TDA1541A DAC Module V3.0 - Out of production
Posted 20th August 2011 at 08:32 AM by dvb projekt
Updated 30th November 2016 at 10:25 AM by dvb projekt
The Red Baron
aka TDA1541A DAC V3.0
![Click the image to open in full size.](https://c6.staticflickr.com/3/2843/9055599445_eb311c22a7_b.jpg)
The evolution brings the following changes
- Direct shunt voltage inputs with shortest onboard traces
- I2S In-/Outputs with shortest onboard traces
- Upgrades DEM Synchronizer
- Onboard Grounded-Gate MOSFET Current Buffer I/V Stage
(-ecdesigns- MK7 version)
- Compacter design
Still on the module
- Separate GND-Trace for DEM-Synchroinizer
- Master/Slave connectors for parallel DAC module usage
and external I/V Buffer stages e.g.
Tube-I-zator & DDNF Stage
- Groundplane
- no SMD Design
![Click the image to open in full size.](https://c3.staticflickr.com/6/5344/31188842482_0a76764a94_b.jpg)
The PCB has the following data:
Material: FR4 - 2mm
Layers: 2
Board size: 125x73 mm
Surface finish: Immersion Gold
Copper weight: 35µm
Soldermask: Both sides - red
Silkscreen: Legend on top
Out of production
- Compacter design
Still on the module
- Groundplane
- no SMD Design
Material: FR4 - 2mm
Layers: 2
Copper weight: 35µm
Out of production
