Greetings Audio Junkies! I come in peace!
Hey everyone,
I grew up installing car stereos in the late 90's building custom enclosures, going to sound comps, car shows, etc. I've been out of it for a long long time but with a recent newer car purchase, I find myself hating the "premium sound system". So here I am to speak to other car audio enthusiasts, and get ideas on how to perfect a very complicated stock system. I also love reading posts on the latest and greatest home audio and studio audio equipment.
- Jeremy
Reactions: AdamThorne
planet10-hifi miniOnken Plan-Set Subscriptions
____________________________________
(last revised 27-july-2022)
Advanced & comprehensive miniOnken plan-sets for the Mark Audio & for the new Fostex FFxx5wk are/will be available for a subscription fee. Not all are as complete as i'd like (and even those that are will keep growing) and some have grown so fast they need reorganization (so please excuse that).
Available for the [CHR70 (all)/CHP70.2/CHBW70], Alpair 6.x, Alpair 7.x, [EL70/Pluvia Seven/CHP70.1], A10x, A12/12p, A12pw & Fostex FF85wk, FF105wk (which includes a set of mods to use FE103 SOL), FF125wk. Some FF165wk plans exist (same as A10p enclosures (with adjustments) so more can be quickly done) FF225wk under development (based on same enclosures as Alpair 12pw).
Rectanguar & trapezoid miniOnkens with vents on the side, simplier Classic Golden Ratio, and Compact Floorstanders are included in the plansets where appropriate. Custom designs done to cover client needs are also included. Other variations for wall mounting, more centres, and dedicated mid-tweeter use. And more. Included are details (where appropriate), cut-plan suggestions, tips, visualizations, and other information wher eit is useful.
Many enclosures have been standardized, with vent & driver details changing as needed. For example there are 6 widths of trapezoids (so far) with height changing to accomodate different volumes.
Plans are not a 1-shot deal, but a subscription (except for the Monster miniOnkens). I am always adding to them, and doing updates for specific clients (ie if you have available material that is not a thickness i have already done drawings for, i will generate plans for that thickness, or if you need a variation of a box to fit a specific need). Plans are also updated as questions & suggestions come in. There is much work to do, but any specific client needs will be taken to the top of the queue.
CAD plans for specific pdf pages can be provided on request.
Plans will be revised as needed for when drivers are revised.
Plans based on Mark Audio drivers are $25 USD each for EL70/P7, CHR/CHP/CHBW, A6x, A7x, for A10x, for A12x, A12pw. A subscription to the entire series is $80.
Plans are $25 USD each for FF85wk, FF105wk, FF125wk, FF165wk ar ein place & FF225wk is under development and will be the same price, A subscription to the entire series will be $80.
Tandband W8-1772 $25
HiEnd miniOnken plans for Lowther PM6A/C, Voxativ AC1.6, Tannoy HPD 385 are $50
Condensed plans (single drawings in most cases) for the Monster miniOnken series $10USD:
for Goodmans Axiom 201, Diatone 810 II, Dayton PS180/220 , Eminenence 12LTA, Tandband W8-1808, Tannoy Gold 12", Tannoy 385, Audio Nirvana 10 Cast Frame, Audio Nirvana 10 Neo, Airborne 6.5
Sealed box for ScanSpeak 32w-4878T $25
Canadian clients add appropriate GST/HST.
Plan-sets for other drivers will be done as appropriate drivers (ones we like and think are good value) come along.
The 1st paid planset was going to be for the Fonken with FE127, but the discontinuation of the driver stalled that one. That planset, as far as it got, is available on request for free.
dave
µMar-KenSET build
Hi folks,
I'm planning a small new pair of speakers for my desk.
The design of the “µMar-KenSET” appeals to me (size / appearance) and also the driver used.
Can anyone tell me where the F3 is, the bass is sufficient for desktop use and whether the cabinet would also be suitable for coupling a tweeter from approx. 1000hz?
As I'm new to the forum I can't write to anyone directly yet, maybe planet10 is reading along and could get in touch with me regarding the construction plan.
Best regards 🙂
PO89ZB, an inline DC filter for SMPS wall warts. Preamps, HPA, Korg NuTube, etc
Quite a few recent line-level projects here on diyAudio, are using Switch Mode Power Supply ("SMPS") wall warts to convert mains AC into the DC needed by audio circuitry. To name a few recent examples, the Starving Student II headphone amp, the First Watt H2 effects box, the B1 Korg NuTube preamp, and the Amp Camp Preamp+ (with headphone amp) are all powered by external SMPS warts. It's definitely a trend.
However, the 50-350 kilohertz switching circuitry inside SMPS modules, does make some members nervous. These folks are very concerned that high frequency noise on the DC supply, could compromise the sound quality of audio circuits. They desire a DC supply having very little high frequency noise, or, ideally, none.
I felt that, IF these pieces of audio gear could tolerate an additional 100 - 150 milliohms of resistance in series with their DC power supply, THEN we can build passive filter circuits to eliminate much of the SMPS high frequency noise. Admittedly I only studied their designs briefly, but I did come to the conclusion that all of SS-II, H2gen, B1Korg, and ACP+ can indeed tolerate an extra 0.15 ohms in series with the DC supply. So why not build a filter with a little extra series resistance, and see what happens.
After some experimental tinkering, the circuit schematic in Figure 1 took shape. It has two stages of LC filtering, built 100% with through-hole components for easy soldering. Noise attenuation at 50 kHz is about 40dB (i.e. 100x); while at 200 kHz, noise attenuation is about 65dB (1700x). Input to output DC resistance is about 100 milliohms on the PCB. Then we need to add the resistance of external wiring (about 16 milliohms per foot for AWG-22).
The filter circuit is laid out on a small PCB, 35mm by 40 mm (Figure 2). After stuffing, soldering, and attaching I/O connectors using blue and white "fly wires", the PCB looks like Figure 3. The first prototype unit was mounted inside a half size Altoids (breath mint) tin, using Kapton tape to electrically insulate the metal box from the rear face of the PCB. Then a piece of double sided foam tape keeps the PCB firmly attached in place. See Figure 4.
After the board is seated inside the enclosure and the I/O wires are pulled into their final position, two generous dollops of hot-glue are applied where the wires pass through holes in the enclosure. The glue keeps the wires fixed in place, and reduces the chances of abrading or scraping off the insulation.
When ordering the PCBoards, I told the fab to build them extra-thin: 0.6mm. This didn't cost extra money, and it seems not to have slowed the order's speedy progress through the fab. Figure 5 is an ungainly attempt to show just how slender the boards truly are. After all, the thinner the PCB, the smaller an enclosure it can fit into. Since it costs nothing to build extra-thin boards, why on earth not?
With this PCB and these components, the design limits are 48 volts maximum and 3 amperes maximum. You shouldn't exceed 48V, no matter what the current. And you also shouldn't exceed 3A, no matter what the voltage.
Speaking of components, here is a Parts List. It's plain ordinary text holding comma separated values. You can copy and paste it into a file on your computer, and then MacGyver the data into any format you wish. Surprisingly, there is even a Wikipedia article about MacGyver.
PARTS LIST
Code:
2.1mm x 5.5mm male plug,xyz,490-PP3-002AH
2.5mm x 5.5mm male plug,xyz,490-PP3-002B
2.1mm x 5.5mm female jack,xyz,490-PR-002A
2.5mm x 5.5mm female jack,xyz,490-PR-002B
470 uF 50V capacitor,LS 5mm and Diam 10mm,80-ESH477M050AH4AA
2.2uH 7.5A 0.10R inductor,LS 5mm and Diam 9mm,652-RLB0912-2R2ML
68V unidir TVS 600W,DO-204 pkg,576-TP6KE68A
953ohm 1% 0.25W res,xyz,603-MFR-25FBF52-953R
0.04R 5% 1W current sense res,LS 12mm,66-OAR1R040JLF
A quick note on DC barrel connector plugs and jacks: the individual parts sold by Mouser and DigiKey, have unusually small solder-lugs to connect external wires. That's because these parts include a removable, screw-on housing which takes up valuable space. {Unlike high volume wall warts, whose plugs are simply molded plastic} So the Mouser/DigiKey plugs and jacks only accept smaller diameter (lower current!) wires. Tinker with them and decide whether you find them acceptable. If not, you can buy thick 2.1x5.5mm (and/or 2.5x5.5mm) extension cables, then cut each end to 15 cm length. Amazon also carries individual cables with quite hefty (AWG-18!) wires attached to plugs or jacks. Here is an example to start your search adventure (the first link) But honestly, there's a fantastic implementation in post #935 of this thread that is worth considering.
This filter circuit includes polarized (electrolytic) capacitors and a unidirectional diode. Thus it only works correctly when the input is positive with respect to ground. Most SMPS wall warts are arranged this way, with the center terminal of the barrel jack "Positive" and the outer ring of the barrel jack "Negative". However, a few pieces of audio gear {I'm looking at YOU, pioneer batch B1 Korg NuTube preamp!} have chosen to make the center terminal Negative and the outer ring Positive. For those weird situations, be VERY VERY careful to route the IN, OUT, and GND terminals of the SMPS filter PCB, to the correct pins of the barrel jack and barrel plug.
Ingenious builders, I am confident, will dream up amazingly clever ways to mount and package these PCBs -- in astonishing configurations that bear no resemblance to a pedestrian candy box. The nicest thing you can say about half-size Altoids tins is probably, "they are both cheap and easy to obtain." Innovative, talented people will do better, astoundingly better I'm sure. edit- and my prediction came true, see post #935 of this thread. Thus I request that you disregard half-size Altoid tins and please DO NOT CLICK the following link (the second link)
The unique identifier for this board is "PO89ZB" followed by "-A" indicating revision A. I've put that identifier into the thread title, for easier searching in future months or years.
Gerber files for the rev-A PCB are attached; anyone can send these files off to a PCB fab, and get as many boards built as they like, with my blessings and good wishes. Please consider giving away or selling any excess boards that you've accumulated, to other members of diyAudio.
HOWEVER, rev-A does not include mounting holes on the PCB. Member carsten.witt has modified the Gerbers to create a PCB which does include mounting holes. These Gerbers were used to build the boards & kits sold by the diyAudio Store. Please visit post #407 of this thread (here is a LINK) to download Gerbers WITH mounting holes.
_
  • PO89ZB_A_Gerber_Files_SMPS_Inline_Filter.zip
Optimation PA-250AC Lab-Grade Audio Amplifier
Hello everybody!
I was recently given this amplifier, an Optimation PA-250AC, and I would like to know if any of you all know anything about it. As far as I can tell, it is NOS, or near NOS. It even came in its original shipping box! I also have all the tubes for it and the manual. First of all, this thing is a monster and weighs in somewhere around 90 pounds. According to the manual, it is a lab-grade audio amplifier, capable of delivering 250 watts at 0.01% THD! At reduced power, the frequency response is 5 to 100,000 Hz. It takes 8 EL34/6CA7s on the output stage. It also has 3 impedance outputs, 3.75, 15, and 60 ohms. It's also capable of delivering a constant-current or constant-voltage output, and the meter can measure the output voltage, output current, or the plate current of each individual output tube. It uses both negative and positive feedback to keep distortion to a minimum, and even has overload protection. Overall, it sounds like a pretty amazing amp. Also, the front panel is hinged so you can easily access the circuitry. I know tube amplifiers pretty well, but this thing is far more advanced than anything I'm familiar with.
I've included a few pictures of this beast that I took before I installed the power tubes and played with it. First of all, it sounds incredible! It goes down to 5 Hz with ease, and it has power to spare.
If any of you know anything about this monster, or have had any experience with one or something like it, please let me know! Apparently it's pretty rare, since I couldn't really find anything about it on ol' Google, but just because something is rare doesn't mean it's worth anything.
Curtis from Boston, MA
Hi, I live in the Boston area. I have a CJ amp and an LTC Aero dac, wharfdale bookshelf speakers, and a very ancient Myriad CD-100 player, all of which I love. I am building a Tubelab SSE amp. I have all the parts and am doing final assembly and check out. I am also interested in the Nelson Pass Nutube amp, bc it represents a resarection in tube technology. I would be interested in audiophile meet-ups in the greater Boston area. Curtis
New Member Introduction
Hello. I am retired and live in the greater Boston, MA area. I started updating my stereo system (still playing vinyl) and am looking for info/advice on items such as amplifiers, phono preamps, DACs and other ancillary equipment. I began this project when I recently inherited a six-tube(?) amplifier built from a kit. Completed, I think, except for attaching the case covers. When get permission, the first question I will ask is "How long a stick should I use first time I turn it on." Thank you.
Reactions: Pano
For Sale Audio Precision System One SYS-322A Audio Analyzer + Burst Option + APIB USB Adapter
This is the Audio Precision System One SYS-322A Audio Analyzer, this is the dual domain DSP version where you can test both analogue and digital signals, as well as DSP FFT Spectrum Analysis. In addition with Burst option you can generate additional signals like Square waves.
It also come with both APIB PCI card and USB Adapter (adapter alone already cost $375) from Duke Aguiar (ex Audio Precision engineer), his USB Adapter even works on my Windows 11 PC (also tested working via Parallels Desktop (Win11) on Mac M1 Pro).
Despite its age its still a very capable equipment, Stereophile uses same model for their measurement before upgrading to Audio Presion SYS2722. Even British Loudspeaker Manufacturer ATC still uses it for their active speakers amplifier testing: .
Originally bought used directly from USA and still in working condition, convertible to 100V, 120V, 230V, 240V Mains voltage.
I'm located in Kuala Lumpur, Malaysia.
Asking for $1850 (negotiable) + shipping fee (depending on your location, I will try quote with both EMS and FEDEX shipping fee)
If you have any queries feel free to reply here or drop me a message ;-)
A better TMB Tone Stack
Hi, i don't know if this was done before but i made a improved version of the classic TMB tone stack making it a bit more versatile, this version has few tweaks to make the treble pot more useful and independent from the middle potentiometer, for example, the frecuency response isn't flat anymore when the mid is up and the rest at 0, now the treble can boost and roll off high frequencies. The middle control now attenuates ~25 dB compared to the 15 dB from the original circuit, also the bass control is more noticeable now thanks to the better frecuency separation from the rc filter.
How does it work?, is pretty simple, C1(the 470pF one) and R1(33k) are now two T high pass and low pass filters, this separates the highs and lows so the controls affect only the proper frequencies. R3 Bleeds the low frequencies
from the treble pot when its necessary, if the bass knob is up R3 is off so more lows and mids stay in.
It maybe good for mods because you keep the pots the same values, you just need to replace and add some resistors and caps.
I hope this can be useful to someone that doesn't like the original TMB stack 🙂, personally i think its more practical and sounds better but that's subjetive, if you try it any suggestions will be very appreciated.
Green : New
Blue : Old
Hello, I just burnt some resistors and some More!
30 years old guitar player here also novice electrician. I like enjoy fixing stuff but this time I need help. My amp is not in a good condition I read 33V dc on speakers.. Ouchh..
First it was only one resistor that burnt by plugging the amp, after changing it then others smoked, then I noticed the wire going to power transistor is deattached. I replaced old tip29/30c's with modern 40/41c's, 204/207 pairs with also 547/x pairs, 2n3373 changed with mj15003 but I am still hearing the buzz and It's still 33V dc at speakers... What is wrong bias? I am just tired. I double check transistors BCE, EBC all right, I don't know what to do anymore... Feeling overwhelmed.
Amp is HH vs musian 100
At first I lost that 10 R at the 48 volt supply then bias one, then 1k feedback resistor... I am open to suggestions..
SAE Mark IIICM defective resistors
I have been in the process of resurrecting my old SAE 3CM amplifier. It's been more problematic than I expected. It hadn't been fired up for 30+ years so I bought a re-cap kit and swapped out all the electrolytics before I punched the "on" switch. The re-cap job went OK, although I first had to un-do some "improvements" the previous owner had done. Like remodeling old houses, you never know what you're going to find once the studs have been exposed.
Initial testing after the re-cap job looked OK -- the driver board's idle-current measurements were good and the output voltage offsets were reasonable and could be adjusted to a few mV.
But longer-term operation revealed a problem in one of the channels. The output would limit on the negative portion of a test waveform (1KHz sine). And I also observed that the bias voltage went down, from the normal ~2.1V to about 1.85V. I suspected a problem in the Darlington VASes so started my troubleshooting by measuring the emitter resistors on the Darlington emitters (R24 & R25, see below). The 3CM uses symmetrical NPN/PNP LTPs that drive two Darlington pairs, one for the + side and one for the - side. So there were two emitter resistors to measure: and BOTH measured quite high. The schematic indicates that the resistors should be 62 ohms. The one on the + side measured over TWICE that, and the one on the - side measured about 90 ohms! That is far beyond the 5% tolerance the SM specifies for those guys.....
For a sanity check I also measured the 10 ohm resistors that are used to isolate the driver board's supply busses from the output board supplies. They were spot on.
I also measured the emitter resistors in the "good" channel and they also measured high, although not as bad as the failing side. The SM indicates that the R's are carbon film types. Visual examination didn't reveal any indication that the resistors were subjected to excessive current, and I didn't see any obvious mechanical damage.
In normal operation those 62 ohm resistors should be dissipating far less than 1/2 watt. I think they are that size so they will survive if/when a short circuit condition occurs & Q11 or Q12 turn on.
I'm puzzled why the resistor on the plus side is the worst, but the output waveform clips on the negative side. That channel initially works -- more or less -- but then starts clipping after it's warmed up. So there may be a thermal intermittent situation. My next test will be to monitor the resistances while I heat them with a hot-air gun.
The main point of this post, however, is to ask folks if they have seen a similar problem with old carbon film resistors spontaneously failing like this. If not, there's a good chance something else is going on that is over-stressing those resistors. The other thing is: if those went bad simply due to their age, it doesn't bode well for the other CF resistors in there. And there are a lot of them. Replacing all of them is not my idea of a fun time.....
Mark
PS driver board schematic below:
Kind of new to diy audio … again!
I somehow stumbled into diy again after nearly 25 years have passed since my last project. On an online market I came across a guy, who had started to build up an Nelson Pass F5T V3. The project was started together with a friend of him, who unfortunatly passed away. Because of this circumstances he didn`t want to work on this project anymore. Since I`ve been always attracted by class a amps, I decided to buy from the guy what was already there and to finish the project. By searching the internet for scematics and more information about this amp, I came across the forum and joined as a quiet reader of the threads regarding the F5T some weeks ago. As I need a good preamp too, this led me to the BA3 threads and currently supplies are coming in with the material I`ve ordered. My plan is to get everything done during winter and I`m really eager to hear the difference to the 6550 push pull tube amp I use right now. Of course I hope to get some help from all of you here if needed. 🙂 thnx in advance!
MAT02, 03 Elektor preamp schematic
Elektor has in time past published two hi-end preamps using MAT02 and MAT03 dual transistors for the differential pair using +-15volts supply; one was with a DC offset nulling preset somewhere in the negative supply line and the other was with a servo using OP77.
I have somehow lost both the Elektor issues but would like to have the schematics. I have three assembled boards of the one with the servo. I would also like to try out the easier offset nulling arrangement.
Could someone please send me a scan of the entire articles OR if someone wants to sell their copies of Elektor containing the above, I will gladly buy them.
Thanks,
Bad news for Ripole sub builders :-(
The inexpensive 12" Peerless SLS woofers work really well in Ripoles. In fact; the SLS 12 is my all-time favorite $75 woofer.
I regret to report that the Peerless SLS 12 and XLS 12 woofers are no longer available at Parts Express without a 100 quantity min-buy. I called Parts Express about this and was told that the manufacturer (Tympany) imposed the 100-qty min-buy, not Part Express. Apparently; these woofers are being phased out but I don't see any comparable replacements for them on Tympany's website.
The discontinuance of these woofers seems non-sensical to me-- rather like Logitech discontinuing their Transporter streamer.
If anyone is interested in doing a group min-buy; count me in for ten.
new here and want to share my build Jmods with Mforce subs
Hi everyone,
I am 21 years old and will finish carpentry school this year in Amsterdam. I started enjoying sound systems after going to a party of kantarion. I was pulled in to the world of sound en subwoofers. I started cooking up a plan in my head of what I wanted. I knew it needed to be bass heavy but also pleasant for the ears. In the 3 years my school takes I did multipel internships. one was at Solosound. This is an electrostatic speaker maker in the Netherlands. This is where I learned to really listen to music and what it takes to make it sound good. sadly you can not use electrostatic speakers in a club setting because of the moister that builds up from sweating people. An other internship I did was at the Fiction Factory, this is where I learned to use a 5 axis cnc.
I was talking with IVCU from kantarion about what kind of tops I wanted and my first idea was the classic X-tro. but ended up choosing the JMODS from John White. this was because I liked the idea of a meh. I still have acces to the cnc and I already used it in a prototype I made of the meh jmod. was super nice to do all the weird angels easy peasy with the saw on the cnc. so now that I choose the tops I was looking at what kind of sub/ kick bin. JW did say in the paper that a kick bin won't be needed but I am planning on mostly playing EDM so kickheavy music and what I like about kantarion is the punchiness.
I was looking into the NNNN sub that goes down to 16 hz and was like yesss infra subwoofers is what I want. After some digging I found the Mforce drivers from powersoft. I looked at them and was like what the f*ck is this. got pulled into the idea of a system that is really special. so I contacted a distributer that had them. he was super nice and gave me the email of ALL, he is working on a diy design for the mforces. Went to visit ALL this weekend and was super nice talking to him and sharing details. because I still have acces to the cnc I am planning on making multipel prototypes out of mdf for the MFORCEs. (the tapped horn of ALL, standerd EDM sub and DV sub from powersoft.) currently writing this is the car on our way back to nl with the Mforce drivers in the back. I am here on diyAudio to share my findings with everyone about the drivers and the measurements from the boxes, about the road I am taking for the system. (also get some help if I don't understand anymore.) did not choose on kick bin yet because I maybe want a 2x15 or a few singel 18s, this will all depend on how loud the big boys wil get. I will be in Milano the next few weeks for the design week, wil start building end of April. Will keep everyone updated.
Versatile Hybrid Preamp w. Power-Amp Option
Experimental Hybrid Preamp Design
By Kurtus Richter
Here is a collection of diagrams for a very versatile hybrid guitar preamp, meaning a preamp involving both solid-state and tube-type circuits in one project. The reasons for hybridization are as follows. (1) With purely analog circuitry, tube-amps sound better than solid-state amps, and which also applies to preamps. (2) Hybrid preamps allow for the mixing of a nearly pure input signal from the solid-state circuitry with a distorted signal from a tube circuit in which the tubes are deliberately overdriven. (3) Tubes have a slower slew-rate than solid-state devices; by orders of magnitude. In fact, a guitarist who plays very fast scales can exceed the slew rate of the tubes in a tube-type amp, resulting in indistinct attacks of individually picked notes, heard as a muddy sound, but solid-state devises have slew rates that cannot be exceeded. Consequently, for analog circuits (i.e., no digital processing involving modern sampling technology), one remedy is to use two kinds of amps, or two preamps; one solid-state for attack definition, and one tube-type for the tone. Hence my design for a hybrid preamp.
The block diagram above illustrates how different circuits in my Hybrid Preamp can be connected together, though other arrangements are possible. I have deliberately placed input and output jacks on each of the solid-state subcircuits, and recommend they be retained, in order to maximize versatility. This gives the user the ability to connect the different circuits as desired and insert external devices, such as stomp-boxes, between any two such circuits, though the tube circuit is self-contained, since it is a distortion circuit inspired by the Garnet Herzog unit made famous in the ‘60s and ‘70s by guitarist Randy Bachman, who used it on hits American Woman and Takin’ Care of Business.
But first I show the input preamp, which has highly user-adjustable parameters, and can also be considered a distribution amp, where one output can be a direct signal sent to the Mixer, another can go to the solid-state 5-Band Tone Control or the Booster, or both in series, and the third to the Tubes.
The table in the diagram lists the low corner frequency that can be set by switches S1 and S2, according to the user’s personal taste. For instance, for deep lows, use the 20 Hz setting, but for no lows at all use the 240 Hz or even the 400 Hz setting. The gain of the preamp can also be adjusted from 2 to 200, depending on the setting of switch S3 and the position of the Gain control. High gain, in conjunction with a sufficient setting of the input Level control allows for enough signal voltage to be sent to all three preamp outputs so there should be no trouble adequately driving subsequent circuits. Below is a 5-band active tone-control circuit, which is of my own design.
Ordinarily, 3-band tone controls work fine for the electric guitar. Yet, I designed the above 5-band control for users who want greater adjustment of the sound of the solid-state circuitry. There is also volume control on the output of the Tone Control circuit, and a Booster circuit has been provided, with its own simply tone-control, to help the signal from the 5-Band Tone Control compete with the signal from the Tube Circuit.
The 5-Band Tone Control’s frequency bands divide the audio spectrum by 5, labeled here as Bass, Lo Mid, Mid, HI Mid, and Treble. The approximate frequencies are:
Bass < 250 Hz, Lo-Mid 250 – 500 Hz, Mid 500 Hz – 2.5 kHz, Hi-Mid 2.5 kHz – 10 kHz, and Treble > 10 kHz.
But, of course, the user must set the positions of pots by ear to compensate for personal taste and how the human ear hears different frequencies.
Next up is the Booster circuit.
The booster has four controls; Input Level, Tone, Gain, and Volume. The Input Level control is needed to keep the Booster from being overdriven if it is to be used cleanly, but will also allow it to be overdriven if desired. The Tone control here only affects the highs, the Gain control adjusts the amount of boost, and the Volume control sets the circuit’s output voltage. And here are some active filters; one low-pass with a high cutoff, and one high-pass with a low cutoff. In series they form a 2-stage audio band-pass filter, to mitigate unwanted subsonics and ultrasonics generated in the other circuits. They can be used separately or in series in any order.
And we have a 4-input mixer, to mix-down as many as four different signals. And while the project is designed to provide three channels, one direct, one amplified, and one for the tube circuits, there is a fourth input to the mixer in case it’s needed.
The added mixer input is provided in the event an external splitter is used for some reason between any two stages and the user has an extra signal to be mixed with all the others. Below I show the power-supply and the pinout diagrams for the ICs used in the solid-state circuits. This supply is only for the ICs. The tubes have their own supply.
Note: A builder of this project may wish to make two or three of these supplies, each providing voltage to only two or three ICs, to keep from overtaxing a lone supply.
As said, the Tube Circuit is my version of a Herzog distortion unit. It is in fact a single-ended low-wattage guitar-amp in which the output tube is used as a preamp tube, for the purpose of overdriving it to get its distortion sound. The tube-type sub-circuits are given as follows. They must be treated collectively as one channel.
For a power-amp build to go with this preamp, consider the following resources.
A Complete Guide to Design and Build a Hi-Fi LM3886 Amplifier - Circuit Basics
Audio Amplifier Boards & Modules Amp Kits | Mojotone Amp Maker: Guitar amp kits
Amazon.com: 1 pc LM3886 Amplifier Board Power Amplifier Audio Amplifier OPA445 high
Voltage Version : Electronics
As an example, however, I copied a power-amp design below, or the builder can keep the power-amp separate from the preamp, according to personal preference.
Should anyone build this project, know that I have not built it in order to test it, so it must be considered EXPERIMENTAL CIRCUITRY all the way. Also, the builder must assume all responsibility for the outcome. I cannot be responsible for someone else building this project.
Comments welcome here, and/or send me an email. hkurtrichter@gmail.com
Getting accurate measurements in the worst measurement space
This past weekend I did a talk on how to get good measurements when you don't have somewhere good to do it.
I designed and build a small sealed reference speaker in the UK using a B&C 12NDL88
I got some measurements outside fully calibrated in half space:
I then measured it at 8.49v to account for the 3m and 1w at 8 ohm
This got me this result:
I wish I had done more sweeps and a bit slower to get it a little smoother but I was in a bit of a rush getting prepared to come over to Berlin for the Hackathon.
I also measured a duel 12" reflex box outside in half space to compare it to.
On the following graph there is one very uncalibrated measurement of the duel 12" reflex which is the purple at the top, one measurement that is the half space measurement of the duel 12 reflex (half space so +6db) then the final lower purple measurement is the corrected measurement from above with the reference box.
As you can see from the graph above it gets you very close using the reference speaker to calibrate but the space I measured it in wasn't too bad.
When I got to berlin I borrowed a 12NDL88 and rebuilt the reference box.
In the workshop I used possibly the worst space I could find to do a measurement to see what results I could get using a 12" tapped horn:
These were the uncalibrated results:
As you can see there isn't much you could do with these measurements as the room was tiny and there was a lot of reflections.
After processing the results using my outdoor half space measurement:
As you can see the measurement has been cleaned up to the point of being extremely usable, it would be possible to EQ this flat and time align it to other speakers measured in the same place.
I think after testing this with the other measurement it is very important to get the measurement environment as similar as possible, measuring indoors without the background noise and other things changing seems to work really well.
Another factor is I found a sub to measure with a similar baffle size whereas that could add some distortion to the measurement, the duel 12 reflex was cleaned up reasonably well just off by a few DB, which I think was from me rushing and not measuring it properly. I thought I had calibrated it all but in my rush it was a good 15db too high haha.
Over the next few days I will release my outdoor measurement for this box and the dimensions of the sealed box for anyone else to build. This should allow anyone to get really good measurements without needing to find a massive space outdoors.
You can do this in your living room and get to within +-1db
Also using this subtractive method will allow you to in theory use any microphone and not calibrate anything and as long as you keep it all the same between tests it will calibrate it to my measurement
Another note is I had been messing around with REW before this and forgot to reapply my mic calibration, it doesn't adjust it too much but I will try and get a better measurement of my reference box, it won't change it too much though as it is already pretty flat.
All the presented measurements have no smoothing or windowing.
Another note would be that the 12ndl88 isn't the best for this but it was a driver that I owned and someone I knew in berlin owned so we could test this.
I was given this Idea by Kyle from Neuron AV but I couldn't find his profile on here to tag
Yet another Adcom GFA-555 cry for help
So, my Adcom 555 journey started in 2015. I picked up an early rackmount version of a GFA-555 for 300.00. I had never seen one like this one, the speaker connections on the back are not the the red/black variety, but a reddish brown for both the positive and negative.
Upon receiving it, I took it to Jim Williams (Pro audio upgrades), who did his thing on the driver board, and the main PSU caps tested as good.
I hadn't used it much, but late last year, I started to use it more with some JBL 6332's. One day one side went out. I opened it up and I saw there were 4 fuses, which I carefully ordered the same type and replaced them. All was good until one day, one side would make a pop sound and then volume on that side would get really low, and then come back intermittently.
I found a local guy that took a look around, checked some values on some caps, and said he repaired "30 things" and tested another 250 things. He charged me 150.00.
I got the amp home and it sounded great! i was playing it at relatively high volume and then, POP again, signal gets low. Out of anger, and smacked the front of the amp around the power switch, and loud static, and it came back to life. Something is loose.
I have built some studio style mic preamps and a compressor back in the day, so I am not an expert, but can get around a bit. I called the guy back to see what his input was on this symptom, and I wasn't that keen on taking it back to him, and he did lift a trace while he was working and I now have an extra wire on the bottom of the board....He advised me to get a piece of wood and poke different parts of the unit to try and isolate where the loose connection is. I used a 6 inch long wooden q-tip and started poking around while audio was passing through. When i hit one of the fuse holders on one of the output boards, POP! I found the issue!
I disconnected the amp and re-flowed the solder on all four fuse holders, as well as rough them up a bit for solid connection. I also re-flowed some joints on the outputs. Felling like I really accomplished something, I decided to check the bias before I closed it up. As I was too impatient to wait for clip leads to arrive, I tried it with regular leads and while on one of the emitter resistors, it slipped and sparked, shorting to i believe either the orange or white wire pad right near the 2nd emitter resisitor. After this and before I turned it off, the driver board started to smoke just a little bit, so I immediately shut it off.
I did call another local guy, but his wait time was 6 weeks. After looking at may ADCOM troubleshooting/check out vids on you tube, and reading every thread here on Adcom 555, I have decided to tackle it myself!
When powered on the left distortion LED on the front panel stays on. I powered it down and used the multimeter to check for resistance on the output board ( not sure if it's the pos or neg side, but its the one with the green transistor at the top. There is no resistance on the Toshiba TO3's so I know that at least one of them is bad. I plan on taking this board out and removing all of the TO3's to test. One of the things bugging me on this is that the board does not have the silk screening, and the layout is close, but doesn't match the one that I have downloaded, and I have looked high and low for this board layout and cannot locate. The only one I couldn't get to was hifiengine, as they are closed for new registrations.
I would also like to address if possible the resistor that the guy moved to the bottom of the board and the wire trace.
Side note, while I was beating myself out for shorting the unit, i started to look around for another 555 locally, and found one 3 exits from me for only 280.00. I went to see and hear it, it his guy was the original owner! Unit is super clean, and is also an early version but with the red black horizontal terminals on the back. I opened this one when i got home, and it is pure untouched! so at least I have a back up if something goes south, but my hopes are to get the non functioning unit back on it's feet, and then may replace the electrolytics on the driver board, the one safety transistor that is a known possible failure point, and the filter caps on the bottom as Jim Williams did to my 1st unit.
This is a great community and I'm kind of glad I found it, as I'm starting to get the electronic bug again! Thanks to all in advance!
Reactions: Freedom666
Tweak amplifier performance for a certain power level
When tweaking an amplifier for best performance (THD / spectrum analyzer) we see that the performance is different for each power level. With my average speakers (for example Pied Pipers) the actual power needed is barely higher than 1 watt. With most music and listening conditions 100 mW will be fine. The amplifier I'm still working on (KT150 PP) will easily give 75 Watt per channel, so I have a lot of headroom (more than ever will be needed).
What is a good rule of thumb to determine on which power level to "put" the best performance, keeping in mind the speaker efficiency. At 1 Watt (as in my case)? Higher? Lower? For 1 Watt I got THD below 0.10%, so I'm already pleased with the results.
What are your experiences with this?
Regards, Gerrit
Another “what kit” thread!
As per the title, looking for options for my next build.
This will be a build for my Son so will be a pre-designed open source kit as it needs to work.
He has a “media wall” cabinet with space for his Yamaha Hs7’s either side of the TV. So requirements are -
  • Passive Crossover
  • Open source available kit
  • Max volume 15L with 220mm wide baffle
  • To be used on a Media Wall so needs to work close to the back wall (or in a book shelf)
  • Likely to be sealed or be able to be modified to have a front port (circular or slot)
  • Budget £1000 for drivers, crossover parts and hardware (wood available), UK based.
  • Will be used for a mix of TV and Music (ranges from Pop/Country to Prog Metal and Metalcore).
  • No sub at the moment so need reasonable bass
  • I would prefer something with a more dynamic sound than laid back and has a broad and deep soundstage (probably difficult in this placement).
  • Room is a UK living room so approx 12ft x 15ft and 8.5ft ceilings with listening distance approx 8-9ft firing across the short distance.
Doing a bit of research it seem that the Scanspeak Revelator 15W (all four versions) is the favourite mid woofer for this size cabinet and there are around 10+ designs out there with a wide range of tweeters. The Carmody Carrera, Gravesen Ellam (XT and Flex are open source), Ego IX, Zaph ZD5, HiquiSpeak, Klan and Ton Scan Monitor, Audio Excute Revelation Two Monitor (+mk2), Intimates (x3 different tweeters), Skaldo are just a few of the designs out there. I have costed up most of these and they come in under budget. The Ergo IX seems to be the obvious choice as it is design for near wall use.
The crossovers vary quite a bit from a first order electrical with no capacitor on the tweeter (other than a 500uF protection cap), second order, second woofer/third tweeter and a number use a zobel or notch to manage tweeter impedance or shape woofer response and a couple use a ladder delay circuit.
Others I am considering are Jef Bagby’s Revolution / Revolution mini (especially the new Textreme versions), SB Bromo and Ara TX (simplified 1st order crossover with notches).
So, has anyone got a preferred 15W design that stands out above the rest or are there other designs I should be considering?
Thanks in advance for the comments and replies.
For Sale unfinished project: mini tube amp with DC-DC step up converter
Hey! I'm selling off projects that, due to situation, I can't finish. 20 EUR + shipping from Lithuania
I have: a sturdy metal case with two sockets for 9-pin tubes, a ready-made boost converter board, a jack, and a potentiometer.
I planned to build a low-power amplifier running on low voltage (12V). I can recommend a circuit, or you can choose one yourself.
Another KT88 PP
I had questions about my amp(s) -a pair of monos- but I can tell only what I know. It is my first ever tube project and it has been "evolving" for more than 15 years. Most of what I know about tubes -together with what I don't- came out of this. If anything, I post it here as evidence of what a laboratory mouse can do provided with time and resources. 🙂
It all started from the schematic bellow which seemed very attractive for an amateur equipped only with a DMM. Still, not informative about that 6,3V going where. Go figure!
First implementation shown bellow. Very heavy, kitchen oven wiring, integrated stereo with all kind of inputs and twelve region graphic equalizer per channel. Custom made transformers by a local manufacturer.
Soon it was split in two halves with solid state omitted and these served as "guinea pig" platforms for whatever I found on the internet before I came across to diyaudio.com. In fact, I became a follower of this forum searching for solutions for this amp.
From the above to its current state, all steps were taken one by one. The picture bellow shows what stayed on. Many other things have been tried.
The final schematic is following. Admittedly, not what an engineer would do out of parts ready to deliver 35W in class AB or even 50W in class B. This is just 16W in class A.
I know exactly the difference each new part made to the sound but I'm going to keep it brief. There are some obvious modifications for reliability, like the power section negative bias circuit and the heaters DC elevation. Then the NFB was removed together with the equalization network at the original EF86 input tube. Also, for this the coupling caps to the output stage had to be increased. Sparkling gain was addressed by wiring input and output tubes in triode mode -and moving from EL34 to KT88. One of the most important changes was to replace the ECC82 with the 6N6P with tail CCS. The soundstage got its third dimension after that. The particular CCS has to deal with 140V/34mA and you can see the flimsy heatsink on the top of the pic showing the inner parts. It is floating at 140V and I've found that shunting it with a cap to ground reduced third harmonic by about 5dB.
The power supply is something one will never find in an "orthodox" schematic. Definitely, it's not going to work inside a feedback loop let alone class AB. The idea was to decouple all three stages taking advantage of the steady current consumption. For this, the input stage moved to differential double triode with tail CCS, with ECC40 chosen because it's electrically similar to the EF86 and was fitting to the same hole. Otherwise it should be 6SN7. Accordingly, the output stage was converted to class A by means of two power resistors to take B+ from 500V down to 375V. Originally meant to be a temporary test but it stayed.
PSUDII was extensively used for simulations. I was looking for low ripple and fast clean transition on load transients -if any.
Finally, tube operating points and basic measurements.
ECC40
6N6P
KT88
Distortion @1W
I ended up with a relatively colorless amp... Whenever I want the tuby sound I have to connect some solid state! 😛
Simplest OpAmp opto-compressor
A little preface: back in 2017 (8 years ago, hard to believe!), I designed this circuit. Well—"designed" might be a stretch, as it was based on the well-known and popular "optical compressor" structure using an op-amp and a photoresistor.
An audio compressor is a device that reduces the difference between loud and quiet sounds by automatically lowering the signal level when it exceeds a set threshold. This helps balance the sound, making it more even and controlled. It's called a compressor because it "compresses" the dynamic range of the audio signal.
Essentially, what I developed back then was a variation featuring a transistor buffer and an ultra-bright LED to exert more "influence" on the photoresistor.
Recently, I saw someone publish a very similar circuit (most likely based on the same source), and it inspired me to finally refine my own design.
And so, after 8 years, I finally built and tested it—and it worked right away...
The circuit is very simple. It uses a dual operational amplifier, which can be a TL072, NE5532, or any other op-amp with the same pinout. Power - bilopar +-15V
The first op-amp acts as a controlled amplifier. A photoresistor (VR1) is placed in its feedback loop—its resistance decreases as the light shining on it becomes brighter. In series with it is a potentiometer (R7), which will be mounted on the front panel and will determine the "compression" level: at high resistance, the op-amp's gain will be at its maximum. When R7 is set to 0 resistance, the gain will be entirely dependent on the signal amplitude.
The trimmer resistor (R5) is optional (that's why it's marked in blue), but if installed, it can be used to limit the maximum gain.
Additionally, you can see the input diodes marked in blue—they are also optional and primarily serve a protective function against excessive signal overload.
The second operational amplifier further amplifies the signal for the LED. After it, there is a buffer on a complementary transistor pair—this is necessary to allow the use of an ultra-bright LED. Following that, there is a diode bridge.
You may have noticed that the transistors are connected without biasing, meaning they operate in pure Class B. This is intentional. Unlike an amplifier output stage, where such a configuration would cause distortion at low amplitudes, here it establishes a threshold. In other words, until the signal reaches a certain amplitude (0.6V voltage drop across the transistor's PN junction + 0.6V drop across the diode bridge, totaling 1.2V), the compressor will not "intervene" in the signal.
After the diode bridge, there is a single smoothing capacitor (1µF). There is no dedicated soft release time control, but an additional 10µF capacitor can be connected if needed.
A few words about the optocoupler construction. It’s quite simple: take a piece of heat shrink tubing, insert an ultra-bright LED on one side and a photoresistor on the other. Then, fill it with glue—and that’s it!
The PCB has a designated spot for this component.
The tubing is essential; otherwise, ambient light will interfere with the operation!
If anyone is interested in replicating the design, I’ll prepare and share the Gerber files a bit later. Original CAD files on GitHub.
Thread on the GroupDIY forum
And of course, if you like it, we can refine and improve it in the future!
Reactions: geraldfryjr
Cambridge Audio 540A protection circuit engaging: troubleshooting
hi folks; I have an old Cambridge Audio Azur 540A amplifier which I've had for 15 or so years, and which has in the last few weeks started firing a protection system error.
I've pulled the unit out, disconnected all inputs and outputs, and put it on its own mains outlet. When I turn the unit on by selecting an input, it's likely (50% of the time) to immediately click into an error state, with the red light blinking once for a DC detected on output error. This is true whether I have speaker B selected or not. This even happens if the headphone jack is interested, which might be important (as a totally different output path, though maybe the protection circuit checks them all anyway?). Once a channel is successfully selected, the amp almost never triggers an error; it's usually only when coming out of standby.
I popped the case and, referring to this post I measured DC across J6 and J12 and their adjacent negative lines, and the numbers seemed very small (but I'll likely probe more systematically).
i'm curious to hear folks experiences or thoughts on this before I go down the rabbit hole. This amp has some sentimental value so I'd like to get it working again rather than buying new; in the past I've had to replace the relays, but otherwise the unit has caused me no problems until now!
Low voltage tube line preamp
I want to introduce you one interesting circuit. There is absolutely nothing innovational, circuit is hyper simple. But, I hope, my experience of construction building will be helpful for novices.
Tubes, used in this circuit may be 6AS6 or Russian 6Ж1П.
This tubes can work with LOW anode voltage!
In the circuit I suggest power is 12-20V DC
To use single supply, I put LM7806 voltage regulator to convert input DC to 6V for heat.
Original Article on my blog
This is very convenient because you don't need to build special power supply, you may use standard adapter (better is switching).
This was the first try. After testings, when I heared sound is really well (testing gear: Soundtech Series A mixing desc and Quested S6 monitors, signal sourse - audio interface e-mu tracker) I assembled the second version - with factory-made panels and whole better look.
Also, if anybody wants - there is video of testing.
And - certanly - inside mount.
or
For Sale P. Millett's 50W NuClassD Amplifier
Spring cleaning time!
Fully built NuClassD amp designed by Pete Millett.
I must have gotten lucky with the installed Korg Nutubes, they never gave any problems with ringing or noises.
SOLD plus shipping and PP fee.
Will ship to USA address only.
My Balanced Line Receiver
My balanced line receiver is a small PCB that adds a true balanced input to any amplifier, thus helping to avoid certain problems inherent in single ended (e.g. RCA) connections. Compared to integrated receivers such as THAT1200 series, the board offers an order of magnitude lower distortion (depending on the choice of opamps) and built-in DC removal, which makes a downstream DC blocking capacitor unnecessary.
This project is based on my prior series of volume control boards, which itself was based on Bruno Putzeys' a demo project that illustrated his article "The G-word, or how to get your audio off the Ground", first published in Linear Audio Vol.5. While the focus of those previous projects was volume control, I realized that the combination of a low-distortion balanced input and a ground sensing output is useful by itself, for example, in a monoblock or even a stereo power amplifier.
There was some interest in this receiver in the discussion of our Omicron headphone amplifier earlier this year, so in the coming days I will publish the schematic (post #6 below), measurements and other info on this little board that may be useful.
Unable to find spec sheet for 2 speakers, please help
Hello there,
I've got 2 gears where i'm not able to find any spec sheet that would help me to know how to build a gentle desktop speaker.
Does any of you know how i could find something or move forward for the box volume, etc...
  • TANNOY R71CC
  • FOSTEX FH15HQ
Thank you in advance
GB Group Buy Salas UltraFSP RIAA
After significant amounts of design and testing, we are announcing a group buy for a revised Salas Folded Simple Phono preamplifier.
The power supply has been updated for the UltraBIB type, 1.3S. The S being for Special application in supporting only higher voltages. It keeps the voltage very steady at 28-36volts, depending on gain needs.
Also, additional switch banks are provided to making gain changes much easier. This can allow with a few switch settings and voltage adjustments to change the gain signature and use a different cartridge.
The signal portion remains otherwise the same as the legacy FSP. Schematics for UltraFSP
The BOM is provided here.
UFSP BOM
There is significant cost associated with the boards, the transistors and parts for the kit. If you are a previous owner of the previous Salas FSP, you can reuse your signal transistors as needed as well as signal caps.
However, I will be offering kits as well. I realize that we are in the midst of ... supply chain problems, postal delays, lost wages and more. Please be mindful I will do my best to provide boards and parts as best as I possibly can, but substitions and other matters may come up, which I will try to communicate.
To the meat of it.
UFSP Board cost 58.00 a pair.
RAW power supply, 15.00 (shown with optional parts kit)
Minikit costs, include MSRP of mouser parts, + packing and paypal fees. 55.00
Includes matched C1 and C2, plus C2Y trimmer caps. Matched Q3 and Q7.
See BOM link above.
Big Parts Kit, including minikit - 185.00.
Big Parts kit does not include below
Full Parts Kit for RAW PS - 44.00
2SK369BL matched Pair, for high gain settings, all except low MC - 12.00 R1 included for IDSS.
2SK369BL matched Quad, for LOMC Gain settings - 26.00 R1-R2 included for IDSS. (See BOM Spreadsheet TAB for 2SK369BL)
2SK170BL - triple Pairs for Q4-Q6. Includes resistors R8 and R11 based on IDSS of Q4, Q5. 36.00
Above Jfets, one set per pair of boards sold
max.
https://docs.google.com/document/d/1ip_eB3CbCMnZqCa7Nrlpsx4D9TfRMBJnN2GqJsKhqFE/edit
iMac wireless to DAC to preamp - how?
I've searched and searched but can't really figure out how this is done.
I'd like to stream my music from an iMac to something like a Forte Audio Interface DAC (cheap as chips on eBay) which will plug into an input on my preamp..
Do I need a bluetooth device with the Forte to receive the digital music file.
Or am I just barking up the wrong tree.
(I don't want to run a cable from the iMac to the Forte due to distance. (iMac is "here" and hifi is "over there.")
Thanks for any suggestions.
Post your Analogue Source pics here
This is my bid to earn a 'sticky' thread. My first attempt at a Pre-amp. It's dual-mono throughout. The RIAA is all-BJT based off the famous NAD3020 circuit. There is an all-BJT shunt regulator based off Salas designs. And there is a cathode follower output buffer loaded on an active 'amplified resistor'. Haven't tested it yet, but this thread is for piccies 😀
simple active crossover
I am thinking about building yet another active crossover. I am debating as to either make steeper slope with feedback or just simple lower slope crossover.
Crossover will be ~150Hz as this is what I was always using so far to power mid/tweeters with classA amp and below that with classAB for woofers. Normal stuff.
I am looking for highest purity of tone, highest clarity for mid and tweeter, so less caps the better, plus I am using open baffle with natural roll off. So 6dB/oct should be plenty.
For woofers, I prefer steeper crossover. Can I just combine both types? Will there be negative consequences for phase or uneven fr response around crossover? Or should I stick to the same slope?
Btw, if you see any obvious mistakes on the schematics, please let me know, I just drew it from other active crossovers I have seen around. Thanks.
S.M.S.L. M400 (AK4499EQ) - Is there any Advantage to Replacing the small Internal Power Supply Module
Maybe this model could be an alternative to the no longer available Topping D90 equipped with AK4499
https://www.audiosciencereview.com/...ds/topping-d90-balanced-usb-dac-review.10519/
As you can see on the attached images, the very small black box contains the whole SMPS - go to image No 5.
Would it be better to replace it by an outdoor shunt regulated power supply with 50/60 Hz transformer ?
Thanks for comments.
Some URLs:
https://www.audiosciencereview.com/.../smsl-m400-balanced-usb-mqa-dac-review.13732/
https://www.pttweb.cc/bbs/Headphone/M.1634053354.A.1DF
https://ptthito.com/headphone/m-1629808628-a-ea4/
  • SMSL M400 USB DAC XLR Balanced Back Panel Inputs Outputs XLR RCA Audio Review.jpg
Maplin MosFET Amplifier GA28F construction thread
Hi
Please find a few pics of my new Maplin 100w Mosfet amplifier construction thread .. All parts are new old stock with original transistors, but all capacitors are new, just a little bit of nostalgia from the past !!
Both amps will be mono blocks ..
best regards Nick
Reactions: fschmdt65
Ath generated CD 2-way
After looking at these fancy CD waveguides for about 10 years, i finally found some time to wrap my head around mabat´s ath waveguide generator and made my own. Thank´s to sheer endluss information on this forum, i feel pretty confident that i am on the "right" track so far. After simulating probably 100s of iterations between christmas and newyears, i think i found a compromise that i am going to build.
Below you can see the current state CAD design and ABEC SPL response with enclosure. It´s supposed to be mated to an 8" fullrange, used as a Midwoofer up until 1,5kHz in this case, in a 60l BR enclosure. I want to use basotect on the inside walls to reduce mid reflections. Main design goal is to get rid of room reflections and keep as much midrange dynamics as possible. If general frequency response is within a reasonable target its a welcome bonus.
As much as i´d love to just get myself a Hypex FA (you can see it semitransparent in my drawing), i am not quite confident enough to sell my beautiful NS1000s to be able to afford those.
As of now i plan on building said enclosures, measure both drivers and use VituixCAD to design a simple crossover and take care of frequency response with DSP. I could go forward and spent another 2 weeks to setup a working Akabak simulation, but i am not sure it´ll be precise enough to get me in the ballpark, working with a CD horn in this case.
I´ve been looking into a Le Cléac`h crossover to compensate for HF driver position and increased center to center distance.
https://www.melaudia.net/zdoc/jml_crossovers_etf04.pdf
Honestly i have no idea how it is going to work out, but i might need some directions for crossover design.
Looks like i need to use a 10kHz first order lowpass to get somewhere close to a linear frequence response and attenuate efficiency to match with my woofers 90db? Is it possible to combine a first order lowpass with a 3rd order butterworth for a Le Cléac`h crossover concept? I might get some strange tweeter response below my crossover frequency i guess...
I will document further development here. As somebody building his first proper pair of diy speakers, i might need input at some point. 🙂
Reactions: vineethkumar01
LS 3/5a garage
ideas and project started two years earlier, but in April 2023 the first prototype of LS 3/5a box.
immediately after the summer the second box, the veneer with true Walnut thickness 1.4mm over 15 years old.
the prototype was born with a few millimeters more in depth than the standard BBC / Rogers specifications.
I then made others with different features, exact measurements and different aesthetic finishes.
here you go:
Reactions: GM and 6thplanet
Edmond Verrijn Stuart passed away
Friends, it is with great sadness that I have to report that member Edmond Verrijn Stuart has passed on 29th of May, at the age of 81, in his beloved Amsterdam.
Edmond was an extremely clever designer; his design of an optically coupled and regulated power amp bias system, published in then Wireless World has been a milestone in stable bias circuitry for power amps.
More recently, his DiAna software package to measure and display harmonic distortion including residuals from a soundcard measurement is used by many on this forum.
Edmond was very generous with his time and talent, always willing to help and explain, but he had no truck with people too lazy to do their own legwork.
Jan
Technics SOAD70A Laser diode Power
Hi everyone,
Have a question on the SOAD70A optics. I have looked through many of the forums and can't quite find the answer to do with what the SOAD70A laser power should be in mW. I understand that laser diodes are current dependent devices which is why setting laser power by mA is most often used, however I have a Leader Laser Power Meter and was wanting to set power of the SOAD70A using this meter.
I could calculate the power from VA but just wanted to know what power these SOAD70A units a set to. If you know the answer or have a working CD player with SOAD70 optics you can measure please let me know the power.
For Sale Biamp front ends similar to Diy FE 2022
Hello,
I have for sale some nice and shiny stuff.
This time I have a few pairs of modules that can be used as a low thd line preamp or as an low thd amplifier front end, you know to drive a follower os.
These have balanced inputs, single ended outputs and a voltage gain of ~10x which can easily be changed on each side by replacing 2 smd resistors.
You can power them with up to +/-29vdc and they draw 30ma/entire module.
Each of the two big pcbs hosts 2 preamp channels.
These channels are connected in such a way that you can use them only for biamping so half pcb amplifies the lows and half the highs or whatever being same channel, for a stereo setup 2 pcbs will be needed.
Here is how the thd looks at 2.85vrms or close to 1w/8r
And here at close to 17vrms or close to 36w/8r
Now probably you wonder what are those small pcbs, right?
Well the preamp produces a turn on thump and the small module is a relay that keeps the output shorted to gnd for a few seconds so it silences the thump.
The offer includes 2 preamp modules(4 channels) and 2 thump silencer modules.
Sold
Adcom GFA5802 pcbs and IRF244
I have for sale the amplifier pcbs from a GFA5802. One has a few burned tracks and components(resistors and a to92bjt) meanwhile the other one was working first of disassembling everything.
Both pcbs suffered numerous repairs by how they look and how the vgs of the mosfets measure. This is not my amp and I don`t know much about its past.
The pcbs are sold as they are.
This is the one with the burned components and tracks and is the left channel.
And here is the “good” one that will come exactly like the above one, without the aluminium bracket and power mosfets.
I measured the vgs of all mosfets(at 30Vds and 0.9A Id) to see if they still are ok and got the following list
3.863
3.864
3.897
3.898
3.905
3.923
3.926
3.936
3.937
3.940
3.945
3.968
3.978
3.992
4.002
4.004
4.029
4.035
4.037
4.060
4.063
4.084
4.090
4.138
4.144
4.177
4.184
4.324
4.342
4.378
The mosfets look like this
Adding also the brackets where the mosfets are mounted
Adding also the input modules
Price for everything 150€
Or trade with sits, k170/j74 jfets or j313/k2013 mosfets.
New Stasis front end
Not too long ago I received a request for some help from an owner of
an old Threshold Stasis amp, whose amp was broken and where some
previous work had left some issues with the circuit board.
As many of you will know, I have lots of time on my hands 😉 and a
sentimental desire to revise old product in light of the wisdom I have
acquired in 50 years.
So.
I revised the circuit, making it more simple, and laying out a circuit board
which should be usable for all known versions with minor adaptation.
Attached are various schematics and graphics and also the gerber files
for the circuit board, which was made my pcbway.com, who will ask
what dimensions are, which is 5.5" x 3.5"
This thread will also serve as the location for asking additional questions
and so on.
:santa2:
EDIT --
Gerbers and info for Nelson's front end that fits the old Stasis chassis and has mounting holes (post #281) - https://www.diyaudio.com/community/threads/new-stasis-front-end.363701/page-15#post-6447824
@Zen Mod made PCB for this project, information and gerbers can be found here :
Front End (post #282) - https://www.diyaudio.com/community/threads/new-stasis-front-end.363701/page-15#post-6447826
6-deep output stage (post #283) - https://www.diyaudio.com/community/threads/new-stasis-front-end.363701/page-15#post-6447831
8-deep output stage (post #284) - https://www.diyaudio.com/community/threads/new-stasis-front-end.363701/page-15#post-6447835
  • STASIS FE.ZIP
    STASIS FE.ZIP
Filing School
Did anyone here who did an engineering degree or an engineering apprenticeship ever have to endure 'filing school'? This is where students during their first year are sent to a workshop for 6 weeks to get an understanding of what it takes to get a 2" x 2" x 5" solid piece of mild steel (generally rusted and pitted) all sides square, shiny and perfect. Over 6 weeks, we made numerous useless items that served as paperweights or just went in the bin. The only tools at your disposal would be files, set squares, compasses, callipers, and nothing else. Our cohort did V slots (try filing a perfect 1.5" deep 45-degree V slot 5" long into a solid metal bar 😀 ), square grooves, half-round sides etc. I'd say this was one of the most frustrating experiences of my life (oh, the other is when my SWMBO insists she is right and I am wrong). The tutors would be walking around yelling and insulting everyone - just like the military. A few of us had our efforts hurled out the workshop door and told to start again.
Real old-school stuff.
New Member Introduction – Passionate About DIY Audio & Speaker Design
Hello DIYaudio community!
I’m Daisy, a longtime audio enthusiast and electrical engineer from Toronto, finally stepping out of the shadows after years of learning from your brilliant discussions. My journey began at 14 with a disastrous (but educational!) attempt to modify a pair of Sony bookshelf speakers—thankfully, I’ve since upgraded my skills.
Current Projects:
  • Designing a 3-way open-baffle speaker using Fane Sovereign drivers
  • Building a tube hybrid headphone amp (inspired by Pete Millett’s designs)
  • Repairing a vintage Pioneer SA-9100 I found at a garage sale
Why I’m Here:
  • To learn from your collective wisdom (especially on crossover tuning)
  • Share my SPICE simulation templates for tube circuits
  • Find collaborators for a waveguide design experiment
Question for the Group:
  1. What’s your go-to method for measuring cabinet resonances?
  2. Any favorite resources for learning horn theory?
  3. Who else thinks electrolytic capacitors are the devil’s work?
Excited to contribute to this knowledge-rich community. Feel free to roast my rookie designs—I thrive on constructive criticism!
For Sale Meter LOT
Meter LOT
LOT photo 1-5
60mm*60mm overall dimensions
47mm*47mm mount
0-5MA 23.3ohm metal screen
0-50V 5.84kom metal screen
0-50V 5.86kom metal screen
0-50V 6.86kom metal screen
0-300MA 0.4ohm metal screen
0-30V alternating current arrow deflects
0-300V 3.3mоm arrow deflects
82mm*82mm overall dimensions
65mm*65mm mount
0-100microАmp 454ohm
75mm*75mm overall dimensions
64mm*64mm mount
0-120 TV-7 meter ? 2.26kohm
Level indicator
1) 481 ohm
2) DEAD
3) DEAD
100$ US for the whole lot
LOT foto 6-7
110mm*95mm mount
0-100microAmp 750ohm
0-200microAmp 70ohm
0-300microAmp 770ohm
0-300microAmp 330ohm
0-50microAmp 2kohm
arrow does not reach the end
repair required
0-10mV 10ohm
70$ US for the whole lot
LOT foto 8-9
47mm mount
0-100microAmp 3.04kohm
small size there are 3 pieces of such meters
80mm*100mm overall dimensions
60mm*80mm mount
0-250MA 0.4ohm
66mm-67mm overall dimensions
WESTON 0-200microАmp -DEAD winding burnt
WESTON 0-500MA 0.7ohm
WESTON 0-100 1.2MA 10.8ohm
88mm overall dimensions
WESTON 0-1MA 100ohm
LOT foto 10-11
wire coils
for making precision wire resistors
and shunts for instruments
with different wire diameters
photo 10 with carbolite base
photo 11 with ceramic base
100$ US for all coils
I ask 350 USD for everything + shipping - or best offer
Payment via Paypal
Krell KSA 100mkII LT SPICE
I have ambitions to build a variation of the KSA-100 MKII clone. I have a ton of parts and things to make it happen yet I am lacking a few hundred bucks worth of items that are on order or will be ordered soon. I guess, hell or high water I am committed to it. I want to make the best of it. I have received criticism for this decision. I may have to live with it and let it take its course as all things do. In an effort to move forward I would more than nothing desire a relatively somewhat functional LT SPICE model to go along with said project.
Looking for repair/replacement for JVC planar tweeter
Hi, everyone.
I was just wondering if anyone might know of a repair, or repairer, for these JVC HSW1199-01BCS planar tweeters. Failing that, if there's a source for replacement diaphragms, I'd be very happy to try that route too, though I'm assuming they're likely to be unobtainium.
I've seen one or two listings for entire replacement tweeters, though those tend to be a) a little pricey, considering the woofers need replacing as well, and b) have had different final three characters.
misc1 has photos of the tweeter.
Any help much appreciated.
Cheers, Jon.
May he rest in peace, its a great loss Bernt/Bandsei
I just heard from a friend of my mine Bernt passed away due to cancer, and this might not be the right place for it, but it is the place he spend most of his times with incredible builds/posts/topics in AMT's and other planar magnetic drivers. and i always loved the way he worked and helped you out if you had any questions.
i still have some builds from him and will cling on to them! my heart goes out to his family and may he rest in peace !
https://www.facebook.com/bernt.lassen.1
DML PA systems
While there is a very long thread in full range regarding DML speakers, I think they are also very interesting for PA applications, and deserve their own thread since it is quite a different application then when making a pair of speakers for home use.
So here might be a good place to discuss things like what materials offer the best sensitivity, how to get maximum power density per plate, what power amplifiers are good to use with DML speakers and how do you construct a good frame and protect the exciters and plates from rain, etc.
Personally I started looking at DML speakers simply out of curiosity since they just seemed very novel in the the way they actually work as well as how they perform. Initially I hoped to get a pair of half decent home speakers at best, but quickly realised both how much I like the sound, but also how interesting the properties are for PA applications.
So why is DML interesting for PA sound?
1. SPL does not reduce as much over distance. This means a more even spread of the sound over the audience. The decay rate is more like a line array even if you have a single plate set up as a point source.
Basically if you stand on a dancefloor with plates directed to the middle from each corner, it feels like the stacks are half the distance away compare to where they actually are. It is hard to describe, and it is a weird feeling when you walk around between them.
2. The diffuse waves generated by DML really helps with acoustic issues. Not only by reducing the amount of reflections we perceive in a closed space, but also the interference between multiple speakers. It is also weird and seems to defy logic sometimes, but in combination with the previous point it means the whole dancefloor sounds like a sweet spot with both loud and clear sound.
3. Dispersion is really wide, covering a lot of area with a few speakers.
4. Good sensitivity, even when looking at the usual on axis response, and amazing total efficiency when taking the dispersion into account.
5. Low distortion even at high SPL.
6. Despite the diffuse nature of the waves emitted, spatial imaging is excellent. Even when standing very close to one speaker stack you can hear stereo effects from speakers on the other side of the dancefloor in a way that I have not experienced before.
I make a small festival each summer, and as it happens this year the guy who I usually rent from couldn't do it, so I decided to quickly try to put together a DML system since I had done enough experiments to be confident it would be viable.
I will add post in this thread describing the system I built in more detail and add some videos of it in action, but for now a quick description.
4 plates per stack, each plate made of :
1 graphite enhanced EPS plate, 500x330x25mm:
https://www.dekokopf.com/neopor-styroporplatten-3er-set-50x33x2-5cm.html
4 DAEX30HESF-4 exciters:
https://www.soundimports.eu/en/dayton-audio-daex30hesf-4.html
Frame built with wood and 3d printed corners.
I have 4 stacks, so a total of 16 plates. Each stack is driven by one of these:
https://www.china-sanway.com/D2S-2CH-900W-DSP-Built-in-Amplifier-Module-Class-D-pd353583.html
Subs was rented 4xL'Acoustics SB218.
I tried to make construction as quick and simple as possible, and think I succeeded with that, but still of course it become stressful to finish in time. I didn't have much time to tune it with the subs, and never got time to test it properly at war levels before the party, so I was nervous to say the least. The guy I rented the subs from brought tops as backup if it would seem like a flop.
We turned it on and without even tweaking the XO it just was way beyond expectation, sounding really loud and clear, and no problem to keep up with the subs, rather the other way around. Sound guy admitted he was very sceptical initially, and probably thought I was crazy not using his Kara tops instead, but admitted he was very impressed when he heard it 🙂
During the party I just got constant comments about the sound. Everyone positive, and lots of people that would never do that usually. The actual sound geeks present was over the top ecstatic 🙂 Common comments where "everywhere seems like a sweet spot", "I always have to wear earplugs, but not with this sound", "best sound I have ever heard" and "it is like listening to quality headphones but from a PA system". After a couple of days of hearing the same comments it almost went from total relief that I was not crazy and it was not a flop to it becoming a bit too much and annoying 🙂
Since it was such a resounding success I'm really surprised there hasn't been more interest in DML technology for PA applications.
One tricky aspect with DML is the patent situation. Since I do this as a private person and not for profit (my festival is also non commercial) it is not an issue, but getting started with DML commercially might not be so easy. The only commercial manufacturer of DML PA speakers are Tectonic. They seem to produce a very high quality product, but at a price level only big established rental firms can afford. However, those tend to be quite conservative and go with the products that are typically requested, and have no interest in having to sell in customers on something completely new. And Tectonic also seem to have very limited marketing and no presence outside US, and importing their product to the EU would end up very costly.
In the end, with nothing else on the market, no one hears DML systems and no one demands them from the rental firms.
So it seems to be up to DIY'ers has to build some systems and get the word around! 🙂
Anyone else doing DML for PA applications, or is interested in doing that?
From Pi 3B from a friend, I try many time with moode, volumio, picore, librelec, pios lite and then back to moode just by these reasons!
1) Moode is the easiest way that I can use mpd with integrated audio (alsa mode) why I have problem with picoreplayer because it's always put HDMI as highest priority. But moode is different, I can choose exactly my integrated audio by headphone jack in the configure/system + audio tabs. I dont use DAC because I've just give all my Speaker and now I just use my soundbar for both TV (bluetooth line in) and pi3b( 3.5mm line in). =)) Maybe I change my mind in future but now is ok with me!
2) Moode with function log to RAM to save the HDD life because I use HDD for store my music. I still using the idle function when no access HDD share for 10 min to increase my HDD life.
3) Moode is widely supported with huge of radio stations. I love it, and I can play both by my pi3b and my device with function : Play on this device.
4) I love the way of samba, dnla&upnp, http player support by moode.
There are 2 points I need the author and other members to support:
a) Skip folder with .nomedia file tag. I've get stuck (hang) the HDD event 2 days caused by my 4TB HDD with more than 16000 folders with various of data, It can not skipe the .nomedia folder and auto mount whole hdd 2.5inch as usb media. Then I must to pull all my HDDs to put in only 1 HDD just for store my music! 😉)
b) I tried to install and configure both on a docker and core system pi os lite (because I plan using pi3b for multiservice) but falsed in many time (maybe I am not enough experience to do that now) so I give up to back moode OS running on my USB. I hope I can received a strong support from all of you on this forum to make me feel happier, specially running in docker as good as real moode on a USB.
Thank for all!
Finally building my MkIIIs, a pictorial thread
Of all the Amps I've had over the years, I never had a pair of Mkiii's. And not to say anything for, or against them, for some reason I've always been curious of how they'd sound. Refurbished not as if money, or original design, were no barriers, but with respect to them. A very similar topology, well implemented. So, this is how I found them. Gotta love the single ccs phase splitter driver stage, led biased even!, 12bx7, feeding the 6550s directly 🤦‍♂️ Aside from that, and the added "heater voltage doubler" for -15v (now that ccs is working perfectly, I'm sure...) both of the amps are identical with stock iron. Couple weeks apart in '64 says the serials, so probably came from a store is what I'm thinking, as a set? I do know parts are starting to arrive, so it's time to do something with these dilapidated classics.
Yuck, what a mess under here. At least I won't have to worry about trimming the OPT secondary leads, they barely reach. Lot of extra wires for that heater based DC- supply too. If you look close, you can see that whoever made these "driver" boards was recycling them from some other board design. At least they were trying, I tell myself...
Alright now we're talking. Reduced to everything we're keeping on this one. Well, ok, maybe not Dynaco's venerable c-354. Does lamination lacquer come out of carpets if it drips? But seriously, they'll certainly find use elsewhere. And forever thank me for stopping the beating....Ok on to prep..
Ahh there we go. Every surface, every angle and hole. Used a single stage 220grit, which is more than sufficient for chassis like these, without any serious pitting problems. I don't know if you can see in first pic, but they had the chokes screwed in through the tube vent slats! This made one of them be shaped like they now all are. What a pain in the butt hand filing, but I'm glad they look as if they're supposed to be that way now 😅. Besides more ventilation is welcome on a 1.75" chassis with bottom plate (Hmm....more on that later..). I'm thinking close to stock for the transformers, and then a kind of aqua blue for the chassis.
I'll be using the Tubes4HiFi octal driver boards in these. Probably do the mod for the current source. The driver stage is going to have a fairly serious choke, but not decided yet on how much effort vs. gain with one beforehand for B+ as well, other than a beefier 1.5H. Definitely more C than stock, probably top can and underside. And, I'm going to play around with feedback to the cathodes from the OPT secondary. Another nice feature this thing came with 😅 I'll do bias meters (and t.p.?), be going with standard spacing and a switch for 4/8 and maybe 16ohm for the binding posts, and power tubes will be KT88 or 120, we'll see..
Any input is more than welcome, and I love seeing others' examples. I'll post more pics in the coming days as these take shape.
Loren
Cheap Germanium transistor amplifiers and FREE service literature for fun and learning . . .
I don't see a lot of posts on Germanium transistor amplifiers, and wanted to throw a shout out to a really cheap, fun, area ready for learning and experimentation-
I have been tinkering lately with the 12V germanium amplifiers found in extremely affordable 8-track automotive decks from the late 60's and early 70's that can be found at yard sales or on ebay for under $30 including shipping. While 8-track tape is a dismal source, don't let that turn you off- the amplifiers present a great opportunity to study vintage designs that use these early transistors. Easily restored and modified, the result can sound unique, amazing, different, whatever you are in the mood for. These really are hidden gems- because they include all of the impossible to find parts (the interstage transformers, thermistors, and matching sets of germanium pre and power transistors) all in one functional package, usually working fine even if the tape deck is dead.
These amplifiers are typically designed and built in Japan, so are often fairly high quality in a compact package- Generally stripped down to the most basic elements to save cost and area, but using high quality components. They are, however, pretty low power- With only 12-14V car battery voltage to work with, a class AB can only generate about 4-5 Watts per channel even into 4 Ohm speakers. This is not enough for full-room listening, but it is perfect for near-field listening on a desk top or bookshelf, headphone amplifier, or a little test amp.
I reworked one of these as a learning exercise into a small stand-alone amplifier that I detailed in my "Germanium Bake King" project.
You can find FREE service literature for many such auto radio designs at the World Radio History website. Just search for "SAMS" at the main site, (or see the SAMS listings directly here ) and you will find a great many volumes of the SAM's "Auto Radio Series" included there among the SAMS bookshelf. The Auto Radio Series was a long series of periodic books, each volume of which included service literature for a dozen or so various recent models. These books alone are a treasure trove of design examples worthy of study.
You can look up your desired make and model using the free SAMS Annual Index Volume 1, which covers all SAMS models from 1946 through 2001. If the SAMS number starts with "AR-", it is in one of these Auto Radio Series books and =MAY= be there for free at the World Radio History library.
Here is the eBay search string I usually use to find good cheap automotive 8-track players, ranked lowest cost first. Generally you will want to look for a deck that is 8-track only, usually an earlier looking design, the more chrome the better. 😀 It should be from the late 60's or early 70's, with a boxy rectangular "under the dash" design (Not the two-shaft through the dash design). You should see only volume, tone, and maybe balance, with no radio. Once you get into the late 70's with AM or AM/FM designs they have moved on to silicon transistors or integrated circuits- also fun, but not my focus here. If you want to be really sure, find the ones where you can see the power transistors mounted on the outside of the rear panel:
You might even be able to see a transistor number and look it up. Even if you can't see the transistors on the outside, if it's 8-track only, you stand a good chance.
Anyway, happy hunting, and please share you results or thoughts.
Choctaw - 10 Watt Amplifier, 1 Opamp + 2 MOSFET
Here I will present my new 10 Watt amplifier.
All you need to play music.
The supply is one transformer 2x12VAC.
Just you wait until I start posting the amplifier.
Here is the idea, simplified.
The opamp controls the amp.
The MOSFETs are biased to about 250mA.
The compensation of the opamp rolls off bandwidth at 200kHz.
Gain is set to 11.
The max output is like 10 Watt RMS.
Speaker build
Was given what looked like a cheap more modern Phillips stereo with two two way speakers awhile back and with my recent success with open baffle speakers decided to test these drivers to see if they would sound good.
Here's the woofer. Looks like it will be fine for open baffle
Here's the tweeter.
I had the parts I needed to connect up a two way 6dB/octave crossover and the speaker seems to sound pretty good. Bass response seems decent for the driver size.
Here's the crossover schematic
Here's the temporary mounting for the drivers.
Now these paired with a 10-20 watt stereo amp will make a nice pair of computer speakers.
The only thing I don't like is that the cone tweeter doesn't really output anything above about 12.5kHz.
I do have 90% of a box of 200 Onkyo dome tweeters I bought for $10 over 10 years ago from Parts Express which were meant for certain models of GM vehicles and they are close enough to the measured impedance of the cone tweeter to where I can connect it up to the temporary crossover to see if it's output needs to be padded down any with an l-pad and how good it sounds.
Normally I'd use the cone tweeter then cross the dome over at 12-13 kHz, however I want this to be a smaller build so I'll leave off the cone tweeter.
It may not be easy to do given how close the speaker mounting holes are to one part of the speaker, but I'll try to front mount the woofers. I could then find some grills to put over the woofers if so desired.
I'll then need to find a decently small reasonably priced solid state amplifier.
Ok so it looks like I'm either going to buy a dome tweeter that plays down to 3.2kHz or I will need to take the cheaper route and use the stock tweeters and cross in a dome at 12kHz. Doing a brief test by using the cone tweeter and using a 2.5uF cap in series with the dome definitely shows some improvement.
C1 is 1.39uF and the tweeter zobel is 1.4uF. Can get a 1uF and .33uF cap. The 5% tolerance will be enough to compensate.
I honestly think some of the all in one type systems with detachable speakers like the Phillips I got these drivers from may often have decent drivers with the problem being that the implementation of said drivers leaves a lot to be desired.
The phillips speaker has a rear round port and a front port. It has a woofer and cone tweeter. It also has what looks to be like two piezo elements attached to the plastic beside the tweeter. Have no clue what those are for as they don't seem to make any sound that I can hear. Oh it also has a plastic piece on top with two fake dome tweeters in it. They were oh so close with the piezo elements. Just about 4" higher and they could have placed them where the domes are so that they could at least add to the sound.
Here's the drivers in their original box. Absolutely horrible and it sounds about as bad as the graph looks.
Reactions: stv
Will Vinyl Engine ever reopen registrations?
Does anyone know about the situation with registrations at VinylEngine (and HifiEngine, etc)? I'm re-engaging my turntable project and would LOVE to be able to browse for service manuals, as well as research/download details on vintage tonearms.
Are they likely to reopen registrations - ever? I can't even find a way to contact an admin there without having already registered.
I've seen some members here are also members there and have graciously downloaded info for others, but it would be lovely to be able to just browse content and interact with the forums there. Thanks for any info!
Transistors for S500 Output Stage?
Hi All,
I have an S500 that has worked perfectly for last 10 years. I replaced all output resistors and power supply about 10 years ago and now suddenly the right side has gone quiet. The 6A fuse on right side blows immediately on powerup. I had a tech look at the amp and he says he found two resistors that need replacing.
M8352
M8326
there is also M8213
1.) Where can I find suitable replacments
2.) If two are blown, perhaps all of them need replacing?
Anyone have experience sourcing and replacing these? Attached a pic.
Much obliged.
~ Lee
Bay Area Member
New DynaKitParts ST-35 Build
Over the next few months, I'll be building the DynakitParts ST-35 with their bias control upgrade and choke. I also will be doing some other simple and inexpensive upgrades, whether "necessary" or not. I have opted not to use "enhanced fixed bias" circuitry, choosing instead the bias kit from DynakitParts that allows adjusting each tube individually.
It's a very nice kit, complete with everything needed except tools, solder, and tubes. It even comes with a free Dynakit ball cap. https://www.dynakitparts.com/shop/st-35-kit-120-vac/
I did purchase the optional tube cage as shown above, but I doubt that I will ever use it. Some future owner might though. I might open up the solid sheet metal sides and install matching perforated metal if I can get a small quantity of it.
A discussion of tube lifespan and possible power supply mods is here: https://www.diyaudio.com/community/threads/dynakitparts-st-35-power-supply-mods.398189/
The first "upgrade" was to purchase a 14/3 power cord. The kit comes with an adequate 18/3 power cord with inline rocker switch, but I will be installing a switch on the chassis instead, ideally a rocker switch on the front panel if I can find one that will fit.
Today I mounted four larger rubber feet to the bottom of the chassis. The ones that come with it are very, very small, making it hard to lift or move the amplifier because you can't get your fingers under it. I just happened to have four new rubber feet from some other project in my parts box and some screws and washers that fit, so that worked out great.
The two power supply diodes look a bit skimpy by today's standards, so I'll order a couple of 3A diodes if I don't have any in my parts box.
The four coupling caps (C4 and C5) that came with the kit probably are fine, but I'll upgrade those with something a little nicer like the ones shown in the video at the bottom of this post. I'm not sure what those are though. What's a good cap to use without busting the budget and given the obvious space contraints? If Mouser sells something good, I'll be placing an order from them anyway so I could save on shipping charges.
I can't stand silver audio components, so everything is now satin black, including the choke and the quad cap. I have decided for a variety of reasons to stuff different capacitor values into a quad cap can that I emptied out, rather than use the included 60/40/20 uF 450VDC 100uF 25VDC quad cap. The 100uF section isn't used with the bias upgrade kit, so I only need three caps not four. I have retained the terminals and locking tabs unused and undamaged. I bought a cap that had a sticker on it instead of stamped values on the can so I can make a decal to show the values that I actually put inside along with the date.
I have completed the artwork for a new set of white decals to go on the satin black chassis. I haven't had them printed yet because I may use triple binding posts for the speakers instead of just the 8 ohm outputs, and I may be able to fit a power switch on the front.
My first technical question is, with modern equipment, C1 is no longer necessary, correct?
I'll be ordering some 6P14P-EV or 6P14P-ER tubes for it. The ST-35 runs the tubes quite hard, and those military ruggedized versions of the EL84 can handle it.
I'm not sure if there is any real need for the CL-90 inrush current limiter, but it seems to be a popular option.
Login to view embedded media
Update: here is the final schematic as-built. Parts in red indicate additions/changes vs. the kit.
Reactions: jrdmedford
Help with Marantz NR1604 Firmware
Hi, messed up the firmware of my Marantz NR1604 while trying to connect with a Daphile server using DLNA (so kind of diy problem)
Problem is now all network sources have very low volume, googled some forums and its a commom problem for this receiver and only known solution is re loading the firmware.
Sounds easy but update through network doesen’t work (latest firmware already installed) and cannot find any source for downloading the file for manual instal. If Anyone can point me to a download page or has the file I would appreciate it.
...aparently the european Marantz support page has the files but its been offline at least since saturday so my guess its not active...
Thanks!
Audio Research Ref 5 Main Board for DIY
I have a Audio Research Ref 5 main board that has had some damage and would be good for your own DIY Preamp project.
The board is in too rough of shape to be used in an ARC product but is easily modifiable for your own use. The board had a power supply capacitor fail which blew out the digital volume control chips. there is some trace damage around the power supply and the volume control chips have been removed. as well as the housekeeping transformer and output coupling caps (I have some we can talk about). For the buyer I can help with info and schematics.
Board uses a 6550/6H30 in the regulator section and 4x 6h30's for the preamp section. (I have some of those we can talk about also). You can use a standard volume control or use one of the MUSES volume control kits that have been advertised around here. they would sound better anyway!
You are buying a project. one that will take some crafting and work to get running. But once done, will sound EXCELLENT!!!
Asking $120 plus shipping. plus any extra parts you may want.
This is a LARGE board. Shipping in the USA is likely around $20-30 depending on where you are. shipping outside the USA will likely be expensive.
Neurochrome LM3886DR Build
Hey guys,
a few months ago now after a failed attempt at buying a chipamp.com kit, Tom mentioned he would be making the LM3886DR Kits, so I immediately put my name down for the first one. It turned up quite a while ago, however I've had a busy few months and haven't had a chance to start putting it together until now.
Cutting the box open, everything was individually bagged and labelled from Mouser - so much more convenient than trying to figure out a handful of components. Thanks to Tom for helping me out with getting all components along with my boards.
Printed off the design documentation - super comprehensive and walks you through every step of the build (including about as much information on the chip as you're going to find anywhere). Easy enough to follow that providing you can solder, it's pretty hard to go wrong building this kit.
Started populating the boards with resistors. Again, having everything bagged and tagged makes this process super easy.
Power resistors in. Left 5mm gap for airflow around the resistors.
All caps in.
Connectors and inductor in.
LM3886 in (easy to solder, was annoying trying to lift it a pinch off the board for clearance - more due to my fat hands than any issues with the kit).
Chip attached to temporary heatsink for testing. Definitely overkill, but I had it floating around. Checked DC offset at the output - 3.5mv; perfect.
Attached to a test speaker and lab power supply. At the start of testing I was hearing some terrible things - the cone flapping around, continual cracks and pops, etc. Figuring I had something wrong I went through and verified all components with no success - turns out I had a faulty signal generator! Switched over to another one and it was perfect.
-----TBC-----
Reactions: pbilous
An exercise in converting a speaker to time-phase coherent
I've been doing some simulation on how to convert a regular speaker to time-phase coherent. The software is Xsim which has enough basic stuffs for basic simulation.
But first let's get some terminology out of the way. The definitions use freq. and phase response so there won't be any ambiguity. I am sure different people might have different terminologies but with respect to what I did, here are three types of first order speaker, from easiest to hardest.
Here are three:
1. First order/No Time-Phase coherence: this speaker will use first electrical order, but there is no time-phase coherence. It will not be able to produce a proper step response. It's more or less conventional with the exception that it uses first order filters.
2. First order/Time-Phase Coherence, BUT NO "Time coincidence"
(which will be explained in #3).
This speaker will be able to produce a proper step response, BUT and an important BUT. It may not be able to produce an excess phase of 0 degree from say 50Hz to 20KHz. This means that the speaker, for example, may have a phase shift of 50 degree or more or could be a full 360 degree at 15KHz, but only 5 deg at 500Hz. That is its excess phase will vary especially at higher frequencies as the tweeter approaching 20KHz. John Atkinson would agree this speaker meets his definition of "Time-Phase Coherence" since it could produce a proper step response. My guess is most speakers that were measured by John Atkinson would fall into this category. I've seen some measurements done on Vandersteens speakers and I was like ... hmmm... I am not quite sure. But the most stringent definition is reserved for #3.
3. First order/Time-Phase Coherence AND Time-coincident: this is the most difficult definition for any speaker to meet. That is it has to be able to produce a proper step response like in #2, BUT it also has to be able to have a 0 degree of excess phase from 1Hz - 20KHz. In reality, no speaker will have absolutely 0 degree, but the variations should be very small. I believe Thiel claims that their speakers excess phase shift is only a few degrees (less than ten). To be honest, I am not sure many speakers in the entire history can meet this definition.
So to summarize, you have three distinct possibilities from easiest to hardest:
2. First order/Time-Phase coherence BUT NO "Time coincident"
3. First order/Time-Phase coherence AND "Time coincident" (the most stringent)
RF impacts
You know what's crazy. That most people believe that putting an 'more or less' invisible gas into the atmosphere has huge consequences. Meanwhile the same people believe that putting invisible energy into the atmosphere has no major consequences. And are quick to dismiss any idea that bugs or humans are impacted by RF just because "it isn't categorized as ionizing"... If RF can ionize gases and make the electrons jump energy levels, Imagine what that would do to the atoms in you. Also the fact that nerves are basically electronic sensors.
I seriously doubt all that RF pollution isn't having an effect on life. Imagine living with a ~1W microwave pointed at your face, that would be a wifi modem.
with 5GHz wifi and the 5G broadband it would be ~ 4x as energetic per watt that a microwave/2.4ghz wifi is.
So then at the worst case scenario you could be having the equivalent of 1/100th of a microwave pointed at you for your entire life.
Can I use miniature tube as driver with adapter in my amp?
Here’s a schematic. I’m not a DIY guy I’m simply here to ask the experts and I’d appreciate input.
I have generally found I get the top end I like out of miniature tubes vs the octal or larger tubes and since my 6550 Tung Sols lack that extended highs I want- hoping I can use adapters for the 6BX/L7 drivers. So could a 5687 tube work with an adapter? Any other options? 6CG7?
May as well ask while I’m here. I also have matching transformer coupled preamp which uses 12AY7/6072. Curious if i can safely use a 12AT7 or European equivalent? What about a Western Electric 420a or 396a/5670 via adapters? 5687?
Could the preamp handle a different rectifier other than the 6x4?
Thanks in advance
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,365
Members
7,867,275
Messages
Filter
Forum Statistics
Threads
405,235
Messages
7,867,275
Members
507,365
Latest member
Chandena
