LME49810 300 W amp kit from TaoBao (Test)
Posted 5th September 2011 at 10:17 PM by panson_hk
The board is ready for test. The bias level is adjusted via monitoring the THD level as well as the distortion residual.
THD vs power for 20 Hz, 1 k and 20 k for 8 Ohm are shown in the figure. It is so high compared to all my 498xx amps. For 1 k, we should have THD lower than 0.0008 %.
Let test the THD vs power without load. Without load connected, output stage contributes very little distortion. This can be used to check whether the 49810 functions as spec or not.
Total Comments 0
