Yes. I see no output signal except for what looks like noise and possibly some residual of a switching converter.
Is there a signal input? If so, what is it?
Jan
Jan
How to find notes?This is not distortion, this is interference from switcher, please read Jan's notes
DC converter is of bad quality and burned out.
I plan to use this solution.
How to find this power supply in the red circle?
I designed that power supply.
But the DC-DC converter is not 'weak', if it burned out you have a problem in the amp.
Replacing it with something else will not fix the problem.
Jan
Jan
Thanks for the advice。I designed that power supply.
Jan
I found a patch missing on the reverse side of the board? Must the patch in the red circle be made?
Yes, do all of the changes mentioned here: https://docs.google.com/document/d/1Msi3JuRKVNsGa9yKPpHD9AH9sX4urQjUuti1efcf5AM/edit
Jan
Jan
Sorry, can't see the other point of this wire there?Thanks for the advice。
hi jan Can you tell me where the other end of the wire is?Yes, do all of the changes mentioned here: https://docs.google.com/document/d/1Msi3JuRKVNsGa9yKPpHD9AH9sX4urQjUuti1efcf5AM/edit
Jan
Yes, the solder joint in the upper left corner of this red line is there?I don't see anything inside that circle. Are you referring to the mod in the attached pic?
Jan
Is this correct?I don't see anything inside that circle. Are you referring to the mod in the attached pic?
Jan
Hi Jan,
This page is dead. https://docs.google.com/document/d/1Msi3JuRKVNsGa9yKPpHD9AH9sX4urQjUuti1efcf5AM/edit
Can you help us on that?
Thanks.
Thanks.
Hi Derun,
Yes, that was deleted some time ago from the online storage.
I am travelling now but when I get home next week I'll see if I can find anything locally.
I'll let you know.
Jan
I'll let you know.
Jan
I am sorry, I can no longer supoport this project, and as far as I know, neither can Winfield.
But he is/was a member here so you can try to contact him.
https://linearaudio.net/winfield-hills-100w-10mhz-1000vus-amp-70
Jan
Jan
- Winfield's 100W DC-10MHz 1000V/us amplifier
