Horn Folding Tips
I am new to audio Community, facinated about acoustic impedance maching devices AKA(horns) 🙂.
I am currently planning to build a FLH with vented chamber :smash:.
From some knowledge on reading tons of treads on horns, I know that the straight round horn is the best case scenario 😀. But horn gets very long therefore, folding.
So in folding horns, 90 degree bend better than 180 dergree ?.
Does 180 degree bends mess up air flow ?.
Does it creates higher order modes ?.
Causes unwanted turbulence ?.
I have never seen a FLH with 180 degree bend. But a 'TON' of tapped horn with 180 degree bends....
This is my first thread, And english is not my mother tongue. Please forgive me if there is any mistake 🙂. And feel free to correct me :cheers:.
kind regard🙂.
well there is the EV Cobraflex
image.php
or are you taking low frequency?
images
How many folds, as 180 or not matters. That can represent a sine wave and anything else is a just a weird mess. Anti nodes and nodes at folds or driver positions as well as the ends or start of the ‘enclosure. Thats plain and if works out as real or not. Youre forced into being really accurate.
I dunno why anyone would do otherwise and if you look at what might happen if you use all lengths and folds of the same interval(or essentially two intervals) you create a reality that is realistically portrayed and exists instead of the awkward randomness that a bad bad guess at infinity?
The results in those are unique and always show why it matters. However people must compromise to fit things and thats unfortunate because its not as bad as it might seem. Their are drivers that suit box shapes and lengths that make good disquises and even skinny long ones that are further disquises and hidden?
My bass horn consists of only one 180 degree fold 🙂. Based of the reply I think its fine to fold 180.😀.
Sorry for the rough sketch 😱.
attachment.php
This horn is 40 inches deep, 30 inch high and 16 inch wide (inside).
since you were mentioning about the phase,
attachment.php
here is the phase response.
Brian Steele makes spreadsheets supporting different layouts, The Subwoofer DIY Page - Horn Folding.
Here is the thread: Spreadsheet for Folded Horn Layouts...
This i my design: JBL 2226H 30 hz "horn" i built, images at the end. Brian calls it BOXPLAN-PARAH.
When you do a 90 degrees fold, the distance beteween the outer perimeter and the inner determines the frequency where you get cancellation. When the outer perimeter is half a wavelength you get cancellation. As an example, the largest bend in your design is 340 mm from side to corner. Total length is 680 mm. A full wave is 1360 mm, 1.36 m. Speed of sound is 340 m/s. Divided by 1.36 m you get 250 Hz.
180 degrees bend you will have to double the distance, or half you frequency. The same example will give cancellation at 125 Hz. So avoid 180 degree bends.
Thank you for sharing sir :happy1:.
I dont know if it will work, does adding wood pieces like this for dividing the airflow decrease the internal turbulence and change the cancellation frequency to a higher one ?. Or is it a dumb design fail 😱. I need this horn to go about 150hz high. Please correct me 😕.
attachment.php
attachment.php
I thought that it could act like some sort of a phase plug, and hopefully reducing high frequency interference 😕.
Vishnu Vinod,
Adding a second set of internal corners to your folded/bent horn path would not be useful, though longitudinal bracing is helpful to stiffen up the horn path.
The EAW BH760, KF940 and countless other horns have similar bends of near 180 degrees as in your design, yet show no cancellations due to the bends until above 1000Hz, well past your crossover range of 150Hz.
Art
Vishnu Vinod,
Art
Ah sigh of relief :cheers:. I think this answers my question 🙂😃.
