for crossover / EQ. Tascam US-16x08 is the audio interface.
Amplifiers are a variety of chip amps. Some LM4780's I think I picked up last year in the raffle and a pair of LM3875 channels. My tweeter amps are hissing a bit, so if you have 6 channels of amplification you're looking to show off I'd be happy to partner with you.
I also have a Whammy amp (finished it just AFTER last years Burning Amp...) so maybe I'll bring that along with some headphones.
Look forward to seeing you all there!
I will partnering with fellow member KOHO to set up a system. He is going to bring his field coil back loaded horn speakers. I will taking care of all the amplification that including a TT with a 103R cartridge, a phono stage with LL9226 SUT, a 6V6 grounded cathode line stage and a single ended power amp base on Tubelab's SSE board. The phono stage with two input and able to accommodate another TT with mm cartridge, please with your own interconnect cable and ground wire ready.
One more amp is ready, for 92 dB or higher sensitivity speakers, 6W per channel.
It will be interesting to check how different output resistance (from big pentode - like to negative servo damping) drives different kinds of speakers.
I found finally the way to fit in an... - Anatoliy Lisovskiy | Facebook
Gubernator-71 is ready, for less sensitive speakers. 45W/Channel output. It also has output impedance selector, from high impedance to negative one.
Wavebourn - Gubernator-71 class A2 single ended amplifier with "pentode", "pentode with feedback", "triode", "triode with feedback", and "servo damping" output impedance modes. | Facebook
I had the pleasure of a doing a beta build for the ACP+ that will be built during Sat's amp camp at BA Ft Mason. Lovely pre/headphone amp...best of all it will power my Pioneer BOFUs (aprx 94 db sensitive) at mid 80s db with vol knob at 3 o'clock DIRECT with no power amp! ...and no clipping....Also tried it with my cans...what an fricken' amp, silent on noise as gutsy as hell....
I look forward to seeing Sat's participants and experience the same joy I've just experienced upon completion and performance..
Thanks Nelson for the design and hard work, Jim (6L6) for the impeccable documenation/guides as always
Hasta Sabado,
Mario
Hasta Sabado,
Mario
I'll be bringing an MC SUT made with Jensen transformers (we think Jensen) and a pair of VH DIY silver interconnects. Maybe I'll grab my Raspberry Pi with Allo Boss hat too but I have not been able to get it to work outside without my home wifi.
It is just too difficult to travel with anything big.
Oh, nothin'... Just a li'l headphone amp.
440 mW into 32 Ω, 660 mW into 50 Ω, 260 mW into 300 Ω at vanishingly low distortion.
I still need to clean up the verbiage on my website and add a few figures, but the overall idea is there and I've opened for preorders. I expect to have them in stock by early/mid-December. I should get a vendor thread going for this one of these days.
I'll have it with me and available for demo on Sunday.
Tom
Tom
HP-2_ Multitone Intermodulation Distortion (AP 32-tone, 100 mW, 300 ohm).PNG95.8 KB · Views: 95
HP-2_ THD+N vs Output Power (1 kHz, 32 ohm, 20 kHz BW).PNG44.3 KB · Views: 96
HP-2_ THD+N vs Output Power (1 kHz, 300 ohm, 20 kHz BW).png39.1 KB · Views: 105
HP-2_ Harmonic Spectrum (50 mW, 300 ohm, suppressed fundamental, 256k FFT, 16 averages) - annota.png52.2 KB · Views: 118
I had the pleasure of a doing a beta build for the ACP+ ...
I am so pumped for this circuit to be released I can hardly stand it. Please please please offer the boards in the store.
- Member Areas
- Clubs & Events
- What are you bringing to Burning Amp 2019?
