OK, I see now: what worries you is the higher rms current of the post-converter.
That is completely normal: resonant converters, be they ZVS, LLC, or anything else require some storage and exchange of energy with the passive components, and this translates into a higher rms current for a given load.
Depending on the topology, this higher current can be limited (to some extent) to the passives, but it can also apply to actives.
That is the price to be paid for lower switching losses and quieter operation.
This is the reason why to this day, high power switching supplies are still... switching (hard): switching losses are almost a non-problem with modern MOSFets, and the industry knows very well how to manage the EM pollution aspect.
On the other hand, higher rms currents translate directly into costs: more copper, bigger FETs and heatsinks.
It is only when the supply becomes so large that one is forced to adopt resonant topologies, because parasitic parameters have to be taken into account, and instead of wasting power into large snubbers, it is more advantageous to use some kind of resonance mechanism to usefully recycle the reactive power
But that means I have a 350W output with an 800W input? That's a really low efficiency!
No, that's not possible: contrary to a widespread belief, active power is not simply the product of rms current by voltage.But that means I have a 350W output with an 800W input? That's a really low efficiency!
To compute active power, you have to make the product of the average current by the voltage (DC) at the output of your PFC.
Just chucking an idea in for LLC converters in general.... several years ago I had to fix an HV SMPS and it used a resonant output circuit for efficiency reasons but the really clever bit was that it had self-tuning based on current draw so it was always operating at the optimum frequency and maximum efficiency.
Ok, quoting the application:
I1 is the current where the resonant current in Lr meets the magnetizing current in Lm. This is also the point where Cr and Lr finish resonance for the first half-period of Fr1. At this point, there is no more energy delivered to the load and the output diodes are off. The Cr starts to resonate with Lr + Lm until the switching MOSFETs change states. I1 can be calculated as: I1 = (n*Vout)/(4*Lm*Fr1)
So the peak current on the primary is:
sqrt[ ((Iout*PI)/(2*n))^2 + I1^2 ]
In my case this is 2.79A. The average current should be Ipk*(2/PI) that is 1.78A. Assuming the typical voltage of 390V that is 694W. So the input power at the LLC SMPS is 694W with an output power of 350W, that is a 50% efficiency.
Are the equations in the app note right?
Post you complete schematic based on this app-note, it will make things easier.
When you have to dig the info bit by bit from a reference document, you tend to lose the big picture
This is the PFC stage, the input voltage range is from 180VAC to 260VAC and the output voltage is from 380VDC to 400VDC:
And this should be the LLC Half-Bridge converter:
My main concern is how much output power my PFC should be. If my SMPS has a 350W output power my PFC should provide about 400W of power to the resonant Half-Bridge. If you also have any suggestion for the circuits please feel free to tell me!
I cannot discover anything wrong in your circuit at a first glance.
I assume your calculations are wrong somewhere.
For instance you assume 390V input voltage. This is PFC DC output - but not AC-rms input voltage.
Woops. I think I got it. I'm the problem once more 😀 The primary average current is 1.78A but the voltage across the primary is half the PFC voltage! The maximum current is calculated with the minimum PFC voltage, so, 1.78A*(380V/2) = 338W! The exact output power of the SMPS is 337.5W so now everything is correct!
The PFC output power has to be 400W and the RMS current should be used to dimension the transformer wires.
You got it😉
When you properly write down the details of a problem, they generally (not always!) tend to vanish. This is why I ask for them: I felt there was room for simplification.Woops. I think I got it. I'm the problem once more
Try to think outside the box/ tablet/PC/notepad, etc.
I typically do this during my insomniac episodes, at around 4am when I cannot sleep: no distractions, nothing else to do and the benefit of a half-night sleep.
Some problems can be simple when you take them at their face value
the blocking cap is part of the tuned circuit so it has to optimized accordingly.
http://www.ti.com/lit/ug/sluu361/sluu361.pdf
Yes, you can't be more right! Thank you very much for all your help Elvee!
Yes, in my case Cr is 22nF. I've read that using Cr splitted as in the schematic is better so each cap is Cr/2. Do you have any recommendation?
The splitted way is imho preferable, because both caps in series provide a bypass cap for the supply rails as well.
One final question. In this LLC converters do I still need the output inductor? Can I just use a capacitive filter to get a regulated output voltage?
I've seen a lot of designs, some of them use the output LC filter with a small inductance value and others doesn't even use the inductor.
When I designed my LLC SMPS I didn't use a choke on the output and it worked fine.
The input to the transformer is a sine wave so doesn't have the harmonics of other types of SMPS.
- Power Supplies
- Half-Bridge SMPS with PFC
