Tamura F-2013A
Specs: 10K 50H?
For 10K should be 80H for 20Hz
For 15K should be 120H for 20Hz
I never liked Tamura for their specs..
Specs: 10K 50H?
6197 with gm of 11000 and internal Mu of 22 would give an Rp of 2000 Ohm at 30 mA idle. 7.5 Watt Pdiss.
The 7x 6197 was just a napkin scribble guess for how many tubes to get 25 Watts out in pentode mode, class AB.
For 25 Watts in triode mode, and class A, that would take more like 16x 6197 tubes. 16 tubes in parallel would give 125 Ohms Rp equivalent for the bunch. Figuring 5X that for triode operation with low distortion would require a 625 Ohm primary SE OT. A rough estimate anyway for continuous operation. (class A)
So, I guess 300 Watts in class A would take around 192 tubes. $63 of tubes. $400 of sockets. Whew! At least you won't need an OT with 19.2 peak Amps available. Forget that idea.
Well, I guess that could be scaled down considerably if taking audio crest factor into account in class AB. Maybe 50 tubes would work for peak power intermittently in class AB. Just not for continuous sinewave.
The $0.33 price comes from a tube sale at Bangy-Bang tubes (on Ebay) early this year of military surplus stock in high quantity. 200 tubes per box. Normally that place is hideously expensive for single tubes, so I guess they do some volume sales occasionally (of overstock) to keep people checking their website or Ebay store. When an Ebay sale says "serious tubes" I figure a SERIOUS $$$ price goes with it.
I have seen some prices on 6197 tubes on Ebay recently in the $0.50 (60 quantity) up to $2 range lately.
Thanks, I'll have in mind for future project, know I have to see what I can do with these big baby's 🙂
It's very difficult to make transformers for 1000:1 frequency range, and even harder with DC biasing the core. Yet another option is to use two different transformers per channel, one optimized for low frequencies, one for high. Only the low frequency one needs to carry DC. Paul Klipsch built an amplifier like this (mono! of course) in about 1946. On his the output transformers were mounted at the speaker, with high voltages running between amp and speaker - don't! of course.
All good fortune,
Chris
All good fortune,
Chris
PWK's amplifier also had different turns ratios for the two transformers to match the different sensitivities of the high and low frequency drivers. Made for the Klipschorn, of course.
Best,
Chris
Best,
Chris
That way you can do a subtractive crossover and do away with a lot of the usual full range output transformer issues and also some speaker level crossover issues.
It brings it's own issues of course.
Does anyone knows any old amplifier using 211?
I want to compare how they use this tube.
In the RCA datasheet recommend at 1250v Rload=9600
What is "old" for you in that context? Sound Practices era old? Or RCA-still-producing-211-tubes old? If the latter is the case you will have a hard time to find a schematic for a hifi amplifier, as the 211 is a transmitting, not a receiving tube.
Check the schematic for the Western Electric 43A amplifier; it used 211s for sound reproduction.
All good fortune,
Chris
Hi, Chris this sounds little complicated
why not use a bi amplifier, 2a3 for mid and high range and a class D for Low range?
Western Electric 43A use 211 in PP, it would be interested to know what is the impedance of the output and the frequency response..
- Tubes / Valves
- 211 output transformer suggestion
