ACA - help needed
“Once turned on, it just "farts" on the speaker, sounds like a 3 second discgarge noise for the lack of better explanation”
Suggests that the amplifier is working because they make that noise (unless you are in the balanced mode) when you turn them on. Thus my suggestion to make sure you are putting something in the input spigot.
Read this post and the posts following:
Copy that. Did some kits in the past (akitika, pass korg...) and never had that so good to know.
BTW while we're on the subject, any recommendation what caps to use as an "upgrade" for this amp?
Guys thank you all so much for helping troubleshot this, I really appreciate all the help!
Cheers!
