hypex ucd400 power supply
Hi Guys,
I'm gathering parts to built a linear power supply.
Is a 10,000uf cap sufficient for each rail ? I was also advice not
to go for 63v caps as they're too close to the recommended
operating voltage of the UCD. Is this advice true ?
My transformers ac rating is 40-0-40 volts each
Thanks in advance
I'm gathering parts to built a linear power supply. Is a 10,000uf cap sufficient for each rail ? I was also advice not
to go for 63v caps as they're too close to the recommended operating voltage of the UCD. My transformers ac rating is 40-0-40 volts each
The 63V caps are just barely ok, but if you want long, trouble free life for the power supply, go to 75V rated caps. Is this for a power amp?
Many use several times that capacitance for even low power amp circuits these days.
