"Best" connector for DC power to audio stuff
I am designing and prototyping high quality audio devices to run from nominal 12VDC power supplies.
Most wall warts, and many existing 12VDC products use the ubiquitous 5.5mm/2.1mm DC plugs and sockets, or the 5.5mm/2.5mm variant.
I could use this system but it doesn't handle much current and the quality of connection is a bit, well, hit and miss.
So I am looking to spec a better grade of DC connector.
Cigarette lighter plugs are huge and grotty. There are lovely multipin locking mini-DINs but current capacity is an issue and they are not exactly a standard.
So called 'merit' plugs look interesting but they don't lock and I am not sure if they are really going to be adopted as a new standard. Standard XLR/Cannon type connectors scare me because there are so many variants used for so many different things. Microphone, speaker, mains voltage, who knows?
So, can anyone comment, or recommend a DC connector that is reliable, robust, easy to get and can handle at least 5Amps?
Any input much appreciated.
ps. The only reason I would like to use a reasonably common standard is to ensure that the products can have a reasonable lifespan and not be tied to a connector that drops out of use.
cheers, blakkington :cheers:
12V may be too low a voltage for 'high quality' audio, although it depends on exactly what you are doing. The nominal output from a typical digital source is 2V rms, which is nearly 6V pk-pk. When the signal swing approaches the supply rail voltage it gets harder to achieve low distortion, especially with discrete circuits.
Maybe mini XLR would do.
Din plugs and sockets are not likely to disappear.
Many pin arrangements are available.
When I worked for Soundfield microphones we used Lemo connectors extensively, really very nice, but you will pay for it.
Hirose have some fairly nice locking connectors for not too horrible money, widely used in field recording for 12V power, not as nice as the Lemo option but very much cheaper.
There are fake Lemo out there, which are nothing like as nice but are cheap.
73 Dan.
Yes, there certainly are significant limits to what can be achieved with only 12V. The aim of the project is to look at ways to extend or overcome those limits if possible.
blakkhole
73 Dan.
The Lemo and Hirose connectors look great and I will probably use them if the products end up good enough to charge a premium price! 😀
If they don't :cannotbe: I might look at mini DIN/XLR as I have decided I want them to lock on.
Thanks all for your input !
blakktie
the afore mentioned Lumbergs are excellent for this kind of useage.
Look for types SV and WSV (connectors, straight and angular) and KFV (receptables).
They are built acc. to IEC 61076, which is basically the well known DIN-Type connector (think of NAIMs connectors or on some tonearms) with a threaded metal casing to safely secure the connectors on the receptable.
Available from 3-poles to 12-poles, with tongue and groove inlet for failsafe plugging.
Solder contacts are gold plated, for wires up to 0.75mm²/5A.
High surface finish quality and more expensive looks than they cost.
You can´t do wrong using those, if You can place the ~20mm OD on Your casing ;-)
jauu
Calvin
If you go for 4 pole XLR there are industry standards for 12V pinning, please do not put power on a 3 pin XLR.
Definitely do NOT use speakon or powercon for DC on an audio product, far too much potential for a really expensive accident, they are excellent, but have well known defined roles and expected functions, the rule of least surprise applies here.
Regards, Dan.
