First Watt F5 Amp build
Posted 27th January 2012 at 02:53 PM by dvb projekt
Updated 13th November 2015 at 10:32 AM by dvb projekt (New photo source)
After reading so much over this amp, i will start a new project for my Hornspeaker
Letīs see if the F5 can play in the same league as my 300B monoīs
The parts
![Click the image to open in full size.](https://farm6.staticflickr.com/5346/9024789531_7b5dc1e047_b.jpg)
Schaffner FN 2070 - 3A multistage EMI Filter
![Click the image to open in full size.](https://farm8.staticflickr.com/7341/9024791733_ae18599d6e_b.jpg)
Antek AS-4218 - 400VA transformer
![Click the image to open in full size.](https://farm8.staticflickr.com/7385/9027011364_af699815b6_b.jpg)
SST03 Softstart module from Sjostrom Audio
Design without extra transformer
![Click the image to open in full size.](https://farm3.staticflickr.com/2838/9024787625_8f716f2a77_b.jpg)
RFB03 rectifier bridge from Sjostrom Audio
![Click the image to open in full size.](https://farm8.staticflickr.com/7298/9024788583_81d70a3442_b.jpg)
with IXYS DPG 60 C 200 HB HiPerFRED diodes
![Click the image to open in full size.](https://farm8.staticflickr.com/7346/9024783429_bcce7ec111_b.jpg)
PSU with Mundorf 22.000ĩF/40V M-Lytic AG caps
and Mills MRA05 resistors
![Click the image to open in full size.](https://farm4.staticflickr.com/3725/9024793953_4ee43b0f40_b.jpg)
![Click the image to open in full size.](https://farm9.staticflickr.com/8133/9027019014_31473c9049_b.jpg)
diyaudio amp pcb with
PRP PR9372 & Mills MRA05 resistors
For R9, R13 & R14 witch are in the signal line, i choose Texas Components TX2575 resistors.
For P1 & P2 i choose Vishay 1240 bulk metal foil pots, ordered also at Texas Components.
Here is the design for the 3U front and back
![Click the image to open in full size.](https://farm3.staticflickr.com/2880/9024800383_7ff47eb58c_b.jpg)
![Click the image to open in full size.](https://farm3.staticflickr.com/2885/9027025470_0efe61e35b_b.jpg)
The mechanical work
![Click the image to open in full size.](https://farm6.staticflickr.com/5337/9024795007_74ddc365af_b.jpg)
The transformer, rectifier bridges, soft start module and EMI Filter are on their places
![Click the image to open in full size.](https://farm4.staticflickr.com/3760/9027022126_5fbca545e1_b.jpg)
Just a quick look with the psu in the 2nd floor
![Click the image to open in full size.](https://farm4.staticflickr.com/3780/9027024596_cc6d32659e_b.jpg)
Starting internal cabling with Kimber TCX cable for the PSU.
![Click the image to open in full size.](https://farm3.staticflickr.com/2805/9027023138_1b25a7d9f9_b.jpg)
Fitting test on the heatsink
![Click the image to open in full size.](https://farm6.staticflickr.com/5452/9027027110_170ca072ea_b.jpg)
The back panel with WBT & Furutech looks cool...
![Click the image to open in full size.](https://farm8.staticflickr.com/7326/9027053450_e5e3285251_b.jpg)
Cabling completed !
Audio Cable: Kimber PBJ
Speaker Cable: Kimber 4TC
Mains cable: Supra LoRad
![Click the image to open in full size.](https://farm6.staticflickr.com/5347/9024828903_8db857fbf1_b.jpg)
![Click the image to open in full size.](https://farm4.staticflickr.com/3792/9024826793_c4635f5176_b.jpg)
Bias setting for the 1st channel
![Click the image to open in full size.](https://farm3.staticflickr.com/2820/9027055798_faf1d53fea_b.jpg)
Finished internal overview
![Click the image to open in full size.](https://farm4.staticflickr.com/3822/9024830929_67988ec474_b.jpg)
Now itīs time to burn in...
The parts
The mechanical work
Cabling completed !
Total Comments 15
Comments
And once again you beat me to it.... I am planning (already for some months) to build an F5 as well. Actually I have decided to wait for F5Turbo as I don't have such sensitive speakers....
What made you decide to go F5 instead of F4 (I remember you have a B1 as preamp?) ?Posted 30th January 2012 at 09:59 AM by studiostevus -
Thatīs correct. I have a DCB1 hot rodded in my rig.
If the F5 doesnīt beat my 300B monoīs, i will use him for my next project, the Auridux.
Itīs a direct coupled Tube Amp for my Stax SR-404 Ltd. headphone and here i need some voltage gain
The pcb is ready for month on my Harddisk:
Posted 30th January 2012 at 10:35 AM by dvb projekt
Updated 30th January 2012 at 10:42 AM by dvb projekt -
Awesome
Fantastic buiding quality !!
Congrats...
Where do you get the round illuminated switch ??
Thanks.Posted 25th May 2012 at 09:17 PM by ct1agi -
Awesome
Iīve ordered the switch at Conrad Electronics.
Best regards,
OliverPosted 6th July 2012 at 11:08 AM by dvb projekt -
Posted 14th October 2012 at 03:39 PM by wlowes -
You are an artisan!
The F5 is a absolute wonderful sounding amp. Fast, extreme clear and natural in every way.
In my rig the 300Bīs points with their miracle mellow midrange presentation.
Posted 20th October 2012 at 09:19 AM by dvb projekt -
Beautiful looking amp ! What size are your heatsinks ?
Posted 22nd January 2013 at 06:29 AM by thor61 -
Hi thor61,
thanks for your comment!
The two heatsinks per side are 20x12mm, so 40x12mm complete.
You could find the case in the modushop online store Part No: 1NPDA03400B.
Posted 22nd January 2013 at 08:10 AM by dvb projekt -
Hi there - I notice you are using the Sjostrom rectifiers. What is the PSU PCB you are using? I would like to achieve a similar layout in the F5 I am building with the 2-level design
Thanks, lhalhaPosted 2nd June 2013 at 06:51 AM by lhalha -
Please lookif it has still the same GND layout failure!
OliverPosted 11th June 2013 at 05:47 PM by dvb projekt -
Wow, this F5 looks really good !
Also very well chosen components.
I have the same 3U enclosure like you and would like to pimp up the looks, cause I now have a 'blind' frontpanel.
Would you be so kind to share the backside and frontpanel .dwg or .fpd files?Posted 8th January 2014 at 09:15 AM by WalterW -
thatīs no problem. I have attached the files for downloading!
Posted 8th January 2014 at 08:18 PM by dvb projekt -
Thanks !!!!!! Schaeffer-AG will soon have some work to do
Posted 14th January 2014 at 06:16 PM by WalterW -
im looking into buiding one, getting the right parts is such a hassle, is there a reputable shop online that sells a kit?
Posted 23rd June 2015 at 06:21 PM by Dadbeh -
Nice build! I like your pedantic approach. German craftsmanship.
But, however you didn't note what grade JFETs you used.
Also is it really necessary to use TX2575 resistors and Vishay 1240 foil pots? How much difference makes it?Posted 24th November 2015 at 06:06 PM by Insanoff
