6J6 and it's history
One thing to remember is that the top stage of a cascode circuit is the very high output impedance.
The gain is high if the load is high impedance, but the gain is low if the load is low impedance.
Using a triode for the top stage of the cascode, the effective rp will be many times higher than that of the same triode rp in a single tube common cathode amp that uses a bypassed self bias resistor.
A load that varies widely versus frequency is probably not a good application for a cascode circuit.
The output rp approximates the load resistor Rl in parallel with the following grid resistor. If the load varies can always be damped with a paralleled resistor just as the ancients did with transformer coupling. 🙂
jhstewart9,
That is a good way to improve the frequency response of a circuit.
Just reduce the total load impedance.
Swamping works!
The lower the load resistance, the lower the gain.
The advantage of the cascode then becomes linearity, but not gain.
Tradeoffs.
A low load Z keeps the cascode stage honest, but it's the stage below it that is difficult to get linear in the 1st place. Most tubes aren't linear into a near fixed voltage load or low Z diode function load. The beam deflection tubes are linear (current, at least for 6JH8) into a fixed V load.
An interesting topology might derive from the latest "new" series Schade (UnSet, CED) scheme (using cascode stages up top) combined with the beam deflection tube (on the bottom).
A set of R dividers from the cascode plates back to each of the cascode grids (then down to a ground ref.) would make sure the cascode output V's are proportional to the cascode cathode input V's. So producing a low output Z from the cascode(s).
The beam defl. tube performs the input V to cascode linear drive function. The "new" series Schade top acts as an impedance transformer for the BDT. The cascode input V is some fixed ratio of the cascode output V due to the grid N Fdbks, and with the same currents. Of course some small Mosfets could perform the cascode functions well here too, without heater voltage issues.
note:
The BDT outputs have a lowish Rp due to the Mu 6 of the BDT. The Mu factor comes from the dual plates acting as deflectors also, acting as N Fdbk to the beam deflection resulting from the input deflectors. Both produce transvers E fields to the beam direction, giving linear deflection results.
There was a pentode version of the BDT designed also, the 7763 tube. It had a screen grid between the deflectors and the plates. Only a few were made by GE before the tube era ended. It had high Z outputs.
