I have looked in all the usual places and can't seem to find one? Pilot 505. It has a 5AR 4,-4-,EL84's-and 2, 12AX7's.
Thanks for any help you may have.
Pilot favored paraphase splitters. Maybe that clue can help you trace things out for yourself.
What sort of features, like tone controls or a phono section, does the unit have?
I have to guess the circuit is similar to the Pilot SA-232 amp minus the 12AU7 input stage. Use the 232 as a reference to see if it's close enough.
Here's schematic of the Pilot SA-232.
None
I got this as pure amp chassis only.
T
Thanks directdriver!!
This at least will give me a starting point as most Mfg. used a lot of similer circuits when using the same tubes.
I believe I have schematic for that. Purchased some time ago. I will have to look for the right file, if you are still interested.
Parts List
Found my documentation. Unfortunately, I scanned them at 600 dpi, too large to upload to forums. if you'd like, i can scan the parts lists at a lower resolution and upload.
- Tubes / Valves
- Schematic help for a Pilot 505 amp please
