Linear Voltage regulators for power amps...
Hello All,
Looking for linear voltage regulators that have input around 55 V and output 50 V and can handle 5 amps. Also need the complementary regulator for -55/-50 V. Are there any ready components? I'm having great difficulty to find any. (Otherwise I'll have to build one myself.)
Martin Albers
If I'm not mistaken, I believe the LM1084, LD1084, LT1084 are floating regulators and could do a 55V to 50V regulation as long as the voltage from input to output does not exceed 30V. You can use a few transzorbs (e.g. 20V) across the regulator to assure that the 30V limit isn't passed. Also best to have a slow start on the amp (even an inrush current limiter would do).
Alternately, if you have 5V to play with, you could do a capacitance multiplier.
If you want REALLY low noise, you could do 4-5 LT3081 in parallel with the same precautions as the LM1084 above. Much more expensive, but much higher performance.
Reactions: fongshuyuen
Trivial question: doesn´t your amplifier handle 55V rails?
It´s only a 10% difference; even Mains voltage can vary by that much.
In general Power Amplifiers do not use voltage regulated supplies but are fed straight from "raw"/unregulated ones, of the proper voltage.
Pass transistors as you mention will dissipate a lot of heat, 25W internal dissipation from each device, either integrated regulator or bipolar transistor will need significant heatsinks.
Hello, Thanks for the hint. What about the complementary regulator on the negative side? I can also settle for regulating 50 V down to 48 V.
If you can find the parts for these board, this project really is one of the best pairs of regulators available: https://www.diyaudio.com/community/...r-in-a-crc-power-supply-r21-ps-module.376003/
Alternately, if you have enough headroom on your voltages you could do a capacitance multiplier for the negative rail as well.
There is no integrated IC like the Lm1084 for negative rail. You could parallel a whole bunch of LM337K (likely looking at 5-7 in parallel for 5A output), but you'd have to use ballast resistors to balance load and that would significantly affect performance, and you'd also need the transzorbs from input to output to prevent from exceeding the max voltage testing of the regulators.
https://sound-au.com/project15.htm
LT1084/LM338 are good regulators.
But you need additional circuit to limit input/output differential at start up.
Also if your amp is Class A and draws 5A immediately at start up, your transient dissipation is 250W~275W even with current limit.
So it depends on your application.
If your transformer has 2 secondaries, you can just make 2x positive regulated supply, and series them to give +/-50V.
Patrick
Actually it is a AB amplifier, so I need to have a regulöator that can handle the negative voltage.
I think capacitance multiplier is enough and have better efficiency than voltage regulator. Usually audio amplifier do not need voltage regulator and it should work with voltage tolerance +-10%. If you need voltage regulator, usually only at VAS and input stage with several volt higher than output stage.
There were James Boak's regulators back in Audio Amateur in 1980.
https://studylib.net/doc/8115546/a-family-of-power-amplifier-regulated-power-supplies
thank you very much for this URL - I have save this TAA article as PDF here.
in post 51-57 under
https://www.diyaudio.com/community/threads/tweaking-classic-linn-lk1-lk2-lk280.106226/page-3
you will find the schematics of Linn's power amp models LK-2, LK-280 and Klout - all this models use voltage regulators with integrated protect functions.
The attechment in post #1 (file No 15) under
https://www.diyaudio.com/community/...mp-nap250-compared-with-nap160-nap110.398516/
show Naim Audio's NAP250 regulator.
Maybe of interest.
here is the text from pdf attachment in previous post for the purpose of copying it to Google language tools:
A FAMILY OF POWER AMP POWER SUPPLIES
ONE OF THE MOST POPULAR power amps to appear in The Audio Amateur is Reg W illiamson's classic, the 20/20
(TAA 1/70, p. 5).
The amp's clean performance and ease of construction have kept interest high, and several people have attempted to
design power supply circuits to gild its characteristics.
Reg published the first of these circuits with the original construction article. His aim was to protect the
output transistors in the event of an overload by shutting down the power supply. This was a latching circuit;
you had to power down or "reset" the protection after removing the overload.
The next circuit to reach The Audio Amateur's pages was a true regulator, Josh Goldberg's 68V supply [TAA 217A, p. 13).
The design featured straight volt-amp limiting at a fixed value.
Although each circuit it had something to recommend it, drawbacks to each, in both function and design, limited their usefulness.
The Williamson design did not provide regulation; the Goldberg design lacked "foldback" limiting (a very important consideration if the supply overload circuit is to protect the output transistors as well). I was tottering on the brink of designing a rugged, three-terminal type regulator with adjustable foldback current limiting, internal safe-area and thermal shutdown protection, and adjustable output voltages, when Nelson Pass's class A amp
arrived (TAA 4/78, p. 4).
The Pass amp has supply demands somewhat like the Williamson 20/20. The ±32V rails of the split supply correspond to the 60V to 68V we find on the Williamson amp. The class A amp of course draws more current, even when both are at full load. But due to the split supplies Pass uses on his amp, the overall maximum output is about 300 watts in each case (32 volts at 8 amps vs. 68 volts at 4 amps).
"Wait a minute!" I can hear you saying. "Isn't one of the benefits of a class A amp the constant load it presents to its supply? Why regulate it at all?’' The reason for regulation is that Pass has chosen a bipolar push-pull design. With three current paths and a full load current much greater than the idle current, the amp looks like a class B load (plus a constant) to the power supply. The price we pay for
the amp's increased efficiency is this load current variation. To provide low noise at no signal, and to maintain voltage levels within the amp, we still have to regulate the supply.
An other reason to design a regulated supply is the Williamson 40/40 [see p. 5, TAA 4/79], This comprehensive update of the earlier 20/20 has very similar supply demands. The final and most compelling reason, however, is my own forthcoming 80 watt 541-based power amp. I required a large and tightly regulated supply for this amp, to keep the dissipation under control while working near the absolute maximums for the 541 package. The supply demands range upwards to about 8A peak at ±40VDC, or somewhere between the large current demands of the Pass design and the voltage requirem ents of the Williamson amp. Rarely in the demanding world of quality audio design can one kill two birds, let alone three, with one stone.
I found the temptation irresistable, and the result is the circuit described in this article.
DESIGNING THE SUPPLY
I feel that the fewer parts a design requires, the fewer parts there are to go wrong. This leads me to design with IC components wherever they can be used without sacrificing performance. I further believe a good design is straightforward and easily comprehensible. When a designer thoroughly understands his circuit, he can more easily analyze and correct those factors which degrade performance.
We therefore want to start with a simple IC circuit, adding complexity only where necessary to ensure performance. Anyone who has worked with a three-terminal monolithic IC regulator appreciates the reliability and ease of use of these devices: once
installed, they are virtually immune to overload and overheating. We will therefore start with a three-terminal regulator as our basic circuit. This certainly satisfies the simplicity criterion, but what about performance? The first problem we encounter is the output current, as most available regulators are limited to about 1.5 amps. We can increase the current capacity of the regulator with the Fig. 1 circuit. The ratio R2/Ri sets the ratio of currents through the regulator: i.e., if R2 = 6 and Ri = 2, then the transistor TRi will pass 3 amps when the regulator passes 1 amp. Output currents in excess of 20 amps are possible with a suitable TRj. As long as we select a transistor
with a wattage rating WT such that
WT/WR > R2/R1
where WR is the wattage rating of the regulator (about 20 watts for an LM340T), and put both TRi and the regulator on a common heatsink, we can treat the combination circuit just like a monolithic regulator, with dissipation and current capacity equal to the sum of the elements. The regulator's output impedance is divided by the ratio R2/Ri. The regulator will be thermally protected for any size of heatsink, and will have foldback current limiting and safe-area protection. The circuit still will not do the required job, however. The output voltage is fixed at the regulator voltage, and that limits us to a maximum of 24 volts.
page 6
This is the voltage above the ground pin; we can therefore raise the output voltage by raising the ground potential of the regulator IC.
This can be done with any stable voltage capable of sinking about 10mA of class A current. In order to improve stability, I "bootstrap” this
reference with an additional 15mA of current from the output. We must also ensure that at no time does the voltage across the regulator exceed 35 volts, as the internal pass transistor in the IC would be damaged if this occurred. We need to protect against high input voltage, and we need to reduce the input voltage if the output is shorted. We can accomplish this by adding a "pre-regulator" which is really just an emitter-follower regulator (see Fig. 2) placed ahead of the IC. Under normal conditions, no matter what the input voltage, the IC sees
a constant supply voltage equal to zener voltage Z1.
In the event of a short circuit, D1 is turned on by the drop-in output potential drop relative to the floating "ground" pin of REG1. This shorts the bootstrapped zener reference Z2, reducing the voltage across REG1 to about value of Z1.
The only feature we need add is the ability to vary the output voltage in order to trim the regulated output and allow for component variations. We can do this by adding a variable resistance in the ground leg of REG1, as in Fig. 3.
Using a 500Ω pot with a total ground current of about 25mA allows us to vary the output voltage by a total of 6-8 volts (limited by Z1).
GILDING THE COMPLETED DESIGN
The basic design approach is complete. One or two chores remain, however. We must ensure that the ground reference is free of stray AC,
which would appear on the output; a tantalum cap across Z2 takes care of this. An additional problem arises due to the current Z2
must sink. In the 68 volt configuration, Z2 must sink not only the 25mA class A and bootstrap current, but also the current through the pre-regulator, which will be about 20mA. This means Z2 must dissipate nearly 2 watts.
The typical zener impedance of a 47 volt device is 100Ω, which would cause the ground reference to vary significantly with current despite the bootstrap. To avoid this we use the zener power booster of Fig. 4.
This circuit has two advantages. First, the dissipation of the "zener” equals the transistor dissipation. We can build zeners with dissipations of hundreds of watts using this technique. Second, the zener impedance is divided by the hfe of the transistor. Thus, for a 47 volt zener with 100Ω impedance and a transistor with hfe of 100, the
resulting "zener" impedance will be only 1Ω, resulting in a shift of only 1mV per mA sink current shift.
Combining all these tricks, we come to the Fig. 5 circuit, which can provide up to 10 amps at 68 volts using the heat sinks and transistors
specified. The crucial limiting factor is the pre-regulator pass element TR1.
With NPN pow er transistors rated at 625 watts and 250 amps now available, your ambition is really the only restraining factor on the maximum current which could be supplied. One can create a bipolar supply out or two positive regulators by connecting the output of one regulator to ground. To do this, the raw supplies for each regulator must be independent, as they must "float” against each other. This arrangement degrades the transient response of the regulator, however, which in turn creates potential problems for the limit circuits. A better solution is a "mirror image” of the positive supply. This negative supply version is shown in Fig. 6.
It is functionally identical, with polarities reversed, and uses an LM320T negative regulator for the primary control element. Remember that the LM320T pinout is different than the LM340T! Some care must be used to bend the LM320 leads around to fit the LM340
pads. The maximum current is set by the choice of R4 and R5, corresponding to R1 and R2 of our earlier discussion.
The values in the parts list are appropriate for the amplifiers indicated. You may choose other values to suit your own needs.
Two additional components, diodes D2 and D4, are not really a part of the normal circuitry, but help to improve response to faults. D2
protects against the "tractor pull" problem when a positive supply is shorted not to ground but to a negative voltage. The first supply to limit current would be destroyed by the other supply without D2; this diode shunts a portion of the current to ground on such a short, guaranteeing that both sides of the supply go into current limiting. D4 sinks current to the raw supply in the event the two load voltage ever exceeds the raw supply Vin.
page 7
AMPLIFIER PROTECTION
The regulator protection circuits can also protect the output transistors in the amplifier if you choose the current limit correctly. The TIP 35 and 36 transistors which Old Colony offer for the Williamson amp are rated at 25 amps and 90 watts. Into an output short, with a 68 volt supply, each transistor will see a half-cycle of 32 volts at Isc (the regulator short-circuited current). The RMS dissipation will thus be 16 x Isc (which is about an amp for the 4-amp option), or about 16 watts. The full load current of 4 amps is thus only available for sine wave signals which draw less than 4 amps peak. As the 40/40 features its own internal current limit, which would presumably act before the 4 amp supply limit was reached, the supply's protection is a backup. The supply's thermal protection still extends to the amplifier if the heatsinks are chosen correctly, however. I discuss the correct values below under Construction Details.
Although the 4 amp supply has a transient capability of nearly 6 amps, a pair of 40 watt stereo amplifiers could potentially draw peak currents of 8 amps. If you intend to power both channels of your amp from a single supply, you must provide for these peaks. Using the values of R4, R5, TR1, and TR2 from the Pass configuration (Fig. 5 and the parts list), we can provide up to 10 amps. Note the value of Isc goes up to about 2 amps with the higher power option, and the foldback point is also much higher; the regulator thus does not afford the same degree of protection as if a supply were provided for each channel.
For the 80W 541 supply, we provide a 12A transient peak, or 8A RMS, at ±40V.
page 8
Construction details for this version of the supply will accompany the power amp construction article. The ±32 volt supplies shown for the Pass amp are optimized for the demands for the class A amp. With the recommended resistors and heatsinks, the Pass configuration will provide 15 amps for a fraction of a second (transient peaks), dropping to about 10 amps after a second or so.
The regulator thus allows for electrostatic or other reactive loads while providing protection from substantial high-power damage. This circuit's operation depends on thermal capacitance in various components, and thus the wattage rating of R4 and R5 is important to correct operation (see box on Thermal Capacitance, below).
CONSTRUCTING THE RAW SUPPLY
The raw supply feeding the regulator can be any DC supply which gives the desired full-load current and stays within the input voltage limits of Figs. 5 and 6. I think the raw supply described in Pass's article is an admirable choice. We will use a slightly different arrangement than that shown in his article, however, as we must provide a margin to allow regulation and also allow for low line voltage, component variation, and other variables. Connect the secondaries as shown in Fig. 7.
If the voltage across the transformer is close to zero, reverse the secondary connections; you should get about 90VAC. To develop the raw supply of 90VDC for the 68V supply, we need about 66VAC, which we obtain from the signal 88-8 as shown in Fig. 7.
Fig. 8 shows one supply arrangement. Note that the ripple rejection of the regulator is in excess of 120dB; thus a large ripple voltage
can be tolerated as long as the minimum voltage exceeds the minimum input shown in Figs. 5 and 6.
The 88VCT available using the juncture of the secondaries as a centertap is about right to provide the 60VDC no-load, 50VDC full-load
capability we need for the Pass supply. For this application, use the configuration of Fig. 9.
SELECTING COMPONENTS
Most parts for the supply are the same no matter what voltage and current you desire; Fig. 6, the negative supply, shows values for a negative bipolar supply, as required for the Pass amplifier. As shown in the construction details, the board is designed to be mounted right on the heatsink. This will keep the lead lengths to a minimum, which is important to improve transient response. Arrange things so the regulator is mounted quite close to the transistor TR2, so good therm al conduction occurs; this will ensure that the regulator can protect the transistor from overheating.
page 9
TESTING THE SUPPLY
Test each section of the supply before going on to the next section. The pre-regulator section is really a completely independent regulator, with fairly good characteristics. If it tests out, we know the zener references Z1 and Z2 and the IC overvoltage protection circuits are working correctly. Next we verify the IC voltage. We then test the IC foldback current limit. The final test is a “ go/no-go" test of the complete regulator. To test the pre-regulator, mount all the components except TR2 and IC1. With voltage applied, you should be
able to read the voltages shown in Fig. 5 (or Fig. 6 for a negative supply) at the zener Z1, Z2, and at the emitter of TR1. If possible, verify that this voltage is constant as long as the input voltage is between the minimum and maximum values shown. Now test the overvoltage protection by shorting the cathode of D3 (this is also the regulator output) to ground. Do this only if the IC and TR2 are not installed! The voltage at the emitter of TR1 should drop immediately to about 25 volts. This test must be passed for the overload circuit to function.
Next install IC1. You should be able to power up the regulator and measure all the voltage levels on Figs. 5 or 6.
You should also be able to adjust the voltage around the nominal value by several volts. Now you are ready to test the overload circuit. To
perform this test, you will need a 10Ω 10 watt resistor and either a 22Ω 10 watt (for the 32 volt circuit) or a 50Ω, 10 watt (for the 68 volt
circuit). Some components will get hot during this test, so perform it quickly and be careful not to burn yourself on the resistors. After mounting the IC and TR1 on a heatsink, power up the regulator and place a voltmeter across the output. Adjust the regulated voltage to the desired output level. Now place the higher valued resistor (22Ω for the 32 volt version, 50 ohm for the 68 volts) between the output and ground.
THERMAL CAPACITANCE
The regulator design takes advantage of the heatsink's thermal capacitance to provide a transient peak current capability about 50 percent higher than the RMS maximum. Thermal capacitance is really a measure of a component's ability to remain cool despite a heat input exceeding the device's heat output capability. For example, when the Pass amp delivers the 15 amp peak currents shown in his article (Figs. 22a and 22b, TAA 4/78, p. 111, the RMS value of the power required is small. When the regulator is cool (i.e., no signal), R4 maintains its nominal value and the peak available current is 6.6 times the maximum LM340T current. The LM340T can deliver more than 2 amps in this configuration, if the junction is cooler than about 50°C. Thus the maximum transient current for a cool regulator is 6.6 x 2 or nearly 14A. If this current is maintained for more than a fraction of a second, however, the 12 amp current through R4 (which develops more than 14 watts) rapidly heats the ni-chrome of which the resistor is made, and as it has a strong coefficient of resistance vs. temperature, its resistance rises also. This reduces the maximum current available. At the same time, the LM340T is heating. At 85°C the maximum available current is reduced to 1.5 amps. This results in an equilibrium point with total current available at about 10 amps.
R4 is dissipating about 5 watts, the LM340T is at or below 85 °C, and stability is achieved. The regulator can thus supply 10 amps steady-state, or a recurring peak transient o f over 14 amps.
The voltage should remain constant indefinitely. If the regulator will not supply this load, it does not have enough ouput current capability to work in this circuit, and you must try another IC. If the IC can deliver this current without dropping more than a fraction of a volt, then place the 10Ω resistor across the output. The voltage should immediately drop to a low value. Now mount TR2 and install everything back on the heatsink. Unless you have some very large resistors on hand, this is all the testing you can perform (the supply can deliver over
300 watts). Check the output to be sure that it is still in regulation by varying the output voltage with the trimmer pot. Fig. 14. Closeup of one of the author's early prototypes showing the board mounted on standoffs to a flat-sided heat sink. Three of the power devices, TR1 TR2, and IC1 are mounted in such a way that their leads are soldered to the board, bent at right angles and then mounted on the heat sink with insulating hardware anathermal grease.
page 10
A NOTE ON WIRING
The regulator senses voltage at the IC's output terminal. The wiring from this point to the amplifier should be substantial to avoid degrading the regulator response. The output impedance is only 0.05Ω; this much resistance can be found in only a few feet of #18 wire.
To keep performance up, use #14 wire and keep the lead lengths short. Also, return the speaker leads right to the ground of the raw supply rather than to the amp or regulators, to eliminate ground return IR losses.
The best approach is to mount the regulator and its heatsink right next to the power amp, arranging things so that the least possible lead length is required to bridge the gap. The leads going to the regulator are not as critical, and can be long without problems. The output impedance can be reduced, especially at high frequencies, by adding a capacitor from output to ground (i.e. in parallel with C7). This will also give the regulator the ability to withstand a dead short more easily, by increasing the risetime of the overload current waveform. This can be a two-edged sword, however, as the same increase shows up in the fall time of the output voltage. The load must therefore be able to withstand a longer and larger overload pulse. Among the amps we are considering, the only one which might have a need for the fast imiting is the original 20-20. All the rest are self-protecting to one extent or another. If you figure about 1000/iF per RMS amp of load current, you should be on safe ground. For best results, place this cap across the supply as close to the power amp as possible. This value of cap will flatten the impedance curve at about the 100Hz value, or about 0.02Ω.
The supply will provide thermal protection to the amp if the regulator and amp share a common heatsink, as long as the overload points are those suggested in the article. If the regulator is added to an existing amp, therm al protection can still be provided, as long as the heat sinks on the supply are no more than half as large as those on the amp (i.e. twice the therm al resistance in „C/W). This assumes a physical placement where the airflow for all sinks is similar.
FOR THOSE WITH OTHER POWER NEEDS
You can easily scale the output voltage by changing the value of Z2 and the capacitor C2. The maximum output voltage with the transistors shown is about 80 volts (from a Z2 value of about 65 volts). Output currents in excess of the 10 amps (RMS) maximum can be obtained by using a pair of 0,1Ω resistors in parallel to improve the wattage rating and reduce the resistance. You must also increase the transistors TR1 and TR2 to avoid the danger of secondary breakdown on an overload.
page 11
A FINAL CAUTION
This supply will source a tremendous amount of power. It is designed to drive an active load, not a crowbar. It may survive a dead short across the supply output; but then again, it may not. The overload response is improved if an additional output cap is added as described above. If you intend to short the supply (as you might on a bench supply) be sure to add this cap. Remember that this protects the supply, but reduces load protection.
Page 32
