Version of my blog in English
Description and links to my russian language blog and google translating
"Nazar`s regulator", variants
Posted 6th September 2015 at 07:59 PM by Nazar_lv
A couple of variants of this ideal regulator for audio applications.
Ideal because:
1. Stable and small output impedance in the 20-20k area and above (for 2x trans. version ~ 0.05ohm and ~0.005ohm for 3x trans. version).
2. Load current flows locally through the regulator`s output transistor only.
3. Excellent step response.
4. Little capacity electrolytic cap on regulator output or no electrolytic capacitor at all.
Also
5. High PSRR (for 2x trans. version 100db and 120db for 3x trans. version).
6. Noise < 1u (20-20000hz).
7. Simple and reliable.
In addition to the classical 2x transistor "nazar`s regulator" also described 3x transistor version characterized by much better output impedance and PSRR.
Also described a filter/voltage follower that makes better use of supply voltage (Uout = Uin-0.7V) and have a higher efficiency. This is possible thanks to the fact that the majority of audio schemes don't need stable voltage psu.
Simulation results of the output impedance, PSRR and step response for LM317, 2x transistor "nazar`s regulator", 3x transistor "nazar`s regulator", filter/voltage follower and LT1761 are attached below.
Green graphs are for LM317, red for 2x transistor "nazar`s regulator", cyan for 3x transistor "nazar`s regulator", blue for filter/voltage follower, magenta for LT1761.
S-Audio Systems - "Nazar`s regulator", variants
Ideal because:
Also
Total Comments 0
