InFocus Projector ballast findings...
I know doon1 will probably never see this post, but if you do, could you possibly tell me what this ballast was taken from?
I have the exact same thing which is from an InFocus LP725 LCD projector. I ripped it apart and carefully picked the potting compound (rubbery stuff) away from the transformers.
I have included the following in case it might help somebody about how these projector's lamp supplies work....
I was trying to find out exactly what these projector ballasts are made of. I've repaired the power supply of this projector, but I'm not sure if it's the lamp, or the ballast which is faulty?
I tried the projector again last night (you have to hold both brightness buttons down for ten seconds to force the ballast to turn on), but the ballast power supply board exploded and blew one of the main supply tracks off the PCB!
I think it's probably the ballast which is faulty.... Inside the ballast is simply a transformer. One side of the main lamp supply connects directly to one of the lamp connector outputs, the other lamp output connects to a winding on the transformer, so only one of the lamp outputs goes through the transformer...
There is also a smaller PCB inside the ballast which holds the ignition voltage generator parts. This consists of a smaller transformer (with lots of small windings to generate a high voltage), a 3000v spark gap (like you find in telephone ringer sockets, a 6Kv capacitor, and a diode.
This ignitor board is controlled separately to the main lamp supply, and looks like it generates around 5000 volts to trigger the lamp. The ouput of the igniter board connects to a secondary winding the larger lamp transformer.
I think the problem with this ballast is a shorted winding inside the larger transformer. This could mean that the ignitor board inside the ballast is wired almost directly to the main lamp supply, this would explain the exploded track and the previously blown power transistors!
I can't be sure that it's not just the lamp that's faulty, but it doesn't test as being shorted, so I might take the ballast transformer apart to see how many windings it uses etc. and maybe I'll be able to make another transformer, or just get one made.
The projector did try to ignite the lamp a few times before it blew up (you could see the small flash inside the lamp). The lamp even ignited at one point, but the output was extremely dim.
I might not get this ballast or power supply working again, but this is a rare chance to see how the hell these things operate. I can fix most main parts of the power supplies, but I'm still learning about the lamp parts.
Hope this might help someone, if anyone wants more information, I can post a few pictures of the power supply, the ballast internals, and a (very) rough circuit diagram of the ballast.
Please note: I still don't know how many windings the ballast transformer has yet, or what the main supply voltage is!
OzOnE_2k3.
