ST-70 DIY Kit, Bob Latino or Dynakitparts?
While not nearly as scarce as the 7199, the 6GH8 is also out of production. AAMOF, all the useful pentode/triode types are NOS only. 🙁
If something comparatively close to the original is desired, consider building around Triode Electronics' board populated with 2X EF86s and an ECC99. The original signal topology is retained, while using in production types whose electrical performance is better than the devices found in the 7199.
Well, one thing your link showed me it that Bob is active on this forum! That is a big plus for customer support!
My local vintage hifi guy has a ST-70 for sale. I thought about buying it but when I started looking around at what it would cost to refurbish it I found these kits. I'm not too concerned with either price, I'm just trying to figure out the differences.
I planned on staying away from the 7199 version and it seems like 6GH8s are easily sourced but I see your point.
Wow! Sad to hear the 6GH8A is out of production. It was the quietest pentode preamp tube I found while running the Audio Note ANK (rev e) design. Not sure if same result vs 6F2, 6U8A, 6EA8 in the Dynaco design. 6GH8A currently still available thru retail vendors, though.
Link below compares these tubes in ST70.
Jim
Replacing 7199 With 6GH8 And Comparing THD In A Dynaco ST-70 Vacuum Tube Amplifier - YouTube
Jim
I am not aware of any triod-pentode still in production. That said, there is no shortage of these, 6GH8, 6BL8 6U8 ECF80 ECF82 and others . All of the above
can be used in a Dynaco ST70 using an adapter plug.
I have compared several of these in a Dynaco SCA35 :
http://n.manet.nu/tubedoc/sca35-7199-alternative.pdf
Here's their description:
Our driver circuit is a modern all triode driver design, for totally neutral uncolored sound.
One half of the first tube is used for each channel as a voltage amplifier.
One each of the other tubes is used per channel as a combined phase splitter/driver
in a long-tailed pair configuration. 13 db total loop feedback is used.
Hmmm,
Sounds to me as if front end dual triode design of Dynaco's ST35 has been 'adapted'
Jim
Triode voltage amplifier into LTP phase splitter = Mullard style topology ala EICO.
