Hi: A record player turntable I have has two stroboscopic strips on its rim (excuse the lack of precision in vocabulary, if you please; I'll keep using 'strip' in what follows not knowing the correct term). One for 50Hz and the other for 60 Hz (mains). But I don't know which is which ( there is an indication on the player itself but it seems ambiguous to me). Each strip consists of a sequence of alternating dark zones and
light zones. At first sight, I think of the two strips, the one with less dark zones (equivalently less light zones) will correspond to 50Hz. I could reason like this: if the light blinks 50 times per second it is logical that the number of dark zones be some multiple or submultiple of 50, say a factor of two, and seeing the number of dark zones in the other strip is not very different, I'll have that the factor is also two there, and hence the strip with less zones will correspond to 50Hz. But I could be wrong and reach the erroneous conclusion.
Then, given the fact that the number of dark zones in one band and in the other, let them be n1 and n2, are alike, more exactly n1/n2 does not differ from one in more than 15 to 20 per cent, will some generous soul give me a hint?
NOTE: It seems the logical thing to me 1 - n1/n2 = 0.20 exactly (or -0.20) if n1 < n2, given that (60 - 50)/50 = 0.20. If somebody finds all this is too complicated I'll try to find some simpler way to put things, but I doubt I'll be successful.
In a standard TT one strobe strip is for 45 rpm and the other is for 33 1/3 rpm.
Also a TT is set up for ether 50 or 60 hz at the factory and should have a label on it specifying which it is.
In other words, you will not get proper speed at all operating it at the wrong hz..
Thanks for your reply. I shoud have been more explicit, now I see. On the front of the record player, which is direct drive, there is a manual pitch control and, beside it, a drawing. By one side of this, it is written '33 RPM'. By the other side, '50 Hz' and '60 Hz', one below the other.
To be more specific, the turtable is a JVC L-A31. On a plate on the rear, where the model and manufacturer's names are, it says 'AC 110/120/220/240V - 50/60Hz - 9W'. I suspect that so much versatility does not speak highly of its quality.
OK........ on that model it can indeed be use for either 50 or 60 hz. Evidently it can sense which what hz it is.
According to the manual, a strobe disk is supposed to set speed for 45 rpm.
It says, "Use the stroboscope provided for 45 rpm".......... and use the strobes on the edge of the platter for 33 rpm.
So, both strobes on the platter edge are for 33 rpm
Acording to the diagram on the TT, the top strobe is for 50hz and the bottom is for 60hz
The "strobe" usually works off the mains frequency.
The mains frequency is constantly changing.
The usefulness of the strobe becomes worth nought, especially when the motor and the strobe are both locked to the mains frequency.
Drive your TT with 40Hz from a Power Amplifier and see the strobe lock in. What is coming off the recording?
[Sorry, I posted before you edited.]
Well then, I'll try to find one. What I did before posting, is to play a recording from the 1970's, a German symphonic orchestra, and use my tuning fork, labeled 440. However, when my ear was satisfied, I didn't see any of the belts to get stationary. But pitch at that time was not exactly standardized. While European orchestras used 435, American ones used 440, this being only a general rule, which must have had some exceptions.
Meanwhile I keep looking for the stroboscopic disc that came with a Garrard 400, though the platter's much larger diameter has to result in greater resolution. Of course, the platter's stroboscope is more reliable than the ear. I think I have now, thanks to your post, all the information I need. Again thanks, Joe, and may you have a good day.
That's what I thought by watching that diagram, but I wasn't sure. This puts a definitive end to the whole question, save I'd like to answer AndrewT.
Thanks a lot.
Oh!, I did not realize that.
You mean feed the motor with the power amplifier output?Drive your TT with 40Hz from a Power Amplifier and see the strobe lock in.
Bach, Magnificat in D major, Vox PL 8890.What is coming off the recording?
The AC motor and the AC strobe both expect an AC signal of either 50Hz or 60Hz, to allow the Platter to turn at close to the specified speed.
If you feed in a sinewave with sufficient voltage you can drive the TT from a Power Amplifier using a sinewave source.
You can vary the frequency of that sinewave source.
Try 55Hz.
The TT will turn at a new speed.
But the strobe is very likely to tell you it is turning at the specified speed, because both the AC motor and the AC strobe are locked to the driving frequency.
A strobe that is lit by an absolute frequency (maybe crystal generated oscillator) can indicate TT platter speed error.
Is your strobe mains frequency reading, or oscillator reading?
Try 55Hz.
BTW...... you can DL and print strobe disks on the net .
That what I use as my TT has no strobes.
Just make sure you get one for the proper hz. 🙂
It actually isn't hard to calculate the number of divisions needed in a stroboscopic indicator; I've done so in this article.
Accuracy with a mains-driven strobe lamp will vary according to how stable your local power grid is. Here in Germany we don't have much to complain about, but it definitely isn't like that everywhere.
Code:
f
mains
N = n * ------ * 60 s; n ∈ {1, 2, 3, ...}
div RPM
I have a strobe app on my iPhone. Setting it for 60Hz allows me to use strobe discs I've downloaded. Very handy!!
There are some useful info on this old thread -
http://www.diyaudio.com/forums/swap-meet/188525-wtb-strobe-disc-light.html
- Analogue Source
- Which stroboscopic strip is the one for 50Hz?
