@amigo1 - I did a build of Volumio back in Spring of 2018 from that how-to. I'm not sure what exact version of Volumio it was, but it was definitely v2. I had to use a Debian Jessie VM to get it to work. Mac user here. Stretch - no dice. I'd like to try again, but was hoping someone had already done so. I've asked on Volumio's forums, but no dice there either.
new Volumio for Beaglebone Black
Thank you! I have heard your image. Аs far as I know nobody has done it in 2019
OK I have built a new image. It's still based on Jessie, not Buster. I believe the RPi images that Volumio provides are the same - based on Jessie. I haven't tested everything, but Botic driver is there and is a choice in Volumio. Kernel is boticized as well. The only thing I noticed that I'm not sure about is the "MyVolumio" feature. Not sure how that is supposed to work.
Here's a dropbox link... Not sure how long I'll leave it up.
Dropbox - Volumio2.668-2019-11-18-bbb.img.xz - Simplify your life
Volumio2.668 for beaglebone black!
Thank you for Volumio2.668 for beaglebone black! You are real geek
Would you so kind as to write checksum SHA 256?
Volumio2.668 for Beaglebone Black
Thank you for Volumio2.668 for Beaglebone Black
Thanks Mull3t for the new Volumio.
Sound is better then 2.194 image. all features work in my system.
DDDac i2s hermes cronus bbb.
@bubu200 - glad to hear that. I'm hoping that the Volumio devs can make another one off image with MyVolumio, which is proprietary and not included in community based builds.
That would be quite helpful. Thank you.
This took longer than expected, however there is now a "debian-buster" branch in GitHub - coroner21/linux-am33xbot: Linux Kernel for ARM beaglebone devices with patches for so-called botic driver and it includes all instructions and files required to generate a boticized 4.19 linux kernel image for the BBB on a debian machine (with a cross compiler, or if you change the instructions a little on the BBB itself, however compilation will take a looong time).
Enjoy and let me know in case of issues.
I don't think so. I think there was an issue with getting a build to work beyond Debian Jessie. Not sure if any progress was made. The latest that I built was using Jessie.
Hey guys here is a new build from one of the Volumio devs. I asked for MyVolumio to be included, which requires the build to be done on their server. I believe we're still working off of Jessie here. I haven't tested the build as of yet.
Enjoy!
http://updates.volumio.org/bbb/volumio/2.673/volumio-2.673-2019-11-29-bbb.img.zip
Enjoy!
Thank you for 'debian-bustler' branch.
I've just compilled and build 'linux-image-4.19.79+_4.19.79+-1_armhf.deb'.
What exactly line should I add to bbb's /boot/uEnv.txt?
ok. After installing new kernel I added to /boot/uEnv.txt:
Code:
enable_uboot_overlays=1
dtb_overlay=/lib/firmware/BOTIC-00A0.dtbo
Code:
debian@beaglebone:~$ uname -a
Linux beaglebone 4.19.79+ #1 SMP PREEMPT Sun Dec 1 04:07:47 CET 2019 armv7l GNU/Linux
debian@beaglebone:~$ sudo lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
However I have strange messages in the dmesg log:
Code:
[ 35.726204] snd_soc_botic: unknown parameter 'serconfig' ignored
[ 35.726222] snd_soc_botic: unknown parameter 'dai_format' ignored
Code:
debian@beaglebone:~$ sudo dmesg | grep botic
[ 0.000000] Kernel command line: console=ttyO0,115200n8 snd_soc_botic.ext_masterclk=3 snd_soc_botic.serconfig=MMMM snd_soc_botic.dai_format=16386 snd_soc_botic.clk_44k1=45158400 snd_soc_botic.clk_48k=49152000 snd_soc_botic.blr_ratio=64 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 rng_core.default_quality=100 cape_universal=enable quiet
[ 35.727017] asoc-botic-card sound: using 'default' pinconfig
[ 35.774135] asoc-botic-card sound: botic_codec <-> 48038000.mcasp mapping ok
[ 35.794981] asoc-botic-card sound: 48k ext, 44k1 ext, use format switch
Second issue with the build kernel.
I'm trying to build lirc-bbb module. I installed generated headers 'linux-headers-4.19.79+_4.19.79+-1_armhf.deb' but stuck at 'fatal error: classmap.h: No such file or directory'. See details.
Should I install something?
Code:
debian@beaglebone:/opt/lirc-bbb$ sudo make prepare
make -C /lib/modules/`uname -r`/build scripts
make[1]: Entering directory '/usr/src/linux-headers-4.19.79+'
HOSTCC scripts/selinux/genheaders/genheaders
scripts/selinux/genheaders/genheaders.c:18:10: fatal error: classmap.h: No such file or directory
#include "classmap.h"
compilation terminated.
make[4]: *** [scripts/Makefile.host:90: scripts/selinux/genheaders/genheaders] Error 1
make[3]: *** [scripts/Makefile.build:544: scripts/selinux/genheaders] Error 2
make[2]: *** [scripts/Makefile.build:544: scripts/selinux] Error 2
make[1]: *** [Makefile:1061: scripts] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.19.79+'
make: *** [Makefile:35: scripts] Error 2
new Volumio image for BBB
Why you not use new Volumio image for BBB?
In my opinion Volumio is in fact MPD with GUI with some restrictions (e.g. relatively old version of MPD, lack of satelite mode etc). I prefer plain MPD (my own build). Besides I use not only MPD but also Squeezelite so I can switch easy between the players.Why you not use new Volumio image for BBB?
new Volumio for Beaglebone black
1. What do you mean under lack of satelite mode?
2. How about using M.A.L.P. or MPDROID?
3. Somе MPD versions sound not good, isn't it?
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
