Yet another ESL57 rebuild
Joined 2017
Joined 2017
I need to find a good material for dustcovers. Thin, not so much stretch and crimp ability and durable... any suggestions what to look for?
Joined 2017
This is new developed PCBs for audio transformer. One for upgrading old transformers to use over 15W and also new protection boards for treble panels. Both PCBs fit in existing screw-holes.
Joined 2017
Did some panels yesterday evening. This suckers take a lot of my time. Need to replace the trough-hole plinth/turret boards with new ones sins the old ones broke. Found some ceramic ones I will fit
Joined 2017
First sample of real handmade spiderleggs with same shape as orginal sides. Absolutely stunning quality. Just bolt on. Adjust listening vertical angle with center back-leg screw. Sins they are higher than orginal they are little less tilted but fully adjustable with back leg screw. Can be completely vertical and also fully tilted.
I have an fine carpenter by my close related. And we have a nice cooperation about this.
Reactions: 1 user
Joined 2016
These looks gorgeous! I have only legs made out of mdf sheets cut out, but painted to match the overall theme of the speaker.
Reactions: 1 user
Joined 2017
Did some work with EHT units yesterday. Melted wax and new diodes inserted.
Joined 2005
The parts in the EHT do have their own sonic signatures.
I decided to roll my own. Check out my adventure here; the Gerber file is included.
Reactions: 1 user
Joined 2002
I am skeptical that the power supply caps would make any difference due to the long time constant for charging the panels. But I'm willing to entertain that idea vs on the 63's where there is an air-gap between the HV supply and the panels.
Sheldon
Reactions: 1 users
Joined 2017
Sheldon
Agree with you Sheldon. I dont think it will do any difference sins if you unpower the panels they play with full power for a while...
Joined 2017
I have done some more job on a friends ESLs. They do really perform well now. Not needed to open the cells this time.
Top
