This one seems to be very good value
https://www.ebay.com/ulk/itm/272219313743
It has the famous CS4398 dac chip and also has coaxial spdif output. Price is hard to beat. I order one from taobao.com even cheaper.
Folks, an insider told a conclusion about these stuff. here we go:
all of them have good mids
xmos: highs bad, lows good
6631: highs good, lows bad
amanero: highs bad, lows good
I think this kind of conclusion seems lack of context. Is everything else equal i.e. XO used, power supplies, pcb layout? How bad is bad? I have used both xmos and 6631. They both do a good job. In one case the xmos fed by a lenovo laptop sounded much better than an akm spdif receiver on the same DAC. On thic DAC with akm chip the high is clean and detail.
My observation in most digital equipment the low is less affected by jitter. My assumption is that at low frquency there are alot more data points for each cycle of sine wave. If the low is bad I would suspect the DAC power supply or analog stage.
Thanks for the evening laugh. I'd bet they're all audibly indistinguishable from one another in a comparison feeding the same DAC.Folks, an insider told a conclusion about these stuff. here we go:
Yap, everything else equal. But, that's a exaggerated expression, the difference between them is small, and designing is the key. So don't worry.
I bought several dacs from the bay Usb inputs,I found a big difference in power supplies when using a usb powered dac,I built a stand alone and it made a difference in fidelity,sonics the one I built used a lm317 nothing special just like the data sheet ,Try it ,I will make a SALAS 5 volt PS and see if it's a better change.
Has anyone tried this ?
Post up the results or opinion !
Sure I can Hear YA! LOL.
Happy Listening!
NS
Happy Listening!
NS
Hey mtoc,
Do you think that maybe that's why dacs have filters built in them,Maybe a different algorithm could be written to adjust the tone or EQ and the volume inside the dac,I have contact buttons on some boards for vol,be nice to be able to eq inside the dac and control volume too.
NS
Hi i want to flash the device but after i erase the old one, i got fail to flash the 101 or every other hex.
Can anybody help me please?
I'm looking for a board that now I'm not sure if it even exists:
Input: coaxial, optical, usb
Output: I2S
Then I could mate that with this board:
ES9018K2M ES9018 I2S Input DAC Decoder Board Support IIS 32bit 384K DSD64 | eBay
Anything available with CM6631?
Output: I2S
Hi everyone,
I have ordered a CM3166A board with IIS and SPDIF Outputs. Nothing more
So i was looking for a dac to combine e.g.(ES9023, WM8740,CS4398,AK4495)
but i have a question!
Can i connect them directly or it need some receiver/decoder like CS8416 between them?
Thanks in advance
Thanks in advance
Hi everyone,
I have orded a CM3166A board with IIS and SPDIF Outputs. Nothing more
Thanks in advance
Do you mean you are building your own DAC from scratch using one of those chips, or ordering a pre built DAC unit or PCB?
Yes and no. It will be like from semi-scratch. Several mini boards to be combined with my own supply
I want to avoid smd soldering, but if it's needed i can solder up to SOIC size and print 1-side pcb
Stand-alone pcbs (with only 1 chip each) would be prefferable to combine them.
Below is the board i ordered
So, what do you believe about #570
The ideal DAC for you would be one that has the same lined-up I2S you have.
Then you can just plug your USB board on it.
Can you please help me to understand what line-up matching means?
Or some proposals maybe
On one side of your board you have six pin holes: that is your I2S interface.
I looked around to see if there were any DAC boards with the same pin order, but I couldn't find any.
But you could use this one:
NEW ES9018K2M ES9018 I2S input DAC decoder board
As you can see, the pin order is not similar and can't be aligned directly with socketing. You will have to use either short (less than 10cm) flat cable interface or three short thin coaxials (shield always grounded) to link pin by pin. The pins are BCK, DATA, LRCK and DATA.
Now i see what you mean..!That is not a problem. Thanks
I can use o short cable or make a mini pcb that will make the pairing
So back to my first post
Can i connect them directly or a receiver/decoder like CS8416 between them is needed?
Reading about dac all these days it seems IIS pairing to be better. Am i wrong?
As long as the cable is short and the pin positions are correct, you can connect it directly.
The interface is with the DAC chip, you do not need another receiver.
Thanks,
So it is up to decide which dac, there are lot of them...i can't decide 🙁
Any suggestion in what to choose? Are there any differences between them? All seems the same to me..
I'd choose the ES9018 I suggested above.
Use a good power supply for both boards. Try not to use internal USB supplies.
- Digital Line Level
- CM6631 USB audio interface ... any good?
