my projects:
Posted 22nd November 2009 at 03:20 AM by Bigun
Head Amp: https://www.diyaudio.com/forums/aksa/...phone-amp.html
Speaker: https://www.diyaudio.com/forums/showt...ght=Moon+onken
Sub: https://www.diyaudio.com/forums/showt...hreadid=140069
TGM Amp: https://www.diyaudio.com/forums/showt...ight=amplifier
Harry77 Amp:https://www.diyaudio.com/forums/solid...arry-77-a.html
Total Comments 10
Comments
Posted 22nd November 2009 at 06:36 AM by Jason -
OOps, try again:
Full Range Speaker: https://www.diyaudio.com/forums/full-...oon-onken.html
Sub Woofer: https://www.diyaudio.com/forums/subwo...2x-trio8s.html
TGM1 Amp: https://www.diyaudio.com/forums/solid...amplifier.html
TGM2 Amp: https://www.diyaudio.com/forums/solid...amplifier.html
Harry77 Amp: https://www.diyaudio.com/forums/solid...arry-77-a.html
Triode Hybrid: https://www.diyaudio.com/forums/tubes...back-pair.htmlPosted 17th January 2010 at 03:43 AM by Bigun -
Posted 30th January 2010 at 11:25 PM by Bigun -
FET-Triode CFP:https://www.diyaudio.com/forums/tubes...back-pair.html
Posted 8th February 2010 at 02:34 PM by Bigun -
Posted 23rd May 2010 at 09:08 PM by Bigun -
Class A/G: https://www.diyaudio.com/forums/solid...-classa-g.html
Tranformer Amplifier: https://www.diyaudio.com/forums/solid...iece-wire.html
Push or Pull speaker?: https://www.diyaudio.com/forums/subwo...push-pull.html
V8 Fonken: https://www.diyaudio.com/forums/full-...en-design.html
My invention of non-switching CFP: https://www.diyaudio.com/forums/solid...fp-output.htmlPosted 7th June 2010 at 03:44 AM by Bigun -
LTP with Aleph current source: https://www.diyaudio.com/forums/solid...aleph-ccs.html
Amp with bootstrap Class A + Class AB: https://www.diyaudio.com/forums/solid...ed-classa.html
my CELLINI amp: https://www.diyaudio.com/forums/tubes...ml#post2204733Posted 7th June 2010 at 03:51 AM by Bigun -
SS emulates tube amp: https://www.diyaudio.com/forums/solid...oes-tubey.html
Posted 1st October 2010 at 02:03 AM by Bigun -
Apollo OB speaker: https://www.diyaudio.com/forums/full-...apollo-ob.html
tube + Krill: https://www.diyaudio.com/forums/tubes...-2-hybrid.htmlPosted 7th October 2010 at 01:16 AM by Bigun -
mister, is there any one build harry77 ampli?
Posted 8th March 2015 at 12:17 PM by spongeman
