Aleph J Zen Mod resistor help
Hi i am building and Aleph J zen mod and would like to know about the r9 resistor it measures with my meter as 0.750kohms but on the sheet it says 750R i ordered the kit from diyaudio store is it possible they sent me the wrong resistors?
@yarozebob, you should just stick with the Aleph Jzm Build Help thread. You now have three different thread posts about your amp and it's too hard to follow what's going on. The recommendation in the Aleph Jzm thread (not the build help thread) was you should not apply power until you fixed the wiring. Please don't power up your amp until that is resolved. You're going to potentially damage the amp boards. The proper process to validate and verify proper build in a step by step process as you build it does not appear to have been followed. Let's get it fixed right...the second time (since we didn't get it right the first time).
