Reference TDA1541A DAC Modules
Posted 14th June 2013 at 10:51 AM by dvb projekt
Updated 27th September 2013 at 01:27 PM by dvb projekt
TDA1541A DAC Module
![Click the image to open in full size.](https://img6.imageshack.us/img6/1506/tda1541amodule001.jpg)
![Click the image to open in full size.](https://img843.imageshack.us/img843/876/27893950.jpg)
- separate TL431 Shunt regulators for each voltage line
- independent voltage rail for the DEM reclock circuit
- I2S attenuator circuit
- shortest possible position for decoupling caps
- separate ground line for decoupling caps
- Ground plane
- 2mm pcb
- Immersion Gold
- green soldermask on both side
- 35µm copper weight
- Board size 125mm x 125mm
in Stock
The price is:
TDA1541A DAC Module: $9
Worldwide shipping: $ 9
Europe shipping: $ 5
paypal fee: 3,9%
Shipping insurance on buyers request!
The Ultra High Speed Buffer Module will be shipped "ready to use",
with three NC7SZ125 chips soldered.
Description
Most I2S converter typical supply voltage equals 3.3V.
The I2S attenuators from ecdesigns i am using on my DAC module, are designed for 5V TTL levels only.
So we need the buffer between the output of these 3.3V devices and the input of my DAC module
for a proper work, without canceling the advantages of the I2S attenuators.
![Click the image to open in full size.](https://img406.imageshack.us/img406/1724/sam0257q.jpg)
- 2mm pcb
- Immersion Gold
- Board size 50mm x 42mm
in Stock
The price for it is $11
Worldwide shipping: $ 4
paypal fee: 3,9%
The I2S switch module (e.g. USB & SPDIF).
![Click the image to open in full size.](https://img857.imageshack.us/img857/8918/sam0321h.jpg)
- separate relays for each I2S signal to get the maximum HF-Isolation
- based on the Takamisawa NA-5WK relay, witch has minimal HF-Insertion loss
- 2mm pcb
- Immersion Gold
- Board size 45mm x 35mm
Following parts are needed:
3* NA5W-K Relays / Mouser Part No.: 817-NA-5W-K
1* 8-Pin Header Connector
1* 4-Pin Header Connector
1* 3-Pin Header Connector
Pitch: 2,54mm / Pin diameter max. 0,8mm
Sold out
The price for it is $8
(naked module as on the right side on the photo)
paypal fee: 3,9%
- Ground plane
- 2mm pcb
- Immersion Gold
in Stock
The price is:
paypal fee: 3,9%
Description
- 2mm pcb
- Immersion Gold
in Stock
paypal fee: 3,9%
- 2mm pcb
- Immersion Gold
Sold out
paypal fee: 3,9%
