What is Gain Structure?
Gain structure (AKA Gain Staging) is a concept that gets talked about a lot in pro audio, but most home audio folks have never heard of it. Understanding gain structure can help you get the cleanest signal possible out of your system and avoid some nasty things. Things like noise and clipping,...
Pano
All you need to do is find or design a system that goes as loud as you want, and then a bit more (headroom), then optimize the gain throughout. The volume control is your friend. You just don't want to be stuck at the bottom of its range all the time, or overdrive some of the components while under-driving some others. It's about balance.
