I'm looking for some insulated turrets, preferably with inside thread mounting like this one:
https://eu.mouser.com/ProductDetail/Keystone-Electronics/11512?qs=do/%2B0R7m72eYwljRf/eNuA==
Mouser wants $ 15 for each which is more than I want to pay. Someone has a bunch laying around they no longer need?
I need about 2 dozen.
Jan
Jan
I know you're looking for someone with a stash, and I have no idea re: availability / shipping costs to your neck of the woods, but this was literally the first item that popped up when searching for "insulated turrets" using a popular web browser / search engine combination from a company that I'm sure keeps ALL of my data.
https://www.newark.com/cambion/572-...d||ptaid||&CMP=KNC-GUSA-GEN-PMAX-Shopping-New
Much cheaper than Mouser, and there are likely even cheaper sources out there.
Just found this amazing item on AliExpress. Check it out!
€15,38 | EIZZ 24K Gold Plated Brass Turrets Terminal Lug Posts For Tag Board PTFE Insulator Hifi Audio Tube Guitar AMP DIY
https://a.aliexpress.com/_Eu0wNIr
Don't know why I missed those, looks better, muchos gracias!I know you're looking for someone with a stash, and I have no idea re: availability / shipping costs to your neck of the woods, but this was literally the first item that popped up when searching for "insulated turrets" using a popular web browser / search engine combination from a company that I'm sure keeps ALL of my data.
Mouser ships to me in Belgium for free above € 50 order value, it's my preferred distrib.
I wonder what the insulation voltage is, it is not mentioned on the data sheet. But looking at the dimensions it should be at least 8kV.
Jan
Fifty of them for $15: https://fairradio.com/product/terminal-50-4-40/. Looks like shipping might be a problem though--$25 minimum outside US.
Edit: Electronic Goldmine has a better selection: https://theelectronicgoldmine.com/search?options[prefix]=last&sort_by=price-descending&q=turret
Another edit: Even more at Surplus Sales in Nebraska: https://www.surplussales.com/Hardware/Standoffs/dap.html
Do a search on electronic surplus stores.
@niel Davis those are nice finds. I've been buying from surplussales before (2100V film capacitors) and they're OK and reasonable shipping.
Their (TSL) PS31 looks just like the $ 5 'official' item at 1/10 the price.
And I now also know the difference between turret and post!
@as-audio I saw that but they look damaged by overheating. I'm not that desperate ;-)
Jan
Jan
Yes, but the eBay shipping module has gone bonkers!Put Keystone 11512 into Ebay and see what you find -- there is a seller!
Jan
Another issue.
If I screw a turret into a Teflon base plate, can I still solder a part to the turret without the Teflon starting to fume?
Teflon seems safe up to 500F (260C) and solder temp is higher, but local.
Jan
Jan
Sorry man, have a close look, this is new old stock, bakelite.
Another eBay, I just got some of these and the quality is great. Teflon. And yes unless your iron is above 450C, and even then only if you abuse them. I've soldered and unsoldered at 400 many times.
https://www.ebay.com/itm/1448463644...rQe-7SNShO&var=&widget_ver=artemis&media=COPY
Loren
Loren
I don't see them.Sorry man, have a close look, this is new old stock, bakelite.
The usual way to refer to such things is by quoting the URL, that would be more helpful.
Can you please?
Jan
With all the info given, I'm gyrating to another solution. Note that I need these for some very high voltage points, up to 8kV.
These turrets look to have rather sharp edges which would be prone to corona, while their insulating voltage isn't clear.
I ordered a bunch of those nicely rounded posts from AliBaba with the M2 thread: https://nl.aliexpress.com/item/4001007632599.html
... which I can screw into the Teflon baseplate instead on a PCB. No sharp edges. I only need to be sure I don't damage the Teflon when soldering, whcich should not be an issue according to @kb2wyl.
I think I'm all set, thanks guys!
Jan
Jan
At first you said "I saw that but they look damaged by overheating"
and now "I don't see them".
196332110834 is
https://www.ebay.com/itm/1963321108...id4/36egu1caenuq1lA2m94g==|tkp:Bk9SR5iirr7YYw
196332110834 is
I was curious so I tried your link again. This is what I got.
Don't worry, I don't think it is your fault, no idea what's going on.
Jan
If you insist in the form of a column it is not. You can however add a threaded standoff.
If you want a chassis solder point this model is very suitable - and it can be stacked to a
multiple solder lug column. These are standard parts from the past, I use them frequently.
Go to German Ebay if the seller is in Germany. He even has turret in the headline.
Yes it is quite suitable as a multiple solder lug pillar.
Too many sharp angles for high voltage.
But I appreciate the help.
Jan
Jan
