XXV Sampson power up issues
right, the power supply driver transistors, the ktc3228/kta1275. The via's were pulled out and solder pads were gone so I had to jumper them to the nearest reference point. I have looked into repair kits to replace bad traces, solder pads, and throughholes.
Isn't there a trace for the damaged connection on the component side of the board? If so, install the driver transistors as shown below (long leads) and make the connections for the pulled via terminals on that side of the board.
It doesn't have to have win7. No one has had trouble with win10 and ad far as I know, win11. The PC doesn't need to be anything special. It doesn't take a lot of resources. If there's something out there that still says it has to be used on win7, let me know so I can change it. If you're considering it, email me so we can get some preparations out of the way.
babin_perry@yahoo.com
