Which product should I be looking at.
I built these speaks this summer and an now thinking about including an amp and DSP in each cab. I get very confused looking at the products on the site. Does MiniDSP make something like what I am looking for?
You're using a horn driver for the tweeter, so you might want to take a look at the Hypex UcD32MP that Hypex is selling the last of stocks for. You'll need to make a cabinet and do a little assembly.
These modules go for €50, including PSU for a 2x30W module. You'll need a regulator and an unbalanced to balanced input buffer (from Ebay) for it.
Then you can add two UcD180 modules and a SMPS400A180 for the woofers. Use Neutrik Speakon plugs on the amp and speakers, so you do everything in one caple - saves you from connection mistakes if you move stuff around...
Johan-Kr
